Posts posted by Sergey Karelia
Good job and serious plans! I think 4 mm will be big too.
I tried these, but I put 2.5 mm single block and 3 mm double block, since the hooks also reduce the distance to the eye bolt. especially on the moving part of the carriage.
you have a good build for the first job!
of course there are minuses, the main thing is not to lose motivation and finish the model. and then you will build the next ship
2 hours ago, abelson said:
I also made the faux sheave for “Top Rope.” I have not found the Top Rope that passes through this sheave anywhere on the plans. If anyone knows what this is, please feel free to let me know
This is yard rope (if I understood the question correctly)
I didn't put all the blocks from the drawing, because I don't plan to set sail and some blocks will remain empty
Good time! And what is this?
I was building a spray, I don't remember such an element. I did cabin interiors and lighting.
I still have a few photos of this model. The ship is far away from me now. An old friend of mine started building it as a child, but he couldn't finish it. For thirty years the ship lay in a forgotten shed. I completed it and returned it to a friend. photos of the initial state and the finished ship are attached.
(light switch button - galley pipe)
- Gabek and modeller_masa
- 2
the ship is amazing in beauty and detail! you are lucky to have such a set
I saw it here:
http://www.chez-xandra.eu/publ/16
does anyone have examples of Blue Shadow builds? to strive for
- thibaultron and Mr Whippy
- 2
i suspended work on Niagara. moved to another topic
Blue Shadow Mamoli - - Kit build logs for subjects built from 1751 - 1800 - Model Ship World™
About 10 years ago, I assembled a Blue Shadow model from MAMOLI.
Then I had few skills and collected everything according to the instructions. The model turned out to be childishly naive, but cute. Mainly due to the rich rigging.
Two years ago, I replaced all the rigging with threads of my own twisting, as the threads from the set were covered with dust and began to look not presentable. And he gave this ship to his colleague.
For better preservation, I made a showcase, but it did not fit into the interior of my friend and he took it off. And it so happened that the children dropped the model. The results of the crash are in the photo. Now I have to put Niagara aside and do the restoration of Blue Shadow.
I'm thinking of making the model better than it was. There is a lot of work to be done:
- I've already cut all the rigging. Completely;
- I will clear the deck, the deck will need to be cleaned of varnish and brought to the same color, I will add imitation nagels;
- I will make a new becket, a pump, make a minimum strapping of guns, modify anchors, replace channels and yufers and blocks (I will make smaller);
- maybe I'll add something else.thus, for the third time I take up this model
- Paul Le Wol, Mr Whippy, AiDi and 2 others
- 5
if you put the shrouds individually (at the end of each loop, pic 1), then do not glue the mast, topmast and stengabram-topmast together.
if the shrouds are paired, then you can glue (pic 2)
do not forget about the gap between the mast parts, so that you can then carry out the rigging
and have a good build!
Spoiler
a good start!
on this scale, it is better to show the layout of the deck board and imitation nails
I didn't make an imitation at the time and I regret it now
this was my second model (Pinta) without deviations according to the instructions
I would do a lot of things differently now
the photo shows that there are no these small details and that's bad
- KurtH, GrandpaPhil, Louie da fly and 3 others
- 5
- 1
on the advice of an expert, I omitted davit cleat
I didn't take a photo, maybe tomorrow
US Brig Niagara by Abelson - Model Shipways - 3/16" scale
thanks I'll do this
