Everything posted by Jim Lad
Hello, and a warm welcome to the forum from 'Down Under'. John
Just a small update, but this is one of those 'one small step for a man' moments for me. The blokes who had previously worked on the model had carefully skirted around putting the name plates on the hull - it's something that I've also been skirting around as a heavy hull fixed to its base and with the masts and lots of deck detail attached is a pretty difficult item to roll over on its side to attach names. I finally bit the bullet and have attached the names to the bow on either side using a single strip wet with dilute white glue and coaxed into position. I think it's worked reasonably well. The name and port of registry on the stern isn't on yet as with a curved and sloping stern I needed to work out the amount of curvature of the name plate to make it appear straight when fitted and also work out how to actually curve it. I think I have it right and will try it out next time I'm in at the museum - I hope. John
hello, and a warm welcome to MSW from 'Down Under'. John
Hello Tom, and a warm welcome to the forum from 'Down Under'. That's a very nice looking dory you've built. John
You can simply treat each photo as a paragraph - simply click at the bottom right of the photo and enter a new paragraph for your text. john
The completed deckhouse looks first class, Phil! John
- 492 replies
- minesweeper
- Cape
6 out of 10. You won't succeed unless you apply yourself (to quote one of my teachers from long ago)! 😄 John
- 385 replies
- Billy
- sternwheeler
I suppose you've thought of printing the name on paper and pasting it onto a more solid backing? John
- 385 replies
- Billy
- sternwheeler
Hello Paul, and a warm welcome to the forum from 'Down Under'. John
Gosh! I would have put a bid in on that! 😀 John
Very well done, Phil. They look really good. John
- 492 replies
- minesweeper
- Cape
We just called them wind deflectors, Phil, but they were fitted on the bridge wings of several ships I was on that were built in the late 40's/early 50's. John
- 492 replies
- minesweeper
- Cape
An update at long last. I'm now back at the museum (albeit working shorter hours) and the 'Duchess' is again growing slowly. I've now reached what is, for me, a major milestone - all 18 square yards have now been crossed! There's still a bit of work to do on the mizzen royal, but it's there and partly rigged! Once I've got that royal as far as it can go for now, I can set up the upper mizzen haliards on deck ready for later and then start on the spankers after a close study of their setup. John
