marsalv
NRG Member-
Everything posted by marsalv
Pandora by marsalv - FINISHED - 1:52
marsalv replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Thank you guys . To Greg: The moldings isn´t done with scraper, it is made with milling bitt - the same method I used for standard production (see pictures in this contribution) Small step forward - installation of chanells. -
Hello, this kit was produced by company Igra in former Czechoslovakia (now Czech republic). I built this model many many years ago and model is not good. best regards Vladimir
Thank you guys . To wyzwyk: the netting is made from YLI quilting thread (http://www.ylicorp.com/product.aspx?PID=63304a0f-0bb5-4b6d-8d39-4ddb657a3c6a&SCID=783065c6-9646-4430-afa0-3911b032b4f4), colour nr. Lt. Brown 21100003. Galion is done, so I went into the port lids and their hinges. -
Thank you for nice comments . I added a few details to the galion - boomkin and berthing rail with head netting. -
Thanks guys . Last part of galion is done - cathead supporter + eking rail.For this piece, I had the greatest fear because it is curved in all three planes. In the end it was not quite that bad (the previous head timbers gave me a hard time considerably more). I am glad I have this complicated part behind me. -
Thank you Tom, but the reality is not so simple as the photos show . I attached the false rails, main rails are installed on the model. -
Your welcome WackoWolf . I continue with other details on the front part of the main deck. Catheads are already installed, so I can continue with galion. -
Thank you guys for comments, but you are not right now. I'm not satisfied with the already finished parts (lower and upper cheeks), and so I decided to make them again. It's hard for me to explain it with my bad english, but used wood has a distinctive structure across the fiber and on the manufactured parts is this structure too visible. I had to choose another orientation of parts on wood. A few minor details is completed - wash cant, gammonig chock, bolster nad lining in the hawse holes. -
Thank you druxey . Now I started the most complicated part of the model for me - the galion. In this moment is completed only the "easy" part - lower and upper cheeks -
Thank you guys, I´m very glad that you like my build. Your positive comments are the driving force to further stages of construction for me. I'll try to disappoint your expectations . Today only few photos of details on the outside of the hull. -
Thanks to all for very nice comments. To RedDawg - blackening solution is desribed in post #206, with regard to nuts and bolts I used the following parts that simulate bolts and nuts: http://www.litomysky.cz/kadee/kad088.htm. So the guns are finally done, rigging will be added immediately prior to installation aboard. -
Thank you guys. Because I have no duplicator, I had to turn each gun separately (many time and many destroyed material). Details of carriages added. -
To Allan - the monogram is not my production, these are made by "etching" company (http://www.etchworks.cz/). Normally are parts etched simultaneously from both side, here is etching made only from one side. Before gluing is necessary to roughen both surfaces (eg. tweezers) then glue adheres well (I had to repair two pieces from 20). The solution for blackening - heated solution water and patina for Tiffany technique (ratio 50 : 1) (http://www.vensy.cz/vensy/eshop/12-1-Tiffany-technika-cinovani/31-2-Chemie-pro-cinovani/5/345-Patina-cerna-tiffany-technika) Carriages assembly. -
Monogram is etched from brass 0,2 mm and glued with CA. The blackening of guns is done a I started preparation of parts for gun carriages.
