PRS
About PRS
  • Birthday 05/06/1958
  • Gender
  • Location
    Barrie Ontario
1,280 profile views
  1. OK starting the fairing process. This is going to take a while...
  2. Grab a chair and there is coffee over there and beer in the fridge.
  3. Lining up the gun port lays. I took a lot of time with this and left it overnight to look at it again the next day and did see where I could make some adjustments. I am going to frame the upper and lower port openings before fairing as to give some support at the top. The piece of wood I am using is the exact opening dimension on the large end which makes lining up the top piece easy. I must say having a table saw and a crosscut sled sure makes duplicating these pieces easy.
  4. Thanks. I can now do this in a proper wood. It was just a test piece out of 1/4 poplar and the wood colour is not that great.
  5. So this piece is just a test to see if I could cut the parts properly. I have some cherry coming on order and hope it will work for this ship but will not know until I see the pieces.
  6. Glued on the rabbit strip and chiseled and sanded the bearding line. When that was dry I glued in all the bulkheads and filler blocks.
  7. I have all the bulkheads done and test fitted. Nothing glued yet. Where am I going to put this monster when it is finished?
  8. Thanks Chuck. I wasn't able to find lite play locally so went with this. I am used to sanding aircraft ply which is real tough stuff so I will see how it goes. I initially looked at MDF but the panels were warped really bad and I know that stuff is hard on blades because of the glue if the blade gets hot. Thanks Matt. Just time consuming and slow work. Good to know. Wasn't sure if the rubber cement would get into the wood and make it hard to come off.
  9. Posting the start of my build log for the Winchelsea. This is going to take quite a while to build as it is huge and complicated with many parts to make. I am going to attempt to scratch build as much as I can as a challenge to myself. I started cutting out the bulkheads and false keel with my scroll saw and it can be done but you have to use sharp blades and work slowly. You WILL break blades and I found that when they get dull you are not far off from breaking. These are the blades I used. They give a very smooth cut. I am using 1/4 inch birch plywood sourced locally and printed out the parts to cut and then used a glue stick to the wood. Then carefully and slow cut with the thin blades right on the line as best as possible. I found sitting with my saw on a desk works best as it ends up being chest high and you can follow the lines easier than standing which is hard on the old back. I did cut the false keel in three pieces as this will keep any warping between pieces to a minimum. Once the pieces are cut I have a sharp scraper and just peeled and scraped the glued on paper off. This scrapper has been sharpened with 800 grit sandpaper so it is very sharp. While I was at the lumber store I also picked up a 3/4 inch MDF used for stair treading as my work base. It is nice and straight. I also made up some squaring pieces for assembly and did have to modify the bases a bit later as they are too large and interfere with the bulkheads. Here is have the false keel pieces glued up and held straight. It was a lot of cutting and if you do it slow not much sanding. Once that was all set I mounted my squares on the build board. There is a very slight warp at the top of one of the pieces which release when it was cut but I am aware of it and will make sure there is no warp built in. Next up is the process of cutting each bulkhead and laying them in place. You know there are a lot of them right? I still haven't decided on Yellow Cedar or Cherry for the most of the build yet. Hope you can follow along and offer suggestions or even an attaboy which helps with motivation as my new 3d printer keeps pulling me away from my projects
  10. Wow you guys are awesome and I really love the comments! I do spend a lot of my free time building as it is my hobby hence the fairly quick build. (I need to slow down) My next project is the Winchelsea. I have the plans and do have a plan in mind. I will be cutting most of my parts myself as I really enjoy working with wood. That will be a slow project and it is HUGE!
  11. Thanks for the likes and comments throughout this build log. It really helps when people comment or offer suggestions. Here is the final resting place and also my crew member.
