Everything posted by wefalck
  1. The designers/engravers of plastic kits usually get the coppering wrong, as did many modellers in wood too in the past. Things are changing though through access to information. The moulded-on copper plates usually are far to thick with too prominent stepped seams. The nicety about using adhesive copper foild/tape is that you can closer to scale dimensions. The nails on coppering to do not protrude, but tend to pull in the sheet due to the softer layer of felt underneath. Look in other sections of the Forum for discussions on this subject. Depending on the scale you might either completely forego the nailing or slightly emboss it from the front before applying the tape. The protective paper layer is just soft enough to allow a light embossing. Having said this, it means that you have to scrape clean the underwater hull in preparation of the coppering. While you are at it, you might also want to remove the grossly out of scale plank moldings on decks etc., btw.
  2. I wouldn't use cloth, as most cloths known to me would be too coarse for any of the usual scales of plastic models. However, the vaccum-formed sails may be a useful mould for sails formed from paper, particular, when the sails have not yet been cut out. I would apply a release agent, e.g. a Teflon-spray, and then arrange the individual bolts of sail cloths. They can be attached to each other with acrylic varnish or diluted white glue. Here on the Forum there are various discussions on how to make sails from paper. Otherwise, I would kit out the vaccum-formed sails with boltropes etc. These can be stuck on with plastic cement. You can then apply a base coat, pick out different cloths and re-enforcements in slightly lighter or darker shades etc. Just as you would paint a sail in 2D. If you are not familiar with the techniques of plastic modellers, it may be a good idea to have a look at how the guys do things there. There are really sophisticated painting techniques around that are partly based on the techniques of the Old Masters.
  3. I gather the monograms, coat-of-arms and year of manufacture had the function to not only identify the pieces as royal property, but at the same time made sure that they were not confused with similar pieces, so that the right cannon balls and charges would be used. This is on land probably more important, than at sea. So the monograms must be readable without going around the piece, typically looking down. Hence, their maximum breadth would be probably somewhat under half of the circumference of the barrel, perhaps a third or so, considering the geoemtric distortion when looking down. This is just a practical guess and not founded on any further information.
  4. I am not sure what you are heading for, a reconstruction of a particular ship ? With the hull dimensions you should be able to constrain the spar dimensions better. A lofty rig normally requires a deep hull or a very broad hull in order to give stability. So for a medium deep hull compared to length and breadth one would not expect the upper end of mast length. For your CAD-example my feeling says that the sail-plan should be somewhere between the two extremes - one is grossly over-canvassed and the other one too small for the ship. It may be also helpful to look not only at the proportionate dimensions, but to go a bit into the physics and compare the meta-centres of the sail-plan and the hull, the resulting levers and righting moments, and their relative position along the longitudinal section. The textbooks you quoted should give instructions for this. This would help to further constrain the sail-plan, though you will have an equation with perhaps to many unknowns/degrees of freedom still.
  5. I am not a specialist on this, but a publications comes to my mind that could shed light on this question: MCCONNELL (1988): British Smooth-Bore Artillery: A Technological Study to Support Identification, Acquisition, Restoration, Reproduction, and Interpretation of Artillery at National Historic Parks in Canada.- National Historic Parks and Sites, Environment Canada – Parks, Publ. R64-178/1988E: 595 p., Ottawa (Minister of Supply and Services Canada). This is available on-line, if I remember correctly.
  6. This is a Channel stoppen, Not at quick Release gear to let go. When a chain is under strain, it may be difficult to unfasten stoppers to pay out more chain, or to heave in the anchor. Hence a quick release hook that opens under strain.
  7. Yes, that hatch-like area doesn't look too big. Nevertheless, it may be that the boat can be arranged in different configurations, depending on the type of charter, or if the owner is on board - but I I don't know anything about the actual ownership arrangements, of course. Perhaps some catalogue could tell you more.
  8. I seem to have seen arrangements, where iron masses to correct the compass inclination were located inside the binnacle. They could be moved up and down. On a yacht this is probably not so critical, but on commercial ships with varying loads of different magnetic properties it can be important. On most roadsteads there used to be an area set apart, where ships could turn a full 360° circle before setting out on their voyage to check the compass movement against a set of landmarks. There is also a flag signal for ships doing this compass correction, giving them right of way, so that they can proceed without being disturbed.
  9. The binnacle discussion almost makes me going back to my 30 year old model ... It seems to me that the Flinder's Bar is still there. One can vaiguely discern the brass capping in front of the wooden body. These fancy skylight were not necessarily permanent installations, but could be removed and stowed before rough sea-passages. There would be the coamings left and a simple cap that could be made watertight with a canvass cover like any other hatch. It looks, as if there was a removable section in the deck planking. I quite like these Victorian or perhaps one should say here Wilhelmenian structures with the panelling and brass bars.
  10. It is tempting to show this, because we are used to see this on modern windlasses/capstans, but the hawsers would only be taken around it, when heaving-in the anchor. For letting go, the hawser would be arranged in long bights on the deck, with the end secured appropriately (you don't want to loose the hawser ...). The bights would be tied together at intveralls with light rope. The hawser would break these ropes, which would reduce the speed of running out. Depending on wind, sea and space around 3 to 5 times the water depth would be payed out. The hawser would be stopped appropriately by taking it around bitts. Alternatively and as noted by others, the anchor can be rowed out and dropped a the desired location. In any case, the ship has to be let drift for the anchor to securely bite. It is always wise to have two anchors out, particularly when anchoring over night. An anchor can come adrift easily. Normally, the two anchors should not prevent the ship from swinging with the wind or tide, if there is enough space. The two anchor cables would be tied together with a lashing just in front of the bow to prevent their uncontrolled crossing. I think there is picture of this Lever's book. If there is not enough space for the ship to swing freely with wind and tide because there are other ships in the anchorage, because of nearby reeves etc., one will have to put out one or more stern anchors. This is a less desirable situation, as the ship will ride harder on its anchors, putting more strain on the cables and risking to break loose an anchor. Only when taking in the anchor(s), their cables would be taken around the windlass/capstan (or a messenger be use). Neither on the old-time windlasses nor on the more modern 'patent' windlasses there is a way to hold the pawls in a disengaged position. On patent windlasses the pawls on the levers aren't even easily accessible. On (sub-)modern hand-cranked or power-driven windlasses the motive power is applied to a lay-shaft that can be disengaged from the shaft with the drum(s) through a coupling. Such windlasses have band-brakes on the main shaft to control the running-out of the chain that is permanently taken around the drum. Their pawls can be arrested in a disengaged position, if they act on the main- rather than on the lay-shaft.
  11. Very well done ! Dressmaker pins, that's what I used too. In the unpainted state and with the brass collars, they looked a bit like Christmas-tree ornaments ...
  12. But private ebay-sales are transported via the postal services to a good deal. The volume of parcels has multipled over the past 20 years, so shipping rates should have come down according to the teachings of classical economics ...
  13. Putting it into the checked-in luggage will you get around this, but beware that customs can open any luggage they find suspicious. I did bring back piles of Sherline equipment (including drive units) from USA trips that way. You will have a maximum worth of goods that you can import as a tourist coming back that depends on your country of residence. Beyond that you will have to go through the 'red' channel and declare your purchases. How your goods are assessed can be a bit of a hit and miss - customs officers are not always sure how to categorise 'exotic' articles. In most cases you will have to just pay the VAT though. It is a good idea to keep invoices and also documentation material, e.g. catalogues, to show customs (and security) what the strange equipment is being used for. The main culprit for the exorbitant shipping costs from the USA is the US Post Office, who decided around 2004 to abandon 'surface' shipping as an economical option. You may have had to wait for your parcel two to three mounths, but it was way cheaper. Mr. T. would do the US retailers and customers in the rest of the World probably a favour, if this was re-introduced ...
  14. Good points by Jaager. One needs to understand the mechanism of bonding of glues/cements and different types of surfaces. There are two fundamental types of fitting: - the parts are held together by interlocking; an example are screws, where the male and female thread interlock; this is usually the strongest joint. - the parts are held together by a force exerted on them: an example are nails, where the friction from the compressed wood fibres keeps the nail in. If the surfaces are sufficiently rough for the PVA to key-in, the glue will form an interlocking joint. Cementing metal to metal or other surfaces with CA, mean to largely rely on physico-chemical interactions with certain parts of the CA molecules and the atmospheric pressure that pushes the CA onto the surface. Particularly with shear-forces, it is easy to peal off the cement. For this reason it is always a good idea to provide for some interlocking. Wooden dowels combine all the different actions. Glued carpenters' joints are another example of combining the different types of actions.
  15. This looks like an elaborate procedure ! The idea of milling both brackets of the regulation spheres in one piece sound like a good idea - makes the whole thing more solid. I gather you will have to slot the binnacle then for this. I remember me struggling with this part in the days before I had mill ...
  16. Quite right so - I use steel-wool too and no magnets. By the time you get to steel-wool, the hull will be very smooth and the flicks of steel can be brushed off quite easily. It is a good idea to change the pad of steel-wool frequently, before it begins to to crumble.
  17. Oops, have to check this out. The binnacle was made in about 1990, when such detail research possibilities and my library of period books were more limited. I would have thought that these compensation balls were in use from around the mid-1860s or so, when iron ships became common. Indeed, in earlier days they put the binnacles on long 'masts' above the deck. I cannot change this anymore, so we assume the tug was still in operation in the 1880s In fact, the design is from the mid-1860s, but the lines etc. were published as a worked-through example in the first German textbook on iron shipbuilding of 1869.
  18. The problem with scavenged material is, that there is no sustained source for it. I wouldn't know, where to get a computer CPU just like this ...
  19. Could enlighten us to what ships this pertains. This always helps to understand functions. Also, it would be good to know, where on the ship this is located.
  20. Keith, the 'appendage' is the lamp to illuminate the compass. It is obviously an electrical lamp on the modern version, as otherwise the binnacle cover would have had a short 'funnel' on top, to release the hot air from the petroleum lamp. For starting a drill hole at an angle, I use an end-mill that cuts over the centre. In this way the drill doesn't wander off. Nice job, btw. This is a specimen I did some 30 years ago (diameter about 6 mm):
  21. Valery, this is just some sort of nitrocellulose laquer filled e.g. with very fine pumice powder. It is used as a primer on wood, to fill the pores. On decks and surfaces that will be matte, depending on the wood, often one coat is sufficient. It sands well and I finish with fine steel-wool.
  22. Forty layers seems to be a bit exaggerated. If one needs so many coats, it means the wood was not properly pepared (by modern standards). In the old days only shellac and pumice was used, but today good sanding fillers on nitrocellulose basis are available that cut down the effort. It also depends on the kind of wood, the larger the pores, the more work. Dense wood works faster. There is also the risk, if one does not work fast enough or too wet, to dissolve too much from the underlying layers and then you have to begin again. In practice, I found a couple of coats of sanding sealer and two to three coats of shellac are sufficient, if you don't want a mirror-like surface (which I don't like anyway).
  23. I am applying a sanding filler before anything else. This stabilises the paper and sort of turns it into a compound material. The filler also prevents 'dirt' from getting into the wood pores.
