Posts posted by vths
Now that is superb, great level of detail and finish.
- dafi, Blue Ensign, realworkingsailor and 1 other
4
- Mirabell61, Padeen, ZyXuz and 2 others
5
- Blue Ensign, Padeen and freewheelinguy
3
Cheers guys, much appreciated. Now I'm taking a little-big detour, because I decided to scratch-build a small pinnace, about 110 mm long. I'm using bulkheads on a keel. They will provide a foundation for planks and then they will be removed and substituted with "real" frames, or at least I hope that this will work.
- Blue Ensign, pnevrin, ZyXuz and 1 other
4
- Blue Ensign and ZyXuz
2
Thanks guys for the kind words.
Alistair> Yes, the planks' color is different and the varnish only emphasised it, but on photos the contrast is even greater because the reflections are not diffused like before, but much more focused. This is also why there is a big contrast in overall lightness (esp. in the 1st photo) and now it is almost impossible to shoot the hull under artificial light. I will have to use some very fine abrasive material for the final finishing touch and I also plan to add wearing (that is a maybe). Now I chose to apply the first coat only to protect the planks. Well and also because I was curious about the whole look
Anyway now I'm not planning coppering the hull anymore, definitely not only on one side. Better watch out for shipworm now.
I could not resist applying first protective thin layer of semi-matt Nelson varnish after sanding the hull. There are still quite a few details to take care of and the first layer also revealed a few poorly finished spots, but the overall result is good, in my opinion. Looks like I will have to use those copper tapes elsewhere, treenails FTW
- lamarvalley, ZyXuz and Bettina
3
But, but... that would mean spending 20 bucks for nothing
I still don't know, but there's plenty of time to decide.
Thanks everyone, much appreciated. Paweł, treenails on the deck should be at this scale .4 mm, but that is rather hard to achieve, so mine are about .5 mm. Treenails in the hull planks are bigger. Anyway, the copper tapes just arrived, so now I'm thinking about a way to assemble 46 pins to make a stamp and "nail" the copper sheets with it. Sounds like a piece of cake
The copper tapes are very thin (about .03 mm), but once pierced, the marks won't disappear whatever I do, so I'll probably use them. Still, they don't look like they can take damage easily, so I will lay them once the heavy works are done and that will not happen any time soon.
Thank you. That depends, Brian. Either I will copper the hull, or treenail it. In any case those visible planks will be treenailed. I'll probably use something else than actual treenails (toothpicks). Probably a thin and cut injection needle that creates small circles that (using a bit of varnish) look rather good.
An example from a Czech board by klimi (http://www.modelforum.cz/viewtopic.php?f=177&t=73264&p=1452414&hilit=jehlu#p1452414)
- Padeen, Blue Ensign and Barbossa
3
- Mirabell61 and rdsaplala
2
Thank you... I'm seriously considering coppering the hull and from what I've learned, the plates' size should be at this scale 19 x 6 mm, but I'm not sure about the material. There are some self adhesive copper 6mm tapes on the market, but they are a bit pricey and I do not know whether their glue will suffice. Normal copper sheats and cyano would do, but what thickness should I choose that would be ideal to work with (incl. "printing the nails")?
Just found your build, very nice!
Love the staggered planking.
I am at the point of deciding my next build and lately the Victory HMS Fly has interested me and your build has helped push me toward it even more.
Is the build still progressing??? It has been a while since your last post?
Hi Randy, the hull is still smiling at me from the nearest shelf, but after long winter there are many other things to do. I will get back to it when the sun, bike and all the other nasty things that keep me outside get annoying.
Glad to see you back, that is some great planking job.
I have one question, during the second planking, from below the gun ports, you used five planks which were in the front untapered, right? Would you do that again, or would you start tapering them sooner?
HMS Fly by vths - Victory Models - Scale 1:64 - Second wooden kit build
Posted · Edited by vths
Hello everyone, I've got a small update. Just finished the main wales and painted them black, now it is time for the little ones above.
Doing this I realized my previous mistake. The main wales are just thick planks, not another layer, which means that I could not follow the plan precisely, because then they would be overlapping the planks below. So, note to self, next time begin the second planking layer with main wales and follow their lines correctly. Now I had to choose the lesser evil - slightly wrong shape, but no overlapping, which would look just terrible in my opinion.
It is also almost time to chose the colour for decorations' background. Ochre would create poor contrast, red is used in the interior, green is just ugly and blue is used too often. I'm thinking about plain white, is that possible (i.e. historically plausible)?
