Everything posted by Der Alte Rentner
I chime in with Gregg in recommending Modeler's Sawmill. I just received my third batch of wood from him, and I'm very pleased with the quality of the milling. Dimensions are spot on. As mentioned in my own build log, I wish I'd known (or even had an inkling) about replacing the subpar materials supplied with the kit when I started. Coulda, woulda, shoulda..
What went fairly smoothly on Wednesday, was a PITA today. I did knock off the two remaining mast partners, and cut the tenons at the bottom of the main and mizzen masts. This time, I took a short cut. Rather than place the mast partners where Hunt said to put them, I glued a piece of scrap wood to the underside of the framework between the bulkheads and more or less tacked it in position to nail the rake angle. Once that was done, I glued the cross members to the fore and aft framing. The masts now fit like a glove, and all sit at their correct respective angles/rakes. Then things went south. In keeping with the process I used to on the fore mast, I built a jig for the main mast, cut the fore and aft faces at the top to precisely 5/16", rotated the mast, and milled the sides. I have no idea how this happened, but these two faces ended up being 9/32" instead of the required 5/16". To boot, I lost track of where the shelf between the round portion of the mast met the squared off section needed to be, resulting in a 3/16" gouge on the starboard side of the mast. To fix this, I glued some scrap basswood to that side of the mast, trimmed away the excess and recut the offending face to net the correct thickness. Long winded way of saying, two steps forward, one step back? I did learn that I didn't need the jig to square off the top 1/4" of the mast. The vices with the Proxxon mill are short enough that I could simply clamp the square section down and mill away. I am quickly learning to convert fractions to metric in my head. And again, by going through this process now, I'm a leg up on Chapter 1 of Rigging the Constitution, when I finally get there.. Fore mast still needs a slight adjustment where the round part meets the square section to allow for the 3 degree rake. But the main mast is done. I just received the boxwood planking from Modeler's Sawmill. So to get a sense of where the next steps are heading, I staged the hull.. When I see the contrast between the boxwood and basswood, I really regret that I didn't know at the start to buy better materials.
Since, I'm waiting for box wood for the deck planking to arrive from Modeler's Sawmill, I took a small diversion to prove the concept outlined above by finishing the top of the fore mast. a. I marked the relevant dimensions on the face of my jig and mounted it to the table of my Proxxon mill. b. Then lowered the mill to be flush with the surface of the jig. c. Proved to myself that the math and the setup was correct. d. Milled the front and back face of the fore mast to net parallel sides 9/32" thick. I had to place a shim under the cut out section of the mast before milling the opposite side. The dowel material warped a bit with the first cut, so I had to prop that up. e. To get the other two faces milled, I rotated the mast 90 degrees and secured it in place with shims. Again, on the second pass, I had to place a shim under the previously trimmed side to support the mast while cutting the last face. I repeated the steps above to shave 1/32" off all four sides to net the 7/32" square notch for the mast caps. Some tweaking with a chisel was required afterwards to attain the 3 degree angled shelf for the mast caps to rest on. I did not glue these in place. f. The finished product. g. Test fitted the mast on Conny. Looking good, I think. a I'll probably repeat this process for the main and mizzen masts when dealing with their respective mast partners. I'll be a leg up when I get to Chapter 1 of Hunt's Rigging the Constitution - (next June?).
Hallo Nils, I noticed you looking in on Mtbediz's USS Constitution scratch build. Digging into your build list, I discovered your Gorch Foch. Ausgezeichnet! I too am working on the USS Constitution, my first build, but I have always wanted to build the Gorch Foch - or rather her sister ship, the Horst Wessel, which I believe is now the US Coast Guard cutter Eagle. My father told me that he spent six weeks aboard the Horst Wessel when he joined the Kriegsmarine in 1936. It's a long story, but the bottom line is that his experience during that time ultimately brought us to the United States. So, there's sort of a personal connection for me with this ship. It may take me another two years to finish the Constitution, but you have inspired me to tackle the Gorch Foch next! Vielen Dank Peter
- 222 replies
- gorch fock
- barque
Oooh! I hope I remember this when it comes time to finish up the masts. - from XKen's build. In looking at the Hunt's Rigging the Constitution Chapter 1, I was dreading the thought of building the "chafing fish" out of Styrene. It appears that I won't have to! June 20, Hmmm Upon further reflection, and having just spent some quality time working with 1/16" x 3/32" planking as I begin spar deck planking, I'm wondering what tools or method XKen employed to achieve those clean angles "to match 90 degree surface". I can't think of any way to hold or clamp a strip to be able to cut a precise angle.
Before beginning deck planking, some housekeeping is required - namely the construction of the mast partners. I started with the foremast: a. Set the belt sander at 97 degrees to facilitate a 3 degree tilt as specified on page 6 of the plans. b. Mark the sander table with reference lines perpendicular to the belt itself. c. The lines are skewed to compensate for a poorly built belt sander. d. Sand the bottom of the mast. e. Use the Proxxon mill to create a 1/4" wide tenon in the center of the mast. With a little bit of math, and by carefully zeroing out the gauges on the Proxxon's X and Y handwheels, I was able to very accurately cut the tenon. A chisel was used to remove the rounded inside edge of the tenon. note: the belt sander left very noticeable sanding marks, which I used to eye-ball the piece vertically in the Proxxon vice. f. Correcting my error in not referring to the plan (I relied on the dimensions provided in the practicum), I added 1/32" shims to the mast partner opening for the foremast. This was necessary to accommodate the 3/8" mast diameter specified in the plan. Hunt had his students use 7/16" dowel. Does it matter? you may well ask.. It does, because the mast boot for the foremast has an inside diameter of 3/8". The 7/16" inside diameter boot is for the main mast. g. As luck would have it, the mast fit perfectly, right down to the 3 degree rake aft. There's no photo, but I did cut a paper template, per Hunt's suggestion, to verify the result. Working on the bottom end of the mast got me thinking about the 'rest of the story'. So, I looked ahead to Hunt's Rigging The Constitution, Chapter 1, to see what the top portion of the mast needed to look like. That left me wondering how best to carve that end of the mast down to 9/32" square at the other end. That in turn needed to be properly oriented with the tenon. So, I built a little jig to lock the mast's tenon end in on one side. The height of the channel to hold the mast in place was dimensioned such that I could use a flat chisel to shave off the right amount on each side to net two 9/32" parallel sides. I'll either find a way to attach the fixture to the Proxxon mill to cut the other two faces, or build another jig. For what it's worth, the jig only took a few minutes to construct out of scrap material lying around in my shop. My thickness drum sander came in handy to dial in the correct height. The hardest part was doing the math. 😉
Funny you should ask, Geoff. I didn't spend much time at the shipyard yesterday, but I did manage to mask the small error of sanding away the detail on those laser-cut hatches. Very light application of pecan gel stain. Not much else to say. Here's the evidence. and today, Wednesday June 5, after delays to to shipyard A/C going down, I finished the last of the hatch coamings. That last one was a royal PITA. The joinery came undone twice (super glue isn't that "super" on miter joint?) But it's done. Mast tenons and planking up next..
What I like about the Gorilla Glue product is the squeeze button on top (or two on the sides of the non-gel version). Let me know how squeezing these little tubes works for you - even with those syringe style tips attached. I get quite a bit of mileage out of one container. I believe I've only purchased three in a year, and I just started the 3rd one.
Especially when it came to masking over the eyebrow.. How you got such a fine straight line over the eyebrow is amazing - in and of itself. Part of the reason I don't want to paint Connie, is that I don't think I can manage a paintbrush well enough to do a decent job - not just the straight lines, but on the intricate work on the scroll work. Your build is looking good, looking forward to your coming back to it. No rush though, wait for me to catch up 😁
Thanks Geoff. I went to the shipyard this morning intending to start the main hatch. After a quick peek at the practicum, I was ready, willing and able to take the easy route by not cutting up the pre-fab laser cut grate provided in the kit. When I took a closer look at that large grate and how it would look in the coamings, I realized I probably should not have sanded the other grates smooth. Furthermore, I it dawned on me that these grates had a top and bottom side. Now that I know which side is up, I'll have to make sure I retain the detail in grate for the main hatch, which could be lost if I over sand. Live and learn.. By the way, how goes the rigging? and lastly, I checked out your Armed Virginia Sloop in the Gallery. Very nice!
Doing some research at the site to see how folks are dealing with hatch coamings, which I wish I'd done a little bit sooner. Seems as thought I should NOT have sanded the top side of the grates. But I digress. Too late for me, but I wish I'd thought about cutting the waterway to fit the cathead instead of the other way around. I haven't looked at your build in a while, but as I get further along in my build, that will change.
After a week's downtime, due in part to a pit bull attack, and exacerbated by a power failure that took my shipyard off line, I returned to work this morning and knocked off the galley stack hatch. (Chapter 4.3.4, if you're following along with the Hunt practicum.) As with the previous hatches, I found it easier to work with mitered corners than the lap joinery Hunt used. I realized after I was finished that I didn't need to produce another coaming piece. I could simply have used the same material I used to make the basic box, and filled the space under the planks on the stack side of the coaming with a slightly smaller filler block. Oh well.. I like the idea of the filler block because it made easy work of planking the stack end of the hatch. I just applied glue to five sides of the block and shoved it into the opening from the bottom. My router table was still setup from fabricating the strips I made for the two forward hatch coaming, so it took less than a minute to make the blank for the center piece. For that 1/32" overlap, I used the Proxxon mill to cut out the notch. Once the stack hatch coaming was assembled, I reduced the height of the stack side of the coaming by milling away 1/32". I little trimming here, a little sanding there, and viola, galley stack hatch done. Cutting the notch. Gally Stack Hatch Coaming from the bottom. Note the filler block below the coaming. I realized afterwards that I used 5 planks (3.2mm each) instead of the 7 Hunt used. Not worth it to me to correct that error.
whatever floats your boat.. Great fit! As I approach that part of the build where I need to fabricate and (dry) fit the mast, I may be coming around to your line of thinking when it comes to the tenons at the bottoms. I experimented with carving a tenon one end of a dowel and was not thrilled with the result. Even if the tenon is flush-mounted and reinforced with a nail after I test the fit, the method your brain preferred may indeed be the better option.
I am struggling to find the right word to describe the asymmetry between the port side and starboard side curves for the deck on the bulkheads. Camber? I had to shim up a couple of bulkheads so that there wouldn't be peaks or valleys when it came time to plank the deck. Checking the photo from above in post 170, I can see that the worst offenders were bulkheads D and P. Those needed to be to shimmed up on the port side of both. For bulkheads A and C, It seems that I trimmed the Starboard sides. I believe I laid planks on top of the bulkheads to find the high and low spots and/or asymmetry before trimming or adding to these four bulkheads. Hope that helps.
Der Alte Rentner replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
Thank you my friend. I have very useful machines, they make my job easier. Even with machines, I can't produce as quickly as you. If doesn't help that my shipyard has been without power for nearly a week.. As always, your workmanship and productivity impress. -
(Quoting myself..) I decided not to wait on the zero clearance rings for my router table. As it turns out, they weren't needed. Milling the hatch coamings was relatively easy using existing machinery - Delta Thickness sander, Wood Pecker router table, and Proxxon mini table saw. 1. I had some scrap 1/4" basswood sheet and used my thickness drum sander to work that down to 5/32". 2. Set up my router table with a bit height of 1/32". Used my Incra fence to dial in the distances for the rabbets. Easily done with this tool! Once zeroed out to the sacrificial fence, I could set the fence to 1/16", 1/8" and 3/16" rabbet depths. 3. Cut rabbets on both sides of the board. It was easier to do this with the board wide, as opposed to dimensioning the boards first, then cutting the rabbets. 4. Marked the heights on the boards (old school method - ruler and pencil) and 5. Cut to the line on the Proxxon table saw - the least easy tool to set up. Because I couldn't get the precision I desired across multiple cuts, I 6. Revisited the thickness drum sander to nail the coaming heights. As narrow as these coamings are, they nevertheless stayed vertical on their way through the drum sander. (sorry, no pictures of that machine here.) NOTE: I removed material from the bottom of the strips, so as not to mess with the depths of the rabbets. 7. Fabricated two hatch coamings - the one forward of the foremast, and the one that abuts the bowsprit. Note: I found the business of making lap joints tedious and opted for miter joints instead. Power tools were of no particular help in their construction, except the belt sander did make shaping the forward part of the bowsprit coaming easier to trim and shape. Hobby miter box and saw were the tools du jour. (I didn't bother marking all the dimension on this sketch. The grid represent 1/32" squares. The dimensions (after double checking) came from Bob Hunt's practicum. Chapter 4. Rather than start another entry for these two hatch coamings, I added the photo to this post.
I am so sorry that my innocent comment initiated such consternation. I only mentioned the scale issue as an aside. My apologies to you good sir. -
Hi there Mustafa. While perusing your earliest posts (I wanted to see what scale you were using to construct your Constitution), I saw that in a reply to me in your post #3, you added the photos you used in post #340 above in your reply to Greg about how you built your ladders. Just an FYI. (I don't know why, and this is why I checked your scale in post #1, but your photos make your Conny seem much larger than mine). -
Just venting today.. While I ponder finishing options, I began working on the spar deck and hatch coamings. Thankfully, I double checked everything in the practicum before committing too much material and time to this phase of the build. 1. Hunt's instructions are to cut the foremast from 7/16" dowel and to make the opening in its mast partner to fit that diameter stock. The plans call for 3/8" inch, and the laser cut mast boot is likewise sized for a 3/8" foremast. 2. Hunt's instructions provide distances from the center line for the hatch coaming framework. There were several discrepancies there, as compared to the plans - most notably the dimension for the framework between bulkheads D and E. (my take? Trust, but verify.) 3. Adding another Practicum observation (May 20) for the benefit of anyone following Hunt's directions for constructing hatch comings. On pages 19 and 20 in Chapter 4, Mr. Hunt provides detailed instructions for fabricating the material needed for the coamings. Likewise on page 40 for the main hatch. He glues up three pieces of stock for each coaming. To boot, for the shorter coamings, because the kit didn't come with 3/32"x7/32" stock, he trims a piece of 3/32"x1/2" stock for the center piece. All well and good. But on page 26, where he shows the parts of the coaming in photo (P4.3.1-1), he says he I think I'll go the milling route myself. (I sure hope the zero clearance ring for my router table arrives soon. That will allow me to easily mill the material myself.) 4. Once again, the materials provided with the Model Shipways kit disappoint. All the dowels for the masts (5/6", 3/8" and 7/16") are misshapen - the 3/8" piece is completely warped. Were I to go ahead with the 7/16" dowel for the foremast, there wasn't enough material provided to then be able to construct the main mast. The dowels are all different colors ranging from near white to mahogany. Also, there wasn't enough 3/32" x 1/4" stock to complete the hatch coaming framework. Last but not least, the material for the deck planking is off by as much as a 64" inch in width and thickness. Having spent much time reviewing Cookster's 2013 build log for the spar deck and coamings (wow!), I've decided not to mess around with cruddy materials going forward. Even if I paint every thing later, I'm going to give myself better options by ordering replacement material from Modeler's Sawmill. (and before you ask, no, I'm not going to waste my time contacting Model Expo, where I bought the kit. I'm still waiting on the replacement material for the hull planking they said they were sending on December 1 of 2023. (Ticket #22286: replacement stock for USS Constitution kit)) Not sure where I'll invest my energy while I await material delivery. Maybe start the side galleries? Or take advantage of the nice weather?
I'll add my voice to those concerned about your health and well being. Loved your build log on the Model Shipways Constitution, and was sorry to see you stopped posting - hmmm, that was about the time you started this build.. Your workmanship and attention to detail are outstanding. Hope to hear from you soon'. Best Peter
