Old Collingwood
  1. Thank you Denis, Curry has taken my attention away though😉 OC.
  2. Starting to put some colours on Curry - quite a process as there is a lot of detail hidden away that is brought out with the different colours - still more to do to him, he is about 2/3rds done. He is just placed on the horse for impression - not glued on it yet. OC.
  3. Thank you kindly Edward, I started with a basic flat white then added a dirty wash and when dry a very subtle white dry brush, the whole horses body had the same treatment. OC.
  4. Good day all, curries horse is finished minus the base and let me introduce you to a cuirrasier called mr curry, just undercoated with flat black ready for his different colours. OC.
  5. Thanks Lou, my farther used to tell me of all sorts of crash landings at the various fields he worked at so I agreee - deffiantley possible, in fact at RAF West Maliing they were deffinatly both serving at the same time. OC.
  6. Evening all, next stage trying out a few Cuirassiers I got on a single spue (cheaper that way only a couple of quid each) I started with the Horse After cleaning the two sections up just a couple of seams but not realy an issue, then I did a couple of coats of Oak Brown, then some washes followed by the harness in Black.. The lighting makes it look darker than it is as my lamp is dead overhead. OC.
  7. Hi all, right - French infantry man number one finished (just a little display on a piece of my base I was sent. OC.
  8. Thank you kindly Mark, that does sound like a great idea as I have five or six primed up (used tamiya fine surface rattle can primer) but now ran out. OC.
  9. I think that was a little later in the day when the farm was over run by the French and the French canon came up, so guess they wouldn't be there in the time frame I am going for, I am aiming for roughly middle of the battle when the farm was still held by a mixture of Green/Grey and Red coat KGL and a few 95th (Sharps) outside near the wall supporting the KGL, while the french was attacking with Line Infantry and Cuirasseriers. OC.
  10. Thank you kindly Edward, I am trying to paint them with a realistic look - dirty from the enviroment and battle. OC.
  11. Thank you kindly Lou, the Spit is there part artstic license and part space saving in my display uinit as I am running out of shelves, but who is to say that they would not share the same apron space at some point - they were both on station at the same time. OC.
  12. Evening all - more painting (good job I am not on piecework) slowly slowly catchy monkey, just needing to paint his musket then the first one is done - only about another 99 to go😲 OC.
  13. Thank you Roger, any advice with figure work is deffinatly welcome (Its new territory to me) I use the excellent Vallajo putty - its really good. OC.
  14. I really need to come up with some better painting blocks instead of my paint tubs for while I paint them, I will have a look in the house and see if I can find anything. OC.
  15. Evening all, I did abit more on my 2nd Infantry Brigade Rifleman, they are very fiddly and need good sharp fine paintbrushes lots of light and a magnifier, its a case of working on the main colours then trying to reach the awkward bits hidden like the cross belts behind his musket, I am trying give him a dirtied appearance as he would have been on the field from all the mud. OC.
  16. Thanks Mark, he is the over looker who sits in a chair and gives advice - just like a back seat driver. OC.
  17. Evening all, on the back of my Mossie Dio - "No peace for the wicked" so i decided to start one of the French line infintry, first I gave the face and hands my flesh colour I followed this with a wash, then another slightly dry touch up over the face and hands, next I worked on the hat - this is a basic flat Black with a Red and White plume and a yellow/gold detail diamond, I followed this with another gentle wash and a slight dry brush. OC.
  18. Thank you so mutch bro, it only shined because of a few suprises. OC..
