Bill97
Members-
Everything posted by Bill97
While I am away from the “shipyard” I am of course from time to time peeking in on MSW and reading other builds. I see different opinions on mast construction and wonder what a little debate about the subject might reveal. I see some build the entire mast to include the yards off the ship and then drop it into place and start adding the shrouds. Others build the mast off the ship, drop it into place, then add the shrouds, and finally the yards. Others work their way up from the lower mast. First installing the lower mast section and then its shrouds, then the next section and its shrouds, then the next section and so on. Then finally installing the yards. I have done it all three ways over the years without a sure fire favorite. What is your favorite mast construction sequence? Will be coming up on that in the next month on my SR and will need to decide my plan of action.
- 1,508 replies
- Le Soleil Royal
- Heller
Spent a great afternoon exploring the aircraft carrier Yorktown in Charleston harbor. Very interesting the life of sailors on these incredible old ships. To think modern day aircraft carriers are so much larger.
- 1,508 replies
- Le Soleil Royal
- Heller
Thank you so much Robert. Everything you added will be extremely helpful. You may become my new best friend! 😊. Which Soleil Royal kit are you looking at?
Thanks Robert. I have ordered the OcCre Endeavor and it is on the way. I did not need it yet but ModelExpo had a fantastic sale on it so I had to grab it. The box will set on the shelf tempting me. Will read through your build frequently now with eyes toward the day I will start it. Please feel free to send me any thoughts and recommendations in advance that I will file for further reference. Thanks again Robert Bill
With these few issues successfully tackled I am going to close up the ship yard for a week and send the workers home for a short vacation. My family and I are leaving tomorrow for our annual trip to the beaches of South Carolina to spend some great time with our feet in the sand, swimming in the ocean, and enjoying some great low country cooking. Be back next weekend anxious to get back to my Soleli Royal. I admit I will still frequently check MSW for interesting conversations that I most likely will comment on from time to time.
- 1,508 replies
- Le Soleil Royal
- Heller
The glue has dried and everything seems to be holding n place!! Woo Hoo. Now to clean it all up, put the catheads back in, and touch up a butt load of paint. Also while waiting on the glue to set up I started tinkering with the deadeye strop prototype. A little solder and blackening and I think this first part of chains will work.
- 1,508 replies
- Le Soleil Royal
- Heller
Ok they are glued in place! Fingers crossed all the glue points will hold when clamps released. Will definitely be a good bit of paint touch up over the entire area. I noticed there are even curved areas on the back of each to work as glue points to the round houses.
- 1,508 replies
- Le Soleil Royal
- Heller
In theory now I have it. Now I just need to make it reality when glue joins the party! Marc my catheads were off a little bit. Do some repair work on the deck and beakhead bulkhead then see if I can glue this puzzle together.
- 1,508 replies
- Le Soleil Royal
- Heller
Thanks Marc. I immediately see I need to make some adjustments to mine. I did not realize the catheads are to set on top of the head of the figurine. I have the support corbels set in very close to the steps. I need to move them out further and turn the cat heads out more. Looks like a bunch more paint repair ahead of me 😞
- 1,508 replies
- Le Soleil Royal
- Heller
Marc do you have photos of what you did posted to your build? If so I will look to see what you did. Bill
- 1,508 replies
- Le Soleil Royal
- Heller
Henry I also looked back a good ways into my build and remembered Daniel (Dafi) has a pretty good tutorial on making chain plates. Hopefully with your’s and his I can do a pretty good job of making the chains. Now that I have pretty much wrapped up the stern (except for the lanterns and cannon hatch covers) I am moving back up to the bow. Installed the cat heads today and the two round houses. Had a little unfortunate glue squeeze out where the catheads are glued to the deck. Removing the squeeze out resulted in a little deck paint damage so I sanded it out and applied some undercoat to the bear plastic. Hopefully with a little patience I can touch up the paint to where it is not noticeable. Marc I don’t know if you have experienced this yet but I think you might. Back earlier in my build I followed your lead and put a second rail and lower panels in the rail at the top of the beakhead bulkhead. Not realizing that when it came time to install the catheads they needed to pass from inside to out along the bottom of the rail. I simply cut out the far left and right extra rail sections and panels, cleaned up the rough cut edges, and installed the catheads and (corbels?) under the catheads. Some touch up painting a little later and this step should be good. Of course I will not be surprised if you guys respond back that I did the catheads completely wrong thus my issue with the rail 😊.
- 1,508 replies
- Le Soleil Royal
- Heller
By the way Henry I am now spending a great deal of time reading and rereading through your section on making your deadeye chains. I will be begin practicing making my stropes and chains fairly soon.
- 1,508 replies
- Le Soleil Royal
- Heller
Great advice Henry. I have painted them already the dark mahogany that is prominent at the bow of the ship but have since about sanding it off and painting it the same blue as you plan. Will see what fiddling I have to do to get a solid strong mount.
- 1,508 replies
- Le Soleil Royal
- Heller
Ferrus that is the exact book I used to build my HMS Victory. With Ian as my class professor and Longridge’s book as the designated text book for his class I learned so much 😀. Primarily used the last half of the book on rigging. I still have the book and use it often for reference. Honestly just the other day when we were discussing the need to move the knightheads on my SR I pulled Longridge’s book out to refresh my memory on what the lines are you were referencing. I have wondered how similar in rigging French and English ships were during that period? It would be great to be able to use Longridge’s book again as reference when rigging my SR. I also have Anderson’s book.
- 279 replies
- Spanish Galleon
- Imai
Henry how did you treat the back side of these two guys (paint I mean). Did you paint the back to match the front even though the moldings are not present, or did you paint the back one solid color? Also do the top ends attach to the sides off the bowsprit or do they just flank it without being attached? I am moving in that direction and I am wondering if I need to go ahead and install the bowsprit first. These guys also need gold leaf.
- 1,508 replies
- Le Soleil Royal
- Heller
I am going to need to look ahead to the rigging area to refresh myself on all the rigging terminology and steps. I got pretty knowledgeable while building my HMS Victory using Longridge’s book and Ian’s excellent advice. Hopefully looking back at all my reference materials, when the time comes, will be helpful.
- 1,508 replies
- Le Soleil Royal
- Heller
Ferrus I am about to get an umbrella with all the rain you’re bringing 😀. I am afraid the main knighthead would be most difficult to move at this stage in my build. Not a lot of work room and I distinctly remember the base of the main knighthead spreads out below the deck and was captured between the two deck halves when they were glued together. Would require a rather large hole in the deck to get it free. I will probably just have to tap dance around what ever happens here during the rigging to make it look OK. In other news I added all the statuary on stern and finished all the necessary paint touch up. Now to go back and add some highlight gold leaf and the stern will be complete except for the three lanterns I will add near the end of the build.
- 1,508 replies
- Le Soleil Royal
- Heller
On no Ian don’t be sorry. The intellectual debate is mental stimulation. None of us want to be in those frequently displayed videos of people blindlessly following each other down the street. And so to model ship building instructions. Hopefully this will help the next Soleli Royal builder who looks to this build for help and assistance. Which is by far the most valuable benefit of. MSW. So I will do the repair to the deck and reinstall the knight head off center. Then back to the stern. Marc I will definitely review your alternate belay pin screen shots. While we are briefly talking about belay pins I have an opinion question. Some may have noticed in my photos that the belay pins along the bulwarks are gone. When I unboxed the kit I found a number of the fragile plastic belay pins broken off or bent. I just cut them all off and drilled holes for future metal pins. For this purpose I am thinking about using needles with the head still attached and cut to the appropriate length for above and below the rail. My idea for leaving the head would be to eliminate the sharp points that would be left on the tops if the head was removed, possibly leading to scratches here and there about my arms and ultimate blood letting 😳 Thanks guys. Bill
- 1,508 replies
- Le Soleil Royal
- Heller
Ok so I am leaving the knighthead off center? Just out of curiosity I looked at a number of other Soleli Royal builds here on MSW and don’t find this issue addressed anywhere else. Since I have already moved it I am inclined to go with Henry and Ferrus. Not based on any nautical research or expertise I have. Just the fact you guys sound pretty convincing. On the other hand I have always trusted your advice Ian. Marc I consider you the expert on the Soleli Royal. What say you? While I wait for a unanimous decision I will return to the stern of the ship for continuation of attaching statuary and additional gold leaf. Thanks guys for your debate and final conclusion. Very much appreciated.
- 1,508 replies
- Le Soleil Royal
- Heller
Oh no Ian. Let’s figure this out for sure before I refinish the deck. I may have to move the knighthead back to where it was. I actually found the look of the knighthead being off center a bit odd but moved it anyway because I understood that to be the way it should be. Henry need you in on this debate.
- 1,508 replies
- Le Soleil Royal
- Heller
Ok enough procrastinating. Repositioning of the fore knighthead in process. A little putty and deck paint touch up still needed. Then will be good to go.
- 1,508 replies
- Le Soleil Royal
- Heller
Marc maybe I am selling myself short. I don’t know. But every time I look through your updates I am amazed! There are two separate areas of amazement that I can’t decide which is more impressive. One is your complete physical remake of the ship regardless of what color scheme you would decide to use. Two is your exquisite detailed paint scheme that you could have just followed on the kit right out of the box. Early on, at the beginning of my build, I decided I would go no where near attempting to follow your lead on redesigning the structural build. I would have just made a fool of myself. I only picked a few things here and there to copy. Secondly, way before I started mine I studied your painting. The beautiful detail everywhere, especially in the painting of your statuary, is incredible! I thoroughly enjoy small detailing and colorful painting but your skill level is so impressive. I decided it best for me to not attempt your expression of the ship, but to leave this version of the ship to you alone in the history of model ship building. Better to not attempt a poor imitation of the Mona Lisa. Now after all this Saturday morning pats on the back let me just summarize by saying very well done my friend. Tres bien joue mon ami en effet!
- 2,607 replies
- heller
- soleil royal
(and 9 more)
All of the touch up putty, sanding, and painting of the side galleries complete. Now to add a repair some gold leaf here and there and then I am ready for all the statuary. I noticed that I have broken off one of the acorn shaped tops on the side gallery. Not sure if I should just cut the other one off or try to craft a new replacement.
- 1,508 replies
- Le Soleil Royal
- Heller
- 1,508 replies
- Le Soleil Royal
- Heller
Ferrus I don’t see a “follow” at the top of the page to click on. I usually just save a site in my favorites and check now and then. Please advise this actually 70 year led brain where to find “follow”.
- 279 replies
- Spanish Galleon
- Imai
