BrochBoating
Everything posted by BrochBoating
  1. Apologies that this build log didn't get completed properly. However I've completed (for me) Trial today. Compared to many of you it's amateurish but I've enjoyed what I've done and I'm pleased with my improvement over the last kit. Summer brings more swimming, snorkelling and horse riding but Nisha should be along shortly and I'm sure another log of one length or another. Thanks for all your comments along the way, always appreciated.
  2. Thanks Andrew, much appreciated compared to your work. We seem to be suffering a similar pattern of a furry loss and health problems but I'm hoping to be back at the bench shortly too. Good luck
  3. Sorry for your loss Andrew but very glad you're on the way back to health. Maybe we'll both get our builds finished before long?
  4. In that case I'd say, if you can, try something else. You will have learnt from this one but it's not worked out and I think that will colour any attempt at salvage. Yes, it can be done, but maybe a bit further down your journey. Personally I think better to chalk it up to experience and try another. Please do though
  5. Hi Micha, How did you get on. I'd echo a comment above and ask if, from the outside of the hull are you happy with the flow and look of the planking? If you are then I'd shape those ribs to fit. If not the taking the planking off may be the way to go if you have enough stock to start from scratch. Depending on how much and which CA you used it may be quit brittle and able to be carefully pulled off from one end. Possibly with the help of a plastic spudger for some leverage? Good luck, Simon.
  6. It's definitely been a week for being outside up here. Garden work maybe not so much fun!
  7. Excuse the newbie ignorance but I assume that is another forum? Again as a newbie to the hobby I can't imagine (other than insecurity and jealousy( what folk can say negatively about your work. Having looked at a lot of kits before moving on from my first (admittedly online) the only kits I really wanted to try were yours and Vanguards. On all of the build logs here it comes across so strongly how high the quality of both your kits are to give any stage of modeller the very best chance of making something stunning. Yes they are expensive but you get what you pay for in most areas and this is definitely one. Good luck to you!
  8. A little more progress with the start of rigging. Slow and steady, trying to keep an eye on where both arms and hands are at all times! The liquid CA on the end of thread trick really comes into its own now. That and using clips to apply just a little weight to try and create the right, minimal, tension when needed.
  9. Not for everyone they're not. Micha I rapidly came to the conclusion that a great deal of kits are junk which haven't been invested in for years, often decades. Modern kits are entirely different but few and far between.
  10. So that's the starboard side finished too. No, not perfect but an improvement on the port side and a huge improvement over my last model so I'm happy with that.
  11. Excellent review, thanks. Are Mamod really that much now! Awful when they were cheapish!
  12. Absolutely no need. The Vanguard system makes jigs etc. superfluous.
  13. Thanks Isiah. As I said in the text the port side is uneven but a change I made when I did the starboard side improved this greatly. If you look a little further up you'll see the improvement from my last model and I'm very happy with that. I've learnt on this one and I'll learn more next time too.
  14. That side is crewed by very small people It is narrow. I'm hoping the other side is better but I suspect the real key was getting the shrouds more spaced at the top to begin with.
  15. Port side rat lines finished. Somewhat salvaged by using clips at the top as discovered for the starboard side so not as bad as thought might be the case. The lined paper wasn't used for spacing in the end, the scrap plank did that, but I found having it place helped stop the shrouds twisting around. Clipping one side of the two clamped planks to the paper helped this too. Can't clip both ends to the paper or there's not enough movement behind the shrouds to easily get thread through and back with help of tweezers. The kink towards the stern looks much worse than it actually is. Next to finish the starboard side.
  16. It's a Brexit bonus Seen a few Spanish modelling companies won't ship direct to UK, I imagine not worth the hassle now. When there's stock Cornwall Model Boats sell them and are good to deal with.
  17. This is why companies can sell mesh wifi for many times the cost of a wireless router and a few cheap AP'S that do the same thing.
  18. Unfortunately the build out for this is a long way off a lot people, me included. Maybe next year if Openreach stick to their plan, they've changed whether they will or won't before. Anyhoo I think in many case lack of internet is often a lack of wifi. In a lot of peoples minds internet & wifi are the same thing. Relying on the often woeful router/AP provided by the service provider is usually the problem.
  19. Add the page(s) to your Reading List in Safari then you can set them to save for offline viewing.
  20. Lower half of starboard side done and much better than port side as used a hairclip to hold shrouds spacing at the top.
  21. Thanks Chris I'll add them to the list. Happy to spend for quality tools but knowing what is quality can be hard.
  22. Thanks. I can't claim the thought unfortunately it's just a simpler adaptation (and lighter) of this thread. It is working very well though. Here's my first effort on the last boat. I'm stuck on this. On one hand I totally agree. On the other I worry about them coming loose as I go along. Thank you. A long way to go but I'm pleased with the improvements on this one so far. I've got about half of the port side done this morning before my back told me to stop. I use a fresh from the pack safety razor to trim with a very light pressure on the excess and even more gentle wipe of the blade over the joint. I found even a craft knife isn't close to being sharp enough for this.
