Jasseji
Everything posted by Jasseji
  1. Agreed on @myxyzptlyk2003 comment here, i got one of the small boats from you as a warm-up before i even ordered the Sphinx kit and so far it was a fail so i will propably try again with the kit boats, but having a resin-cast hull seems the way to go here, also die to the fact that some People might enjoy more doing the Deck furniture and fittings than Hulls (comes down to personal builder prefer ce). I am Glad that Chris makes them, It's always an option and having options is good
  2. There is an influx of trades People in other parts of Europe now tho, a lot of those who were working in the UK and Now cant get a work permit are getting back to the mainland
  3. That seems to Look even better than the cast one, at least the breasts arent that weirdly pronounced
  4. I use elegoo water washable resin. Just make sure to angle the models, i Went through 10 prints before i got to Proper setting.
  5. Make sure to calibrate the resin each time you open a new bottle - RERF as a General test for each New resin type and then each bottle it is suggested to run the validation matrix to fine tune exposure. What printer did you get? I got an Anycubic Mono X but i only use the water washable resin due to IPA smell
  6. i did use the big HZ Building slip actually on LN and Sphinx build, mostly wile assemlbing the bulkheads and then during first strakes of planking. Now i actually think of pulling it iut again to help me with a few things
  7. oh so you want me to paint them NOW ? I did download them, my 3D sculpting skills are limited to Technical things, during 20+ years dabbling in 3D Software i never learned to sculpt organic stuff i am waiting for my Amazon delivery of airbrush primers, so might take up some painting in the next few days
  8. hm, isnt there an option to buy the paper in a specific color ? I wouldnt run painted paper through a printer, the paint will most definitely rub off on some rolls and might damage the printer
  9. i just use my multitool's pliers as a pin-pusher, i also bought the fancy pusher from the 1st post and find it completely unusable
  10. Yes, Resin Printed, i will attempt to paint them but i think i need to re-print them a bit smaller - at the moment they are 25mm (except the bucket guy, i screwed up his scale and he is 23mm high now but he should be much shorter as he's bent over quite a bit) Anyways, decorations done on Port side: Next up Channels and Hull Steps (plus i need to finish the Bow grating area) On a side note, i failed at Blackening the brass hinges for the stern Port lids, i will attempt to clean them up and just paint but i have to wait for Black Airbrush primer to arrive
  11. A little side-Project Although i think the figures turned out a bit too tall (No, i do not plan to use that Cannon on the model - although it does look quite good but i wouldnt be able to paint it like it is now)
  12. yes but i mean which specific ones he chose so the supplied Fittings fit
  13. Can you tell/link which hulls you have used from Jotika/Caldercraft ?
  14. Yes, i am using Vallejo Primer and applying it with an Airbrush. The primer is sticking to the Brass without problems, It's the Gold paint which peeps off from the primer. Anyway, will Touch them up after they are fitted on the Model, no big deal
  15. Well, no ? I am waiting for Chris' Bigger Ship and all the lessons learned here will be applied to it The Galleries themselves are purely cosmetic here, if i can find a way to make the one side at least to look good, then it's not a big deal for me, as long as it is "clean". Nobody will ever see the other side so they wont be able to compare if it isnt an exact mirror copy
