Posts posted by vths
- de_kryger, Barbossa, d.townsend and 2 others
5
That is a good idea, steel would be even more durable, but that would mean silver soldering which is still something that eludes me. Perhaps next time on a different model. Thanks guys.
- Barbossa, riksgewijs, Martin W and 1 other
4
Thanks guys.
SpyGlass: the wales are painted (dull black) and varnished. Plain parts are just varnished with Lord Nelson semi-matt. More and more I realise that for the next model I will need to buy proper wood of the same colour. Combination of tanganyika and differently toned walnut looks weird unpainted.
I've finally added the second pair of seats of ease as well as boards to give the crew some privacy. Again, Dan's suberb Vulture was the model.
- Dan Vadas, Mirabell61, Barbossa and 3 others
6
Thanks B.E. I'm watching your progress in creating cable stoppers, that will help me a lot, so thanks for that in advance
- Dan Vadas, Barbossa, Mirabell61 and 7 others
10
Thanks, they are not on plans. I was inspired by Dan's Vulture.
Now, I was not completely satisfied with the supplied blocks, so I've decided to create a small sanding jig. It is most useful attached to a high-speed grinder.
The result (original and sanded blocks):
And finally the almost finished forecastle with funnel made of wood and its pot or flap or whatever it is called is made of metal.
Hello folks, after a long time (I've rediscovered Baldur's Gate 2 and Throne of Bhaal
) a small update.
The aft furniture is basically finished with rudder and helm in their places as well as their rigging.
But then I remembered that I haven't created scuppers yet, well, more likely I've been postponing it for far too long. So I grabbed a 2mm brass tube, cut it into pieces, drilled holes above the wales and the rest was easy.
Thanks for the kind words.
Martin, that is a misunderstanding, I didn't cast a new piece, I just used the supplied one and bent it using torch. But if I were to cast a new piece, then I would simply lubricate the stencil (=supplied piece) with oil or something, put it in a plaster, let it harden, put the stencil out and then use tin and lead solder to cast a new one. That would be also flat, but much softer and bendable.
Thanks Martin, much appreciated.
There was one more delicate piece to be made, the spectacle plate for the rudder chains. I used 1mm copper sheet and again solder.
Then I could finish the rudder and put in in place.
And then I was thinking about the way how to bend the stern decoration. Alistair chose to break it into a few parts and glue it together again, but I wanted to work with one single part. I aimed to create a plaster stencil and then cast a brand new piece made of tin. In the end I took the risky approach, grabbed a torch and the piece in tweezers, heated it and let it bend slowly part after part. It looks unharmed now and suprisingly well follows the stern of my Fly.
Time for rudder gudgeons. According to the kit plans, their pins should be created using 1mm wire drilled right into the rudder and bent 90 degrees. That would be hideous, so I decided to solder them to the outer side of the gudgeons creating a gentle toe like this (Proxxon butane torch rules)
But then the pin appeared to me too thick, so I replaced the 1mm wire with thin brass nails.
I don't have good experience with blackening brass, so I painted the parts using metal primer, tamyia acrylic and semi-matt Nelson varnish to protect the paint. There is a bit of silver paint to add the shiny metal effect, but not on the photo.
Almost finished rudder
Thanks, I'm sure you'll do a good job and I look forward to seeing the result, so get on with it
Hello Danny, I just wanted to thank you for this whole thread, it is the best resource that can be found regarding the Swan class (TFFM stands apart, of course). Your photodocumentation is impeccable and I find it most helpful. Wish you many happy days shaping your Vulture, it is a gem.
- aliluke, Martin W, shipcarpenter and 6 others
9
- Dan Vadas, d.townsend, Martin W and 4 others
7
HMS Fly by vths - Victory Models - Scale 1:64 - Second wooden kit build
Thank you guys.
Just finished the bowsprit stem standing rigging as well as other stems, so I thought it would be nice to make a couple of photos of the whole ship.
