Jim Lad
Moderators
Posts posted by Jim Lad
  1. A bit of extra time at the museum of late has allowed me to get ahead with the Pritt.
    The counter rim frame is now roughed in and will stay like this until after hull planking, at which time I'll finish fairing it in properly.
    I've also made a start on the deck beams.  Once these are completed I can start to think about planking the hull.
    John
  2. Thanks, all!
    Mobbsie - If you have a decent size Privet then how about turning it into lovely timber for your own next build? ;)
    Mark - I haven't seen Jack's log.  The only place I can find it is in the National Library, but it sounds interesting.
    Bob - As I mentioned, I suspect that the 'counter rim frame' is a piece of pearling lugger technology
    Popeye - Yep, still a knee to be fitted there when the counter frame is finally shaped.
    John
  3. I didn't update my log after my last regular visit to the museum as when I got there I found that I'd forgotten to pack the wood I needed to continue building! :blush:
    I therefore spent most of the day talking to visitors and having cups of coffee in the members lounge!
    On Friday I had some extra time at the museum desk so was able to do a bit of work on the 'counter rim frame' - pearling lugger jargon.  This is the frame that runs around the counter at deck level and onto which both the hull and deck planking butts.
    Because it is fitted into the aftermost frames at deck level, fitting it is largely a case of 'suck it and see' (or trial and error).  So the roughed out frame is now glued and dowelled to the two aftermost frames ready for shaping.  By the time I'm at the museum next Wednesday the glue will be nicely cured and ready to work on.
    The photos are, I think, pretty self explanatory.  The final one shows the typical kicked up stern of the Thursday Island luggers.
    John
  4. Rick,
    I use Selleys Aquadhere and Five Minute Araldite.
    As for blades, you might want to consider using scalpel blades instead - you'll probably find that they're better quality and last longer.  The two that I find most useful are No. 11 (fine straight blade) and No. 21 (heavier curved blade).  But remember - buy them from a vet or chiropody supplier, not from a surgical supplier - much cheaper for the same thing.
    John
