Posts posted by JanV
I fix those knots with a solution of 75% white wood glue and 25 % water. I tried first 50%/50% but then the fixation was not so good
I made first 2 double knots with a very thin line above the block and then fix this with a pensel.
Did you consider to use a mixture of the white wood glue with water (50/50%) and then fix each knot with a small drop of this mixture using a small old brush
consider that CA might break after several years and this is a very hard glue connection which can also break after touching once you are finished.
this is my experience as well from several experienced builders in the Netherlands, we try to not use CA on shipmodels except when all other glues cannot be used
I am using CA only to make a needle from the beginning of a rope so this makes it a lot easier to have the rope in small openings from blocks etc.
Started with the strops for the blocks
This is the 1st batch of the double 3mm blocks for the canons
Hello,
I noticed your log today for the first time
good to see that another Corel Vasa builder started.
first impression of the pictures is very good.
Looking forward now to see the sails on your model Sjors
This looks very good Matti.
We are making a new standard all together with our Red Vasa's
Your Vasa does almost get the same level as the models in the museum. Once Fred has seen this model........
I assume you are also waiting for the Vasa II book in order to start with the other rigging. For the completion of this part it is not a requirement. Let's hope it will be ready after you finished your 3000 knots
Nice to see your second Vasa here Mark.
As all good things you should do them twice to learn
with the figures you are correct, you should handle these very carefull, special the figures you have to remove from their supports.
you have noticed in the other builds of the Corel kit of course already several mistakes.
maybe we can together inform Corel how to modify this kit for the future so that all new generation Vasa builders can finally select more kit manufactures with correct kits. how difficult can this be with a great example in Stockholm
Today I received the blocks in 3, 4, 5 en 7mmI orderded these by clasicmodel.com
first impression looks very good so I can now continue
- tarbrush, marktiedens, RGL and 1 other
- 4
great to see another Vasa here.
I keep following your build
Thanks for your reply Michael.
this looks very good Michael.
just one question, what is the size of the blocks you have used?
First I would like to thank all those who liked my previous postsI finalized today the stairs, I used the originals from the kit which have been sanded to make them smaller
further I made the hings for the doors
oops I do not like the macro on my camera
the last days some small points done, today I painted the doors
- Lin Feng, Karleop, marktiedens and 5 others
- 8
Wasa by maltbyguy - Billings / Corel
I just noticed your log. welcome to the group Vasa builders. I am building the Corel kit both are indead the same scale although the Billing Boats kit apears to be more accurate and based on newer information.
