Posts posted by Isaiah
Can I just add a hook to the block and loop the line through the block and up again? Then just hook the block to the boat?
Looking good Ferrus, You sure know a lot more about ships than me.
I’m very soon going to start making the masts on my Perseverance which means rigging is coming up. Going to need a lot of advice because I don’t know what the heck I’m doing.
- Ferrus Manus and Bill97
- 2
- Ferrus Manus and ccoyle
- 2
- ccoyle, Ryland Craze and GrandpaPhil
- 3
Here’s the link to the types of model boats: https://vanguardmodels.co.uk/product/ships-boats-various-types/
I think it’s a yawl but tell me what you think. I’ll add four ores.
I like that black line around the top of the hull so I might add that as well.
- Chook, GrandpaPhil and Ferrus Manus
- 3
I’ll have to think about it, oars do sound good I just don’t have any included in the kit but I can certainly make some.
the second boat, a little bigger, came out much better. I used a different technique, gluing the hull as one piece before shaping it. I used a bench top drum sander and a dremel. I almost don’t need putty.
Just going to shape the third one and then paint them both.
33 minutes ago, Ferrus Manus said:
I'd certainly like to see the finished paint jobs on the boats. If you want, you can lash a mast/spar/rigging down onto the boats, as they would've had them, especially the larger ones.
What do you mean by lash a spar?
they get tied down to the ship if that’s what you mean.
I don’t think I could’ve painted the lamp as good as that.
nice job.
- ccoyle and GrandpaPhil
- 2
I might try the putty again but with the top plywood piece, it’ll give the putty more stability and hopefully won’t chip off.
One of the Boats half assembled with a coat of primer.
as you can see there’s a few chips on the edges. The hull is made of three pieces of ply wood that requires shaping. I broke nearly every piece which I had to super glue.
This was quite a difficult task and didn’t turn out as good as I hoped. If you have any suggestions on how to patch up the hull please let me know. I tried wood putty but it just breaks off.
I was going to just glue the top piece with the thwarts ( I think that’s what they’re called) and then try to fill the gaps.
- GrandpaPhil and Ferrus Manus
- 2
4 minutes ago, Ferrus Manus said:
Oh, so you finished the ship? Why don't you post the images!
No no, this is a photo from the website I bought the model from, not my ship.
Good to know.
I will call them boats for now until I find out what they are actually called.
Yes I shouldn’t have called them life boats, I didn’t I know what the specific names for them were. I know the one hanging off the stern is a Jolly boat, used for transporting crew to and from shore, but I don’t know what the other two are called. The manual just calls the other two “boats.”
And why are the crane things called a cat head? 🤔
Looking good, such neat work.
- GrandpaPhil and ccoyle
- 2
1 hour ago, Ferrus Manus said:
I added my follow. I am 18 years old, and have been building model ships since i was 14. It's wonderful to see people like me in the hobby. I started out on, and am still doing, plastic ships. The SR-71 is also one of my favorite aircraft!
I just had a look at some of your work, looks very nice. Is that Spanish galleon plastic because if it is you’ve done a great job to make it look like wood. 👍
On 5/22/2023 at 3:38 PM, Dr PR said:
Isaiah,
Very nice work, especially for a first build! I don't know how you managed to bend the walnut around the tuck at the stern! Most experienced modelers do not consider walnut to be a good wood to work with because it is so brittle and splits!
As far as I can tell the only thing wrong you are doing is worrying about doing it wrong!
Thanks for the kind words.
I used mahogany for the second layer planking, but it’s still just as brittle as walnut. I don’t know how I managed to do it to be honest. It was the most challenging part for me.
- RossR and Ferrus Manus
- 2
I know I’ve messed this log up by posting all the photos in one post because I have no clue what I’m doing.
I am thinking of making a new build log and starting again, but then it might be too confusing.
I don’t know, please let me know if I should make a new one or just leave it as it is.
Perseverance 1807 by Isaiah - FINISHED - Modellers Shipyard - Colonial Brig
Ok I think I know what you mean. The eyebolt is in the right spot according to the manual, I guess I listen to the instructions too much.
