bhermann
Posts posted by bhermann
  1. 22 hours ago, JohnEvans said:
    I’ve read your terrific build log, and noted your reference to Bob Hunt’s “ practicum ” but can’t seem to track it down. Is there any help you can give me as to how to get it?
    Hi, John.  The Bluenose practicum is available at Bob Hunts site, Lauck Street Shipyard at https://lauckstreetshipyard.com/.  I used it when starting out my Bluenose as it was my first wood model build.  I hope you don't mind me jumping in on this.
    Bob
  2. I'm so sorry to hear about your many issues over the past few years and the loss of your father, and happy to hear about your new puppy.  I have been thinking about you as the log has remained in a sort of limbo for some time.  Looking forward to reading the finish of this "build book" and seeing  her sitting in her place of pride.
    Bob
  3. I had the same thought as Ronald-V when looking at the last photo in your post, Gregg.  It depends on where the hole for the spacer is on the left side of bulkhead 17 is to see if it will fit when flipped.  If it is to the inside, as the right side hole is, then trimming the tab seems to be your only choice (unless you want to try cutting a square hole in bulkhead 17 to allow the tab to fit where it wants to go.
    Your fix for bulkhead 16 should hold just fine.  Nice work and photos, as always.  I love the kit design that supplies the spacers and places to put them, maybe other kit companies will take note!
    Bob
  4. Congratulations on a well-executed and well documented - and beautiful - model. Gregg.  I have very much enjoyed watching her come to fruition and your thoughtful commentary along the way.  With winter coming and more inside time I am hoping to finally re-start my effort, although I'll be thinking "Wish I'd done that as well as Gregg did".
    Also looking to see where you go next and will be following along there - I think I hear the Conny calling :)
    Bob
  5. Looks very good, Gregg.  I like that you brought the gaffs down to the boom.  So many of the sail-less schooners I see raise the gaff to where it would be with the sails installed which looks a bit strange to my eye.  Actually seeing your rigging choice gives me yet another alternative to consider - this should add another couple of years to my analysis paralysis!
    If you would like to elaborate on the difficulties you had with the silkspan, I'd love to hear about it.  I am convinced that this is the sail material to use, and I am almost decided NOT to sew anything.  I can understand that you may not want to clutter your log with this info, so don't feel bad about not responding.
    Great photos and explanations, as usual!
    Bob
  6. On 8/28/2024 at 9:58 AM, Der Alte Rentner said:
    After seeing this post to Gregg, I took a look at your Bluenose build.  Sorry to see that it's been collecting dust for so long.   Here's hoping you get back to the ship yard sooner rather than later.   This may be a stupid question, but can't you finish it without sails, then change tack later if you feel you must add them?
    That's an interesting thought.  I suppose it's possible, but I think it would make adding the sails more challenging.  Great, one more thing to mull over - this should hold me up another two years ;)
    Bob
  7. 17 hours ago, GGibson said:
    I am going to see if I can get some running lights placed on the two sets of foremast shrouds.  Then it is time to get the running rigging that I prepped months ago attached where it belongs on this Bluenose!  Those of you who have followed my progress (or lack thereof) on this Bluenose (thank you, by the way!) may recall that I have wrestled with how to finish my Bluenose... with sails, without sails, or furled sails.  And I have leaned each of the three ways multiple times over the almost-two years I have worked on her.  Well, stand by for my decision...!
    Thanks to all for taking the time to read, comment and criticize!  Appreciate all of the support, whether it's been your input here or my peeking in on your own Bluenose build logs and having one of those "Oh, yeah!" epiphanies.  Thanks!
    That is some very nice work, Gregg!  I can't wait to hear what you decide on the sails.  My own debate on that has kept my Bluenose in limbo going on 11 years now.  Sails?  No sails? Cloth sails?  Silkspan sails?  Maybe your decision will inspire me at last!
    Bob
  8. That is some more nice work.  I hear your concern about the waterline marker.  I recall sticking a pencil between two heavy Cisco certification books and dragging the levelled hull past it.  I also recall not being happy with the result and retaping and painting by eye to fine tune things.  As with all things Bluenose, take your time, rework as needed until you are happy with the finished product.
    Bob
  9. On 9/4/2023 at 10:02 AM, MajorChaos said:
    One may look upon this and see no mess with the glue. The trick is the type of glue. It has glue all over it lol. It dries clear so it makes for a very clean finish.
    I estimate at least 40 hours planking. Every piece is glued and fitted on all four edges. I wish I would have seen the plank depth issues earlier, but they should sand out and might need a bit of filler in a few spots.
    It’s far from perfect but I’m pleased with how it looks so far.
    Sanding and filler are our friends, first some sanding, then some filling, rinse and repeat, finishing with a fine grade sandpaper.  Taking the time to get this right will be a big benefit in the long run.  Looking good!
    Bob
  10. Responding to the February 18th post (don't know how I missed it at the time), I realized after I had installed my chanplates that they actually sit flush with the hull and not proud of it as I did them.  I think this may inform the decision whether you include them or not - they would not be very apparent at the 1:64 scale we are building at.
    Good luck with figuring out the sails, there are too many options to think about and it has brought my build to a halt for years.  Cloth sails in general are too thick to maintain scale.  I am considering doing them anyway, or maybe doing paper strips to build each sail panel by panel.  In any case making photocopies is a good idea!
    Your work is looking very good to this Bluenose builder!
    Bob
  11. That is some great work, Dave.  The turnbuckles (and the rest of it) look really good!
    FWIW, I rigged the bowsprit bobstays, guys, backropes, stirrups, footropes, and jib stops right after completing the installation of all the hardware.  Like Ed, I was looking to get my feet wet with rigging as Bluenose is my first wooden build.  It has been sitting now for several years waiting patiently for my return.
    Bob
