ubjs
Members-
Everything posted by ubjs
Master Korabel kits I think is very good and maybe the woodenkits who is most like plastic kits. They have a Cannon Jolle from 1801, not much rigging. I think that the first wooden kits you build will not be fantastic but its fun building wooden kits. Just buy a kit and start building!
I build on a steamboat, the hull and the superstructure are largely white. I'm thinking about which is best, to paint the hull first and lay and varnish the deck then or vice versa? I think it might be best to paint the white first because the decks should not be painted and I do not want to get white paint on them.
3d printed details
ubjs replied to ubjs's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
I think it's resin. Here is a close up. It would be very good with tips on painting and sanding because I have no experience with resin. -
If I am going to show a modelship in a stand, in this case Vasa from 1628, should one show the starboard or port side?
_One idea, just plank one side of the ship.
Hi I have both Billings and DiAgostinis Vasa and the difference is hugh, I think its not right to compare them. DiAgostini-kit price is twice that of Billings, ofcourse the most is better in DiAgostini. I am a beginner myself so I cant tell if all is ok in DiAgostini kit. I think its the same kit you could buy from Artesania Latina https://artesanialatina.net/en/ships-elite/62091-wooden-model-ship-kit-swedish-warship-vasa-1-65-8437021128031.html One thing I like with the 1/65-kit is the basic construction of the ship. Much more stable than Billings. The wood I think is better in the 1/65-kit, its really bad in Billings.
Good to hear that I´m not alone in my hullbuilding. As someone said, ¨when you buy a kit, you buy a dream¨.
I should have written a smile beside the statement of simple. I thought about the qualty of the material. But I think that its mostly the size of the build that makes its a experience rate. Otherwise its like every other ship, just more planks, more cannons and a lot of rigging. I´m absolutely still a beginner in this hobby, even if I have built some hulls I have never completed a build. I have built the hulls of Norden, Billing boats, Swedish gun boat, Amati, Spray, Bluejacket, Lilla Dan, Billing boats (my first ship, bought and started 1976!), Phoenix, Master Korabel. Some of them have stopped on a problem in the build and Lilla Dan needs wood that I cant get because Covid. Phoenix is on hold because I need more training in building in wood, it is a very good kit but you must be very precise in building it, no tolerances. Maybe I just like planking a lot. I have now started Vasa because that was the ship I wanted to build from the beginning. Because of the pandemi I think that I maybe not have so much time left and I should use it as good as possible.
With two persons in this thread that have built Billings Vasa I try to ask a question about the construction in the beginning. Billings suggest that I shall glue two lists 4x8 mm between frames 4 - 13. If I do so I have to force the lists approx 15 mm down on the frame in the middle. I dont like that to bend it so much, did you do that and how ? Or did you do it another way? I have glued all the frames to the keel.
Luckily I bought an old Vasa-kit for 50 euro at a market, so I can replace the unusable parts. The old things were not lasercut but straight and of better quality than in the new kit, says a lot I think. I also like Master Korabel and now I understand what a big difference it is between different manufacturers. I have at least 10 Billing kits on the shelf, no one to blaim but myself. But they are cheap so if I buy new good wood I think I could make boats of them.
Yes, maybe I shall throw everything in this box away. Really bad material, even if i only payed 400 I think its worth 100. Thats the worst thing about kits, the material is really bad. Maybe its a european thing, no one sells US kits in Sweden, apart från Eskader who sells Bluejacket, and what a difference compared to Billing boats.
After reading the answers here, I have to ask if I break any rule if I do not build the model in the ¨correct¨ way? I was going to start a construction log, but now I doubt if this is the right forum.
Billings Vasa is a fairly simple model, for example, the sculptures are greatly simplified. After I bought it, there was a much better one in scale 1:65 which I also bought. So my idea is to put Billings together first and then make a smaller effort. One thing I have thought of myself is to either simplify the rigging or to build the model with masts cut 5 cm above the deck. Thought there might be more ideas on what can be made easier.
I'm thinking about how to most easily build this model, Vasa from Billing boats. Here on the forum, there are a lot of great constructions where the builders have probably spent hundreds of hours on their models. But I want to build the model in a simpler way, I just want something that looks ok for someone who is not a specialist in ship models. I am looking for tips on how I can simplify construction.
NEW Vasa kit from Artesania Latina -- looks to be quite good
ubjs replied to md1400cs's topic in Wood ship model kits
I think its the same kit former sold by d´Agostini. I have it och think it looks the same. -
Newer to Model Building, requesting assistance.
ubjs replied to histprof1066's topic in Wood ship model kits
Billing boats Wasa nr 440 is an old kit in a smaller scale than the kit Billings sell now. I think the scale is something like 1:115. -
There seems to be a lot of kits that one could recommend to beginners if they only had better construction descriptions. I'm wondering if it's ok to write a construction description for a kit and post it online? Or do you do something illegal then?
It is of course positive that there are so many nice buildinglogs here to be inspired by. But as a beginner, you probably have to accept that the first boats will be far from perfect. Maybe you should lower the requirements for your first boats and build them with a little less detail and above all simplify the rigging. I think it would be good if there were suggestions in the instructions for things that can be simplified or even excluded. I myself am a beginner, have so far put together some hulls but have not finished building any boat. Currently working on Master Korabel Polotsk and am impressed by the instructions and precision, but it is not a suitable first kit really. Maybe suitable as second build?
Index for building logs gone?
ubjs replied to ubjs's topic in How to use the MSW forum - **NO MODELING CONTENT**
OK, can I get only building logs? I got a of forum posts. -
Enköping harbor by ubjs - a model railroad module in 1:45
ubjs replied to ubjs's topic in Non-ship/categorised builds
Here is a picture of one wall I have built. I use 2 mm thick balsa wood and cut in a little Proxxon saw. I glue the strips to cardboard and I shall make doors in plastic strips from Evergreen. The houses will be quite large so I will have to find out a way to transport them with the walls separated. Maybe I´ll use Lego pieces or magnets to hold them together at meetings.
