Posts posted by pete48
This Is my Second Build log ,( First scratch ) . The plan is to build a Muscongus bay sloop with working rudder and retractable centerboard. This may take 2 boats to get me there. I will be starting this build with Keel #3 . There was a lot of research and comparison"s made to the Midwest kit That I built. Keel # 1 & 2 are on the Kit build log (although keel #2 was built just to get the hull planking correct ) . Keel #3 will also have a planked deck (possibly sprung)
- mtaylor, themadchemist, cdogg and 4 others
- 7
Thank you Russ, I am hoping to get her completed this weekend
Today all the work was done on the kit build. Starting with making the oar locks, I then decided that the cotter pins supplied with the kit are just too big,so I replaced them with "Earing bead landing" wich have nice small loops . On the sampson post I used a medium size paper clip instead of the brass wire and used a black sharpie . I also felt that the trim pieces were to small so I replaced them with 1/16 " square stock (that way theres some room to give it shape)here are the results
Awesome Shawn . Looks good And I have to agree with Russ take the time to fair all the frames (it will save you down the line)
Pete 48
Thank's Casey, If you would like to know how I did any of the mods, Please feel free to ask , I will be happy to share any info
Best Regards,
Pete
Most of the work today was done on Scratch 1 ( or Keel #1). At first, I was just going to do the standard kit version of the companoin way hatch. Then since I plan on starting a "Official scratch log" (Hopefully this weekend ) It would be best to build the companion way hatch correctly. I also did the cockpit area in a teak look. Here are the results on keel #1
Today On the Kit build I have nearly completed the cockpit ( I just don't know about the fish hatches ) I have also installed the Bowsprit and cleat ( this is the best one I have made so far). I think the rudder will need one more coat of Grey. The boat is almost ready to go to the Masting shop. Here are the results
Thank you Russ, I should be able to show more cleats ,as I should have the cockpit finished on the kit build today
Best Regards,
Pete
Today I got alot of work done on Scratch 1, I have brushed 3 coats of varnish on the hull ( it will probably take 2 more). I painted the cabin/cockpit coaming a flat white. I also made a new cockpit floor . On the Kit build I put 3 coats of varnish on the tiller and installed it. I also installed one of the cleats I made ( I used a gold leafing pen to get the color) Here are the resuilts
Thank you Russ, I greatly appreciate it
Hi Pete in Portland I am making them out of 3/32 X 1/8 woodstock then shaping them to size. On the kit Build the Deck has been painted with 3 coats of sand color Badger Paint. All the other hardware and pieces have been painted or stained, so I can start finalizing this build. On the Scratch build, I was not happy with the water line so I repainted it. Here are the results
- shawn32671, The Sailor and DBorgens
- 3
Thank you Shawn, How far are you on yours ?
First of all Thank you , Shawn , Cap'n'Bob ,Richard , Russ and Harvey for your kind words I am having alot of fun building these . Today on the kit build, I got the second coat of paint on the rudder and started making new cleats ( I dont care for the ones supplied with the kit) and on scratch build 1 I got the water line painted. In the meantime I took over an abandon ceramic building my wife Had, and it is now being used as a Masting area. Here are the results
Hi Casey, The one on the left is the kit , I am hoping to finish it this week
On the kit Build, the rudder has beed installed and is ready to paint. On scratch 1 the bottom paint is done and on scratch 2 the hull has been planked and started fairing . I was happy with how the planking turned out . I am now ready to start framing the deck. here are the highlights from todays progress
- The Sailor and trippwj
- 2
Thank you Shawn,Have you started on your loster smack ?
Best Regards,
Pete
- shawn32671, russ, kuya and 1 other
- 4
Awesome Casey, It should be alot of fun to build
Thank you, Russ I greatly appreciate it,
Richard, Yes I like The lobster smack, it is a beautiful boat with very gracefull lines,
Casey, The hatch completly opens and the hatch boards lift out as well
Best Regards,
Pete
Looks great Bob, She's really taking shape, nice detail work
Muscongus Bay Lobster Smack by pete48 - FINISHED - Midwest Products - SMALL
in - Kit build logs for subjects built from 1851 - 1900
Today on the Kit Build, alot of fitting out The fairleads and trail boards have been installed . I used 1/32 Birch Plywood for the trailboards. Most of the work was done in the masting shop I made up some better looking cleats for the mast and boom (I am starting to get better at making them) I also started making new blocks ( I dont care for the wire method that wrap around the blocks) I am using Black thread instead here are the results I will now probably get the boat finished next week ( I thought I could get it done this weekend)
