giampieroricci
Everything posted by giampieroricci
  1. burnishing the little door I fixed the hinges with these beautiful rivets round head 0,3x2 mm and this is the end result: the photos are all in super-macro! The door is fully functional, although it is terribly delicate!
  2. I started to build the doors for the oars; the major difficulty has been to be able to realize the hinges so that they were functional. First, by a thin copper foil has formed the curved part: I filed the interior with the grinding wheel after drilling the holes 0.3 mm I finished the outside I made the hinges by cutting half with the grinding wheel The part of the hinge to be fixed at side
  3. Hallo Ed! Your work is simply fantastic!! What did you used to weld the anchors? It looks so perfect!
  4. Thank you for your compliment, friends! This corvette has 12 guns: I have to do a total of 24 hooks.......
  5. I completed the formwork railing I started the construction of the gun deck with the construction of the hook pins for the artillery:
  6. Yes, Mark! It was very difficult to build it.... This is the other, with the small bell:
  7. Small update: I built the cleats in horns, the lower mizzen mast and the first of the quarter-deck railing to the right of the hatch
  8. Exscuse me, Mark.... why did you let all that space for pintles rudder? Moreover, the pintles should be within the space, so the rudder remains in the stern straight wire; The rudder seems too far from the stern
  9. Thank you for your likes and comments, fiends! I'm happy that you like my work!.... I prepared the stern coffers: to fix the hinges I have used these wonderful rivets 0,5x2 mm
  10. In fact it was like performing surgery, especially because ebony needs to be drilled before nailing.....
