Glenn-UK
Everything posted by Glenn-UK
  1. Many thanks, once the sailors have been up and down a few times they will move a bit and become uneven.
  2. Ratlines - The never ending saga of clove hitch knots. Work continues with adding the ratlines, each ratline takes me between 5 to 10 minutes to complete. Yesterday I completed work on the starboard side foremast. There are one of two ratlines I could have done better, but overall I like how they have turned out. In the picture below I should have added one more ratline just below the catharpin rod. The sailors on this ship will there earn their daily tot of rum when climbing up and over the rod on to the futtock stave ratlines. This morning I have been working on the main mast starboard shrouds. Again there are 2 or 3 which I could redo but overall they do not look too bad. I am a little bit concerned that I will not have enough ratline thread left to complete the process, especially when I start work on the top mast ratlines. I'm trying not to be too wasteful so fingers crossed.
  3. I should visit the National Museum of the Royal Navy - Hartlepool for inspiration which is about a 90 minute drive. The HMS Trincomalee is berthed there which is one of the two surviving British Frigates of her era. I have been a couple of times and really helps with get an good idea of what these ships were like. HMS Trincomalee - Wikipedia
  4. Ratlines - The beginning Over the next couple of weeks I will mostly be tying clove hitch knots😆 As per my last post I have opted for a 5mm spacing between the ratlines to replicate a 13" spacing. (13" * 25.4 / 64 = 5.15mm) The lowest ratline is tied to all the shroud lines. The next 5 ratlines are not required for the outer stern side shroud. The pattern of full width ratlines spaced between 5 shorter length ratlines repeats over the full length. I have indicated this on my spacing template where X indicates the full length ratlines. It took me a few minutes before I found my clove hitch knots mojo again but once I got back into the swing of tying them it does not take me too long to add each ratline. In the two pictures below I have added all the full width ratlines for the foremast starboard side shrouds. My next update in a few days time will hopefully show the completed ratlines for the foremast, post and starboard. With reference the photo below I did struggle to get the lowest ratline positioned correctly due to the presence of the shroud seizing's. After two attempts I have decided to accept for the time being. I might change my mind and redo once I have completed adding the rest of the ratlines. All clove hitches are being lined up with the template, and a final check will be done before I apply some diluted pvc to the completed ratlines / shrouds.
  5. Futtock Staves - Completed I was able to spend more time than I thought in the shipyard today so I was able to complete adding the futtock staves to the starboard side. Overall I am extremely pleased with how they have turned out.😀 Ratlines to be added next. From a little bit of research I have done the ratlines on HMS Victory were set 13" apart. Adjusting this dimension for 64th scale and converting to metric yields a spacing of approx. 5mm (13" * 25.4 / 64=5.15mm) between ratlines. A preliminary estimate is there will be around 24 ratlines on the foremast per shroud and plenty of clove hitch knots. In the past I have found adding ratlines relaxing so fingers crossed 🤞it will be the same again for the Sphinx. I have added a couple of very similar pictures of the completed futtock staves.
  6. Port Side - Futtock Staves First job this morning was to add all the futtock strop hooks to the futtock staves (100mm x 0.75mm black thread). In total I seized 22 futtock strop hooks to 22 threads. It took me a couple of hours to complete. It was then a case adding each futtock stave to their respective shrouds, passing them over and behind the catharpins. It was another 2 hours work to complete the port side today and I plan to start work on the starboard side tomorrow, but my time will be limited due to grandparent duties. The photo below shows the current build status. Foremast Futtock Staves Mainmast Futtock Staves Mizzenmast Futtock Staves There is some debate if the mizzen mast was fitted with catharpins on the actual ships of this period. As they included on the prototype build and shown on the rigging plans I went ahead and added them. I may regret this later on as it might hinder the fitting and rigging of the Gaff. With the futtock stave passed behind the catharpin it is held in place with a pair of reverse action tweezers, as shown in the photo below. I then added two seizing's to secure the futtock stave to the shroud. Once complete the excess thread was trimmed. Once all the futtock staves were installed I applied some Indian ink to the natural thread.
  7. Hello BE Many thanks for your observations. I have no knowledge of what was actually fitted to the real ships. I just follow the plans provided with the kits I buy. I also look at all the different build logs on MSW as well. I have noted that on the prototype Sphinx built by @James H the catharpins were added to the mizzen mast. They are also shown on the rigging plans provided by @chris watton which is why I added them. I am sure adding the Gaff will present me with plenty of problems and headaches with or without the catharpins and futtock staves. You build work is truly amazing and I wish I had the skill set and patience to emulate your very high standards of workmanship. Thanks Glenn
  8. This post covers the completion of the catharpins and the start adding the futtock staves. Catharpins - Completed I have now completed the installation of the catharpins for the fore, main and mizzen masts. I am really happy with how these have turned out and the end result far exceeded my expectations which were based on my efforts on previous builds. As stated in a previous post I tried to replicated the method illustrated in Lennarth's Petersson's book "Rigging Period Ship Models". I was not looking forward to this task but now I seemed to have found a method which is relatively easy to implement it turned out to be not so bad. Main Mast Catharpins Mizzen Mast Catharpins Fore Mast Catharpins Futtock Staves There are 22 futtock staves to add, 8 for the foremast, 8 for the main mast and 6 for the mizzen mast. I have collected 22 x futtock strop hooks and I have also cut 22 x 100mm lengths of 0.75mm black thread. I have started to add the futtock stave thread to their respective strop hooks. The picture below show the first four futtock staves for the foremast which are now ready to be seized to the strop hooks. Using the quad hands the first futtock stave is held in place ready for the seizing to be added. It did not take long to add the seizing using 0.1mm natural thread. I used 12 half hitches for the seizing with 6 half hitches on the bottom and 6 half hitches on the top. The completed part is shown below. The final picture of this post shows the first futtock stave in place and it is ready to be seized to the shroud. The futtock stave has been passed over and behind the catharpin and then held in place using my reverse action tweezers. It should be a relatively easy task to secure the futtock stave to the shroud. I plan to make all 22 of the futtock staves before I start adding them to the shrouds. After that it will be time to add the ratlines.
  9. Another impressive workspace. I would like to refit my garage out for this hobby but instead I'm getting the bathroom, ensuite and downstairs cloakroom refurbished.
  10. Thank you Jim. I am very pleased with how the lower foremast catharpins have turned out.
  11. Foremast Catharpins - Completed After the false start detailed in my last post I was able to remove the port side brass rod without any problem. It was then a simple case setting the brass rod to the same level as the starboard side. With the port side brass rod held in the required position it is ready to be secured to the shrouds. This can be seen in the photo below where I have already secured it to the furthermost shroud line, using fly tying thread. It did not take long to complete securing the brass rod to the shrouds and double checking it is at the same level of the starboard side. I was unsure which method to use for the links between the shrouds. I opted to try the method outlined in Lennarth Petersson's book entitled Rigging Period Ships, as shown in the picture below. I used a length of dowel to workout the distance between the shrouds at each point and made up the cross threads. I tried to make them a tad shorter than required. The first cross thread was a tad too long to be rigged as shown Lennarth's book but it slid over the ends of the brass rod and was a perfect fit. The remaining two cross threads were fitted as per the method shown in Lennarth's book. The middle one took two attempts to get fixed but it ended up being a good fit. I had to remake the final cross thread as the first one was a bit too long. There is quite a curve for the furthermost cross thread around the foremast, which is evident in the photo below. I have never done catharpins this well before so I am very pleased with how they look. All that is left to done is apply some Indian ink to the thread and touch up the brass rod, as necessary.
  12. Many thanks, I think spending time correcting my countless errors is paying dividends. 😀
  13. Thanks @DelF. It seems to be a mystery. I thought I had found fool proof with aligning the shroud deadeyes, it would appear I am the fool 🤣
  14. Catharpins Foremast - A False Start The first task with regards to the catharpins is to fit the brass rods to the shrouds. The 1mm brass rod supplied with the kit was cleaned in acetone and hot soapy water and then chemically blackened. The brass rod was then held in position on the port side shroud using a quad hand, as can be seen in the photo below. So far so good! With the brass rod held in position I used some fly tying thread to secure it to the shrouds. It is not my best work but the thread will be dyed black with Indian ink so will look OK. The brass rod is now ready for trimming to the correct length. With the brass rod trimmed, as shown in the photo below, I am ready to move on to the starboard side to repeat the above process. Unbeknown to me however I had made a fundamental error! This seems to be a core theme with my build log journey for the Sphinx. The more eagled eyed of you might have spotted the error. Fear not if you haven't as all will be revealed after the next next photo. Moving on to the starboard side I used a length of brass rod to check the position to ensure it was set to the same height as the port side. This is when I noted that the thread links between the two brass rods, when installed, would foul with the rigging block affixed to the rear of the foremast. I found it difficult to find a picture that clearly shows the problem, the one below is the best of a bad bunch. The middle and inner cross threads would be at the same level as the rigging block based on the level set on the port side brass rod. It did not occur to be to check this sooner. In the photo below I have reset the position of the starboard side brass rod so the cross threads will now avoid fouling with the rigging block. The brass rod is ready to be fixed to the shrouds. Once this is complete I will remove the brass rod from the port side and reposition so it is lower and level with the starboard side. Hopefully this will be easy to do.
  15. It great to see the innovations incorporated in this design. It looks like it is going to be an amazing model.
  16. Lower Mast Shrouds All the lower mast shrouds have been fitted and the lanyards rigged. The seizing's have also been dyed black with Indian ink. My skills in this aspect of rigging are much improved but there is still plenty of room for improvement. The area which still seems to cause me some problems is getting the shroud deadeyes positioned at the same level. On the other hand a degree of unevenness is more representative of the shroud deadeyes on the real ships. Catharpins The next task will be to add the catharpins, which are the short ropes tied between the port and starboard shrouds for stabilisation and to prevent the shrouds interfering with the yards. On all my previous builds this is one area I have always struggled with. In Lennarth Petersson book "Rigging Period Ships" each catharpin is shown as a length of rope with loops on each end. The two loops are used to secure the catharpins to the shrouds. I might experiment to see if this is a viable option. I think the problem will be determining the correct length for each catharpin rope. In the past I have looped the catharpin thread around the brass road and then formed the loop by added a seizing to the catharpin thread to hold it in place. This has always proved to be difficult to implement due to the limited space available. Also I have always ended up with a slightly twisted shroud which is a problem with over tensioning the catharpins. In Jim's prototype build the catharpin thread appears to be taken over the top of the brass rod and is then seized to the front of the shroud line. The catharpins are positioned to meet the brass rod next to where the futtock staves pass. After passing behind the brass rod, the futtock staves are seized to the back of the shroud along with the catharpins at the front. This is another method which I have not tried before but it looks much easier to implement so is a method I will experiment with.
