Everything posted by chris watton
Just been working away on my two new prototype (well, pre-prototypes) fishing boats. Thought I'd share some (bad) pics. They are now both double planked, with decks in place along with the bulwark timber frames. Nisha, the smaller vessel, has just had her gunwale fitted, with Erycina (the larger, ex cutter turned fishing ketch) about to have hers fitted. I have gone a little further with these, compared to the Fifie and Zulu, with the outer bulwarks pre cut and etched (as well as the inner bulwarks, which have the timberhead positions pre etched). So planking starts at just below deck level. They are also easier to plank. I note that some who built the Fifie and Zulu added detail below the main deck, so with these two, I have included the lower deck platform to the correct height, and included ladders for the companionways, if you wish to show companion door open. Pic not great, and builds are quick and a little rough but these, like my Sphinx pre-prototype are 'throw away' models, and used only to make sure designs work as they should, and change where required. The real prototypes will be made later, once I am happy the designs are nailed down, which is now pretty close. No varnish applied, and both have just been sanded, so look a little dusty. As with the Fifie and Zulu, they will have optional pre made sail sets, 4 for Nisha and 5 for Erycina. Oh, I used that flexible masking tape for the white boot topping, it was great!
A large part of that is down to James hatch, who has helped build the final prototypes and taken all pictures for the construction, plus text. This really does help with continuing new developments while that last one is still being worked on. Regarding larger kits in the future, today, this is one giant step closer, as I have ordered a second laser machine. This is not cheap, but I know it is exactly what I want, and I did promise that any money from sales is invested straight back into the business. The laser machine has a larger bed, so I can cut material of 800x600mm, rather than 600x400mm, and it is twice as powerful, being 80w. It is due for delivery in October, after the refurbishment of our garage next month, to make it into more of a proper unit that dilapidated hell hole.. On the Sphinx front, my wife, Chantelle and made up the 50 kits (that's a lot of boxes)! and now we wait for the printed manuals, plans and box label to arrive. I would have loved to have a full printed box for all my kits, but the costs are frankly comical, and no way worth it when considering they would add £100 to kit price! What Sphinx does have is a very strong double walled box, which will keep the parts safe during shipping. That, coupled with Chan's careful packing of the parts should ensure the kits arrive in perfect condition (We have learned a lot since our first Alert kit..)
I contract it to professionals. Anything that I am not comfortable with, or know that someone would do a much better job, I sub contract. Master carvings are very important, so the one off cost of getting a pro to do them is perfectly acceptable to me. I know well how to design the kits, but have never really tried my hand at real carvings. So Bristol carvings have already been paid for.
HMS Bristol, a sister to the later built Leopard, was to be my second kit in the range. However, things changed a lot after Alert. You see, I was going to have all my laser cutting done in Italy, using ply, MDF and limewood, and castings in white metal, again, all from Italy. When the fist Alert parts arrived, I knew immediately that this is not the way I want to go, looking forward. The laser cut lime was about as robust as tissue paper, and the white metal castings looked nothing like the masters I had made. This is when I decided to use much better materials for all future kits, and since then, I have been establishing more contacts for suppliers. This did mean I needed a rethink of immediate developments, and the decision to purchase my own laser machine, as sub contract costs would have been crippling for the type and amount of cutting I had in mind. The reason Bristol was put back is because the cost of the materials alone would have cleaned me out (at that time). The second reason is that I really need 2 laser machines before starting this, and one needs more power and a larger bed, for the thicker materials needed. I am now in a position where I could carry on with this, but my real love/yearning is for a large frigate before this. But all of Bristol's carvings have already been done, as is the armament, plus bulkheads, decks and all general hull lines already worked out.
Cheers! For the next big one (and it will be big), I am torn between three possibilities, and flit between them depending on mood.. I do know that next is two English West Country fishing vessels (and very pleasing lines they have, too), and then a medium sized kit of a detailed 18 gun brig (20 foot longer than Flirt/Speedy Class). Then, I have to make up my mind on the big kit.
Cheers! But I would like the same make as the one I have, as I have grown to know the machine intimately, and knowing how to prepare the files for laser cutting/engraving. A completely different machine will have different software requirements for the laser to read the files, and this could be a problem if I need to swap files from one machine to the other. They are not cheap, but it has not let me down once, the only ongoing expense being the extractor filters (and many cans of Mr.Muscle oven cleaner to clean the bed...)
OK, we have released the final 5 Sphinx kits to stock. Once these are gone, that is it for this production run. I will not be able to get more PE until next month at the earliest, as Italy is now on holiday. And I thought I had enough to last a while! I think I have already mentioned this, but the photo etched sheets were changed at the very last minute to include all PE part numbers etched on the sheet, which should make identification easier..
Never asked my supplier, all I ask for is pear, and also ask for it to be good quality, so no idea about swiss/unswiss - but am sure I will now you have asked. I have actually sent a batch or two back, as they are awful.. Most of time what I get is pinkish, but for the planking, I did ask for a lighter tone in my last batch. I cannot always guarantee this, as I get what I am sent, which is the way for a natural product. I would prefer the very light pear every time, as to me, it looks perfect on 18th Century subjects, but I also know most of the time, I get the pinkish colour. What I do know for sure is that I desperately need another larger, more powerful laser machine, and soon!
Have sold 39, so 11 left - but these were originally kept back for trade (35 for direct sales and 15 for trade ). However, I am releasing the rest of what I have left and will do another batch as soon as I can. Already ordered another batch of PE. Looks like I will be living in the laser room for a while, not that I mind! So, today, I will finish laser cutting another 4 Speedy Master Shipwright kits, and then back onto Sphinx laser cutting. The laser cutting is the main reason I could no longer have the two jobs...
Thank you Regarding parts, I am not sure, never counted them all up. You can however download the manual on the Sphinx page on my site: HMS Sphinx – 1775 – VANGUARD MODELS The full parts list is near the end. As for sails, I honestly haven't really given them much thought, as I prefer the models 'Dockyard Style', with just masts, yards and rigging. I include sail options for smaller kits, as I can appreciate many prefer to have the choice, and they seem to suit smaller craft.
- 355 replies
- vanguard models
- Sphinx
I would say it is a kit most could build. BUT, they need to take their time at every stage and not rush anything. The batch of 0.8x4mm pear strip I ordered for these kits is the best I have seen, nice and light, too, so will look fantastic under the blue and gold upper works. If I were building it again, I would use the planking under the upper half of the pre etched and cut sides.
I am stunned, thank you all for your support. I never thought I would sell so many. I did enough for 50 in total, as I always order 50 PE sets (which weigh in at 20kg for Sphinx). But castings, thread and anything else non PE and laser cut, I ordered 100 kits worth. I will add a couple more to stock, but damn, thank you! I have put in a repeat order for the photo etched sets, and will start another production run of laser cut parts, each kit takes well over 6 hours cutting/engraving time.. And again, thank you!
I always use a length of 0.8mm ply, about an inch or so wide with sand paper wrapped around it to sand the bulkheads. I find this works really well as I it is flexible enough to bend and sand all edges it comes into contact with (both convex and concave). I usually sand until most of the laser char is removed.
- 345 replies
- Duchess Of Kingston
- Vanguard Models
No, it's a nightmare right now, I only have the smallest of surfaces left to do work on my two new developments, a little corner of the dining room table! Luckily, the two I am working on are quite small, as you can see in these pics of Nisha, the smallest! We have had a quote from some builders to convert our large double garage into a proper unit. Supposed to start this next month, but knowing builders, they probably won't show up... I have ordered more materials (pear sheet) to make a new batch of kits in October/November time
