Richard Dunn
Everything posted by Richard Dunn
  1. Yes Lou, I actually tried to find some round head brass pins of the right size but I had no luck. If anyone does know here are the sizes and quantities. The other problem of course is the head dia is the important size and not the one they give, normally they give the shaft of brads and don't even say what the head dia is. 1.4mm head dia x 3750 1.2mm head dia x 3750 I still have not heard from that other mob, not great service at all, glad I checked before paying for them online.
  2. The plating is .5mm 3ply and you can't pounce Ply also I want resin rivets with shanks as they have to actually be glued in to hold the promenade screen in place. The reason for ply over styrene plating has already been discussed in a previous page somewhere.
  3. Thanks Jim! Hey has anyone had any dealings with Plusmodel in Czech republic, I have asked about product availability for thousands of resin rivets, hundreds of Euro worth and not heard a thing in over a week. https://www.plusmodel.cz/en/kontakt We are here for you is the moto........HA
  4. Some updates to the upper structure being plated. The bridge is going to a nightmare due to the complex curves and shapes. The front panels here are oversize so ignore windows not lining up. The underneath has complex framing and vent trunks to build. The bridge roof can't be installed for a while as I have to fitout the wheelhouse first, another big problem as the roof helps hold the form. Next the fan rooms being done, plating on roof ready for weld seams and the upstand is clearly seen, it is quite strong luckily. And finally the plating in the aft mooring decks and around stern door. The slots for Bulwark stays and stiffeners can be seen as well as the slots to locate the stair wall near forward end. Stern door, the square holes above door is for the stern door hinges. I am happy I pre primed though as the blow back painting into internal corners would be horrible and give a grainy finish.
  5. Thankyou, it's nice to get feedback on such a large project, some days you feel overwhelmed...
  6. I want to share this set of shots, copyright does apply to these. They show the vessel in typical condition with accurate colour. I have sized these down a lot from much higher res images.
  7. More plating, Port side getting close to completion. Today as the sun was going down through the door in the background the light hit the hull and wow the effect is there alright. Tomorrow night I will try to photograph it. its been hard work to plate like this but well worth it!. The arrow below delineates the extent of the double riveted seam forward, from that point forward it's a single row. The holes down low are the Fuel Oil Scuppers.
  8. It was always going to be, that's why I never refined it. I shaped it so the areas adjacent all come into that area nicely and I don't get a sudden change in the fairness of the surface. The plating is coming along nicely, these shots should give an idea of how its going to look, the distortion is subtle but there. The ones that look like they are lifting are taped on as placeholders If you look at the bow area above in the shiny bit you can see the ripples..
  9. I glued the Bow Bulwark on today after 2 days of fitting and 3 templates to get the thing to sit right, in the end I made spreaders to tack on deck at stay positions to hold the spread/flare, the part is not a continuation of hull but flares out ever so slightly more and its a very integral part of her forward beauty so needed to do it justice, anyway here it is glued on and the top 7" Bulb plate capping taped in place, I will glue this tomorrow so the Bulwark is far less prone to damage being only .5mm ply and all. also you can clearly see the 1mm Bulwark Stay locations in the deck plates, all in all it should be strong enough. A cropped shot of how it will look... hopefully I have also fitted aligned and glued the bow rudder into place with the bearings installed, all that needs to be done is the spaces in the rudder filled with balsa and the frame shaped to suit the bulbous bow forms by following of the frames of the rudder itself as the webs are taken off the bow rudder plan I posted earlier. The internal bearing at the tiller arm, it was planned for well in advance when cutting planks for hull. And finally I have machined the engine mounts and am ready to assemble and carefully glass these into place. The motors are bolted down into cradle by upper frames seen below.
  10. This is the best information source for the Ship and what happened to her. https://ndhadeliver.natlib.govt.nz/webarchive/20160417193035/http://www.thewahine.co.nz/
  11. This is a very short video about it, there are lots, but this sums it up as well as any, I have been interested in this ship my whole life and a friend of mine who was the captains Godson had an awesome website about it but it’s been removed as he Passed away a few years ago, I am trying to get the national archives to put it back up. But to sum it up the ship was approaching Wellington Harbour entrance in storm conditions which is fairly normal and was in a following sea with 7m waves and about 60-70-knots and heavy rain, as she entered the harbour entrance at 6.00am where you can’t turn due to rocks either side, at that exact moment 2 cyclones merged into a super cell right at the spot and with 275km winds she stated to lose steerage, she was going port to starboard 15 degrees off centre and at a point started to go to port even with the rudders hard to starboard. The sea had complete control of the vessel and the waves were 30m high, there are photos of them taken from ship and they are monstrous in size and the tops just being blown off the top like a horizontal white sheet of foam At this point she was pooped by a freak wave and broached to Starboard, as she righted she was side on to wind and sea, the conditions had dropped to zero visibility and the radar by this point failed due to water in the unit. The master made a bunch of movements by pure feeling which resulted in the ship successfully being turned almost back out but she was caught by another big wave and dropped on the reef tearing off one of her props and pushing one of the rudders into the hull, she dragged on the reef for a good hour and was extensively flooded, her draft increased 7 feet in this time and she lost all motive power as the engine room was one of the many compartments flooded. She ultimately got her anchors down and floated up the harbour, She was starting to list and roll from the free surface effect of water that was getting on her vehicle deck from the drains that were allowing the water below to come up on deck and could not be stopped, and she ultimately capsized about 1.00pm after all were off the ship, all those that perished did so in the water and on the rocks of the coast in mountainous surf. If you watch the video you can see the unmistakable rolling caused by free surface on the deck. This is super brief but it sums it up.
  12. She had both Bow and Stern thrusters, plus bow rudder, I never asked about it but I assume due to the very windy nature of her home port and very dangerous water she operated on. I do know the bow rudder was virtually never used. Her replacement the TEV Rangatira was built with 2 bow thrusters and no Bow rudder.
  13. I need to find more reference of a particular winch and windlass, in either photos or plans for my model The details I need are on the "plumbing of the 8 ton winches" Winch These are very hi res scans of part of a much bigger image of TEV Rangatira Seen here showing both. Same gear on TEV Rangatira I have partial plans of Windlass from the manufacturers archive but for steam conversion type. The 8 ton winch is a black hole apart from these photos.
  14. Yeah its not that uncommon in that period. Here is the plan. Also this plan is HUGE its 5 m long in reality and one of the hardest to read due to its condition, I had to restore it, I can read it but it was a challenge, you can see why the model is so accurate when you have all the units construction plans like this. A close-up, I left this large so you can save it and look at detail, not all model builders have seen plans like this for real.
  15. A shot of Wahine on launch day showing the gorgeous lines of the bow and the bow rudder.
  16. Some updates from yesterday. I always get excited when the bilge Keel and Bow Bulwark go on, it seems to define the hull in my eyes. The Bow rudder frame is laminated from 9 layers of .5mm ply, so VERY strong and rigid, next to it the radiused back wall of rudder space. now to cut the fore foot off the hull and build the rudder.
  17. I only need 90kgs of lead but some of that is casting cost, I am happy with price no need to be a scrooge about it.
  18. I have done some think this morning and am considering dropping the water ballast in favour for lead. I need to stiffen the ship up and need to lower the CG and I can only do this with lead as it is 11 times heavier than water for the same volume. yes its $500 of lead but is the stability of the model worth it....YES
  19. Next up is to do the bilge keel on the other side. I then have to laminate the frame for the bow rudder and have the arduous task of fitting and setting up the whole bow rudder arrangement. The lateral thrusters fore and aft have been fitted and are ready to be installed and I also have to make the rudder horns and rudders. The shaft bossing's will be made after I have built the engine mounts and glassed them into hull so I have the exact shaft centre inboard and a jig at rudders to keep the outboard centres, the A brackets carry very little load with my new design as the shaft which is nothing more than a 16mm dia 800mm long outer brass shaft with bronze bushes each end with the 8mm SS shaft carried through middle running from motor compartment all the way to the aft end of the A bracket. The A bracket just keeps it from vibrating but no longer needs to have bearings in it as it was last time. Then a large number of false discharges and intakes to do, about 160 2mm ones for various things like scuppers and valves and some larger ones that are 11mm for boiler intakes etc on ships side. once all this is done i can glue the topsides on and paint the lower hull in VHT red oxide. Question When making twin dagger type rudders does it matter if they are solid or should I make them from a frame and cover in 1mm ply? They are about 90mm deep and 55mm wide. Just not sure if light weight is an advantage with rudders given the servo etc. of course I could just make them from glassed balsa
  20. Getting the lower hull ready to laminate with glass. Seachests and bilge keel fitted. Hull finished and sanded ready for glass. Bilge keel is recessed 8mm into hull into a slot cut with saw attachment on Dremel and run along a batten screwed to hull. Grain run across width of Bilge Keel to keep it strong, it will also get 25 gram cloth glassed onto it. The most fussy thing here is getting the razor shape edge along the top where it flares out I don't want what should be a sharp edge to be at all round so feathered it out with scrapers etc. Full Size Shell Expansion to plot everything on shell, openings, discharges and weld beads.
  21. Ha, yeah I bet The answer is yes but its grown for the purpose of marine fitouts, many of the super yachts still use it although it's a 5mm veneer not solid so it goes further. Anyone can correct me if I am wrong but nowadays there are products to keep teak in good order instead of washing and scrubbing, and those that have it can afford to pay someone to look after it. The burmese teak is what they use nowadays still (Tectona Grandis). There is an alternative wood that has been used in place of it for several decades now and that is Iroko, its horrible stuff, we used some on a boat 20 years ago and its terrible to work, it also has dust that causes your throat to close, its very course grained and splintery stuff, it shares the oily nature of teak though which is why they use it. Mahogony depends what species, their are over 30 species of mahogany, but the one i think you are referring to is Brazilian mahogany or Swietenia Macrophylla its been the staple for guitar builders for centuries for necks and bodies. thier is also sepelle and many others which are still grown for the purpose but solid has become harder to get as veneer is seen as a better usage and less wasteful way of extracting the wood. In Australia we have a few identical looking timbers that are actually better, Queensland maple being the most common, its beautiful stuff and you cant tell the difference. here is a chair I made with it, as you can see it looks like Mahogony. Anyway I don't want to hijack this post.
