Lucius Molchany
Everything posted by Lucius Molchany
  1. Ok thanks for the tip.I will remember to try to stagger the planks on future builds.
  2. Finished with the ratlines and will now start work on the jibboom.
  3. Put the block in a 3rd hand alligaror clip.Then you wrap the rope around it and tie it off,Cannot slip off that way.
  4. Yes it is a good kit with nice wood.Look forward to see how you build it.
  5. Is it the old blue box number 440 kit?
  6. Yes the parts are thin but being wood they are more robust than plastic for sure!
  7. Tied on the second course on the main mast and will do the 3rd next.I also put the highest platform and flag pole.
  8. Thanks for the info .I will use your suggestions on future builds.
  9. Attached the blocks for the second course and tied up the ratlines.
  10. The doubling method for the shrouds was a good idea and I am pleased with the result.
  11. Yes both the Ersatzia and Vernon are tune up builds to learn the techniques necessary to build a major ship model.Mistakes made here can be pointed out and corrected on future builds and the end results are still excellent and impressive decirative objects that friends and family find mighty impressive!
  12. I consider the doubling method a success in making the shrouds look better.
  13. In order to thicken the shrouds,I obtained heavier thread and doubled the lines.seems to have worked pretty well without having to undo all of the work on the rat lines.
  14. Yes sir,that is exactly what i was doing with the billings wasa which i renamed ersatzia and the vernon before i invest in an expensive kit.
  15. Ok constructed the mizzen and wil tie on the woolings prior to installation.
  16. Wel I did have troUblE with the single planked hull and I should have carved blocks for the bowso the mistakes are my fault.I think a double planked hul may ha ve come out better.I ha ve to use my daughters old Samsung tablet to take pics because my laptop died.
