Posts posted by Isaiah
- mugje, Pitan, GrandpaPhil and 3 others
- 6
2 hours ago, Pitan said:
That looks like nice progress, Isaiah.
That hull should be nice and straight by now?The hull had a slight twist along the length. I’ve currently got it under tension while the glue around all the bulkheads dries. Should work.
- Pitan and GrandpaPhil
- 2
- chris watton, CiscoH, rcweir and 6 others
- 9
- Ferrus Manus, wvdhee, Thukydides and 4 others
- 7
Good to know, as long as you’re improving that’s the most important thing.
Good to know, most other kits I’ve seen require keeping the keel straight while planking. Glad I won’t need it then.
- Knocklouder and Mr Whippy
- 2
Hi Simon, great work so far. I hope you don’t mind me giving a little criticism.
I would personally suggest redoing the ratlines. They are currently not a uniform taper from top to bottom. I know it would be very annoying and a big step back, but it would be very worth it in the end.
I hope you don’t take this the wrong way, I just felt I had to tell you this as the rest of your build is really good. It would be a shame for you to build such an amazing model, only to be let down by the ratlines.
Kind regards,
Isaiah
1 hour ago, Pitan said:
p.s. While you are replacing stuff, have a look at the belaying pins, see what you think.
What would you say’s wrong with the pins? Are they too small?
I stand to be corrected, but, I thought Vanguard uses Ropes of Scale?
Though the supplied standing rigging is black in this kit, and you may want brown?
I’m following your build as well.
It’s not Ropes of Scale. I think it might be Amati cord. Ropes of scale rope only comes in 6 metre lengths.Good point about the standing rigging. Coal or black tar came much later so brown or pine tar would be better.
Pretty late here but anytime a blade or mill passes out the back of your wood piece there will almost always be tear out.
Using masking tape or duct tape at the end of the cut or really anywhere the surface is exposed to the blade. helps quite a bit. Clamping a sacrificial piece of wood on the end also helps.
And I also bought the fore and aft rigging book by Lennarth Petersson.
Yes I would, even though I want it to be accurate, I’m going to focus more on making a good looking build. I don’t mean compromise accuracy, obviously I’ll try my best to have both worlds.
- Mr Whippy and Ferrus Manus
- 2
I like how Thukydides organised his log so I’m copying his. You will be able to easily find any part of the build.
Table of contents
Pre-buildingLog #1: research and preparation
Hull ConstructionLog #3: Frame assembly
Log #4: Transom, Fairing and KeelLog #7: First layer planks - pt 2
Log #8: Finishing and sanding first layer planking
Log #1: Research and preparation
This is the start of the Sherbourne build log, the kit won’t be arriving for another 2-3 weeks but anything that I should be aware of or extra parts I should get please let me know.
I will be replacing all rope with
Ropes of Scale and the kit blocks with Syren blocks. I will also get thimble blocks from Syren for the backstays.
I don’t have an airbrush and I don’t like the idea of using spray paint for the hull.
I just bought white acrylic paint so what I might do is only use spray paint as a base coat, then apply a thinned down white acrylic.
I’m already thinking about gun tackles and I know I’ll need at least 2mm blocks.
I don’t think there’s really any available though. Only Vanguards blocks but they’ll be different to Syren blocks. Will I just have to make them?
- Ferrus Manus, Lee Spender, Pitan and 6 others
- 9
4 hours ago, Ferrus Manus said:
The plan shown was not my own. It was a representation of what I wanted my bow to look like. I redesigned my own bow to reflect the online image. That picture is likely a photocopy, my designs are all drawn on paper with pencil. Go back and look at the original side profile of the boat. I hope that answers your question.
Ok gotcha.
- Keith Black, Ferrus Manus and mtaylor
- 3
I’m just confused because the plan before your drawing has a straight bow, but then you said you’re redesigning to make a straight bow?
- Keith Black and Ferrus Manus
- 2
I thought the first drawing already has a straight bow? Me the beginner is confused.
- 3
Thank you all for the compliments, I’ve just ordered the Sherbourne so I’ll be starting that as soon as it arrives!
- Coyote_6 and Ferrus Manus
- 2
Glad it’s useful for others as well. Once I made this jig I made about 40 of them in just a few hours.
- Scottish Guy, mtaylor, Keith Black and 2 others
- 5
1 hour ago, Knocklouder said:
Wow, very impressive. I am going to start making rope coils like yours very nice.
Congratulations on some very nice work.
Bob M.
Thanks Bob, I got the idea from this video Here.
14 minutes ago, Thukydides said:
Great job. You should be proud of her.
Do you have plans for what you want to do next?
Most likely the Sherbourne from Vanguard, I’ll be purchasing it shortly if no other ideas arise.
HM Armed Cutter Sherbourne 1763 by Isaiah - Vanguard models - 1:64
Posted · Edited by Isaiah
Log #5: bulwarks
Bulwarks bent and glued, ready for planking.
I made this jig to bend the bulwarks to the exact radius. I used the top deck piece as a template.
