Everything posted by ERS Rich
Boss! Someone said, a masterpiece is a collection of simple steps, each executed perfectly…..
- 282 replies
- Bluenose
- Model Shipways
Various Photos Flag on the aft jack. Prefer to heavily crumple the paper flag. Also touched up white area on the stern. Finished up the hawse lips and bow ornaments. Views of the main deck stanchions. Line is bass wire, tried thread but to difficult to pass through the stanchion eyes.
- 166 replies
- Maine
- BlueJacket Shipcrafters
Hi John. Is the 3/16” drill bit used to hold the ring for drilling a hole into the ring? Thanks for showing how it’s done. -Rich
- 282 replies
- Bluenose
- Model Shipways
Hi Alistair, Thank you very much for the kind words. Yes, this kit had everything needed to produce a fine model of the Maine. At the end, I’ll post thoughts on some things to be careful about when building this kit. And I do have another USS Maine kit that I’d consider selling along with USS Olympia if anyone is interested they can private message me. Given the price of shipping someone would have to be within driving distance! Cheers! -Rich
- 166 replies
- Maine
Home Stretch It’s getting down to it. Not many more tasks to do. The heavy lifting is over. Here is a shot of the bow ornaments. Followed by the entire ship with the main deck stanchions installed.
- 166 replies
- Maine
Accommodation Ladder and Railings Here's how the accommodation ladder install went. Two brass rods under the top platform. Using the bit as a weight on the lower platform for tension in the block ropes, then liquid CA on the ropes. Added the U shaped rod, seems to make sense, may redo it seems a little out of scale. Railing install pretty straight forward - use little dots of CA in the corners instead of along the bottom of the whole piece.
- 166 replies
- Maine
Good Morning, Will make the case, thinking of cherry hardwood and probably plexiglass panels to minimize the weight. Need to source a sheet of cherry faced plywood. I have some Kusmi #1 button shellac that looks nice on cherry (shellac.net). Have a good weekend. -Rich
- 166 replies
- Maine
Aft Boat Davits Rigged the davits, and radial davits this week. I like to get everything in place, to make sure everything fits before tying off the lines. Just love how this is looking. Made a little jig to help place the davits.
- 166 replies
- Maine
Hello in New Zealand! Thank you, for the encouragement. Oct 4 will be one year, and it looks like I’ll finish by then, outside of the case. Looking forward to building several 1/32 aircraft. Nice break from so much construction. Rigging the cranes tomorrow, then just the companionways to construct, and finally the scroll details. Cheers Alistair
- 166 replies
- Maine
Hello Michael, Welcome to MSW. Congrats on finishing your project. That’s a huge accomplishment. Best if luck on the next one! Cheers, -Rich
Hi Giuseppe, welcome to the forum and best of luck on your projects! -Rich
Hello George, Welcome and it’s good to know you. Your ship is coming along nicely. There is a topic called “At a Glance” where progress pictures are posted. Check it out. -Rich
Hi Fred, glad to know you! -Rich
- 166 replies
- Maine
Rigging -Continued At this point the standing and running rigging associated with the masts is installed but not belayed - tied off. Sun in the shop this afternoon put light on the subject. Have a good weekend!
- 166 replies
- Maine
More Rigging Rigged the aft mast derrick with this setup. Then installed it on the ship. The round nose pliers make “S” hooks easy. Foremast rigging is coming along.
- 166 replies
- Maine
Good Morning, thanks schooner. Annapolis is a place I’d like to go, just haven’t made it yet, we have a new dog, and my wife would go but she isn’t into museums. Looked up “preventer” in a couple of books I have about rigging, nothing there. I’m not an expert on rigging/line names, I’m a mechanical engineer, so from my point of view seems like extra support, maybe because of the “crows nest”, imagine men/weapons up there at battle stations. Getting to the finish line, started last October, hoped for six months. Eager to start something new. A simpler project.
- 166 replies
- Maine
Rigging the Foremast Here is my general approach to rigging, the major steps. First lines are seized with a lashing, using this setup. To the left are several lines seized to turnbuckles for shrouds. Here several shrouds are in place, I like to create tension with the silver clamps. Sometimes I apply CA at the top, this fixes the shroud so one side has tension while the other side is rigged. The seizing is left relatively loose so tweezers can be used to take up the slack. Blocks were blackened with a solution from Bluejacket. First drilled out the hole, then threaded the blocks on brass wire. Dipped in the solution, then swirled in the water to stop the reaction. Later the block sides will be painted, after installation. The blocks were stropped with wire, and a hook formed with the pliers with round ends. The preventer was built on a piece of plywood, with posts spaced from a measurement of the model. Tape is used to hold it together for placement on the ship. The Preventer is installed. Tape is removed.
- 166 replies
- Maine
Rick, Roger, Alistair, Thanks for the encouragement. I’ll post pictures of the rigging asI go along. Thinking of making the case with Cherry Hardwood, have some that’s been around too long and may as well use it for this. Thanks again, and have a great weekend. -Rich
- 166 replies
- Maine
End of Construction At this point the construction steps have been completed. Next is Rigging, beginning on Page 58 of the manual. Once the rigging is done will fit the railings and the bow and stern scrollwork. Then final touchup, dusting, and the case. Thanks for following along.
- 166 replies
- Maine
