Posts posted by vths
Well that is quite easy For example in Photoshop create a new picture with the same ratio as the piece. So if the piece measures 18 x 5 mm, you can create a picture of 900 x 250 pixels. Then draw the windows or anything else - in this case just black rectangulars and fiddle with them to put them in right position. It is also good to make a frame around the whole picture (you'll know where to cut it). The last step is to print it out using scaled print size choosing the actual dimensions of the wooden piece for the whole picture, so in this case 18 x 5 mm again. The printer will provide you with a template of just the right size.
What I did looked something like this
- Landlubber Mike and Martin W
- 2
Thanks Martin. I made a long strip of windows using computer and printed it at the right scale. Then I glued two sides of the companionway together using just a little bit of PVA and a strip of five or four windows on them. Then I drilled a small hole with a .6mm bit in each corner of each window, cut them out with a very sharp exacto and finished them with a fine file.
I would also recommend gluing a piece of paper on the other side of the plank to strenghten it, because it tends to break during the process. It is also good to apply a coat of varnish first to seal the fiber.
Looks like I have the same problem as you, Alistair. I was not aware that the opening for gratings in the gun deck and opening for stairs in the quarterdeck overlap each other, so now it is not possible to place the stair right. Well now it's too late to do something about it. Guess the next build will be from a scratch, then I will be able to make just my own mistakes
Anyway I've rebuilt the companion top to make it narrower and its base was tapered.
Yep, it is highly recommended. It does not have to be absolutely clear, though.
Thanks, Alistair. I decided to copy Dan's companion top from his superb Vulture and that is a bit larger than yours. If it were smaller, I think I would also have a very hard time creating the side windows. Still, it is a bit oversized and rather close to the mizzen mast due to one silly mistake of mine, so I will probably have to take it apart and scale it down somehow. Yippee
Thanks Nils, I find your Pegasus build very inspiring, keep up the good work,
- aliluke, Blue Ensign, Martin W and 4 others
- 7
Thanks Alistair. I'll see what I can do about the pictures. Now I'm struggling with the cap rails. The little bent pieces are made of tanganyika. It still was not easy to do, but it was possible with a bit of patience. Now I'm thinking about the top of the transome and what to do with it. Is there also supposed to be a cap rail?
EDIT: Missing photos reuploaded
- Blue Ensign, Mirabell61, Bettina and 4 others
- 7
Thanks, unfortunately, that forecastle planking is all wrong, so I'm doing it again
Hello everyone, after a few moments (months) pause I've finished planking the forecastle, placed the front pair of sixpounders and found a place for the stove. Looks like the cook will have a hard time working under the beam, but the was no way around. At least I tapered it a bit.
Now it is time for treenails, yay!
Thanks. Alistair, the kink is noticable, but only from above, so the rails should sort it out as well as the inner planking. Anyway I did not give much thought about the stern piece, cause I simply needed it in place to protect the captain's cabin. So that is something that only future me will have to deal with.
Hey folks, got a small update. I finally moved on and closed the rear deck, so the captain's cabin is finished and sealed and six guns with basic breeching are in place. On starboard side they are run out and on the port side they are in for reloading. I'm planning to show them at different stages of reloading, but that is so far just a thought for the visible ones.
Now I need to get rid of the dust and plank the rest of the decks.
- Mirabell61, aliluke, Martin W and 3 others
- 6
Thanks for the honest words, Alistair. As for the badges, they surely won't annoy me later on, 'cause they annoy me already But I needed to hear/read something like this to make a decision and scrap them. I will make new pieces, this time using much harder wood (got a few pieces of acacia left), no soft and fragile lime.
Yes, Doris job is uncomparable, but she does that at different scale and in different universe Cheers, V.
- WackoWolf, Dubz, Mirabell61 and 1 other
- 4
- Aussie048, Mirabell61 and WackoWolf
- 3
Thanks B.E. I was just checking your log and the fine progress you made. I'm very worried about the guns though. How did you manage to work so heavily on the ship with the guns run out? I feel like at some point I will make a bad move and break some of them off, which is a bit terrifying. Also, is there any reason why you have no guns visible in the very front and rear ports? (perhaps because of the same fear I have
HMS Fly by vths - Victory Models - Scale 1:64 - Second wooden kit build
I felt a bit irritated about the stairs, so I finally decided to make a ropewalk. It is a simple jig with cogwheels and the one in the center can be attached to a motor. I had no luck making it work in horizontal position so I tried putting it vertically, which works just fine, but I've only tried it once that way. What I'll need is a better motor that can work in both directions.
Result of the first successful attempt
