rvchima
Everything posted by rvchima
  1. Hull Plates Completed It took about 30 hours to finish the plates, cut all the ports in the bulwarks, and attach the plates with double sided tape and approximately 525 tiny brass nails. Not suitable for someone with a short attention span, but I suppose none of this is . Final Details I finally ran into some parts that were missing from the Panart kit. There are 6 oval ports in the bulwarks that are lined with cast bronze fittings. Only 4 fittings came with my kit, so I made 2 more out of brass sheet and wire. I formed the parts around a wooden form, soldered them together, and plated them with copper patina for stained glass. They don't look too bad. The plans show the upper rails made out of 3 mm x 8 mm basswood, with no information about how to make them fit the compound curvature of the bulwarks. I didn't have enough basswood that size left, so I bought lots of 1/8 in. square strips. I traced the outline of the bulwarks onto cardboard, subtracted 1/4 in., and traced that onto a Masonite form that I then cut and sanded. Then I steamed the basswood strips with a wallpaper steamer, bent them around the form, and glued them with CA. Pretty complicated for a railing but they came out nice. Here's the final result showing the ports and rail. The rail and deck all have 3 coats of orange shellac. The black arches (or whatever the proper nautical term is) were also steam bent out of basswood. Cast bronze letters were provided and painted white for the ANTEO name.
  2. Kurt, Thank you for posting the photos of the Alice E and your model of her. Seeing photos of a beautiful scratch-built model like yours helps bring me back to earth when I start to feel complacent about my work on a kit The "water inlets" on the Anteo are labeled as such on the plans, but other Italian-to-English translations in the instructions are pretty poor. Two ports are located on the main deck behind the engine room and could easily be escape hatches, but two more are located on the upper deck above what I think are crew quarters. There are several doors below so escape hatches seem unnecessary, but water tanks don't seem likely there either. Finally, I had not heard of the nautical research guild, and just spent a couple of hours on your site. It sure looks like something that I need to join. Rod
  3. Hull Plates The Anteo kit includes a large sheet of photo etched brass plates that surround the top of the hull. I felt that shiny brass was unrealistic around the top of of a tug, so I colored the plates black with a chemical used to patina stained glass. The plates are a b*tch to attach. Most plates have a hole that has to be cut through a triple-planked basswood hull. No matter how carefully I drill, cut, or sand, the paint gets scratched on the outside, the wood tears out on the inside, and a tool slips and gouges my beautiful deck. It will take a bit of cleanup after the plates are all attached. The plates are attached with 3M double sided tape. That works beautifully. Each plate edge has 7 or more holes for tiny brass nails. The only problem is that the nails are too long so I have to cut them off. The blunt nails don't drive well so I have to pre-drill every hole. I'm getting about 3 plates done each night.
  4. The Anteo Was Almost Launched Two weeks ago my Anteo tugboat almost got launched. We had the "storm of the century" here and my basement rec room and workshop were flooded. The photo shows my rec room with my Syren model and Amati U-47 U-boat kit (future build) safely out of harms way, while my DeWalt tool bag floats by from my workshop. The ensuing chaos has kept me from posting for a while, but things are mostly back to normal and I am building again. Final Paint Scheme Before the flood I decided on a paint scheme: Emerald Green for the hull and Periwinkle for the trim. I love the final look. Engine House The engine house has 10 hinged windows. Each hinge is made with two brass "eyes" drilled into the house, a third drilled into the window, and a pin made of brass wire. Each window has a brass porthole with a clear plastic insert. I love the detail in the Panart kits! I had planned to glue the windows shut so I didn't finish the insides, but the hinges were so cool that I had to leave them operable. Lifeboat Containers The lifeboat containers are vacuum formed plastic. They would probably be fiberglass on the real tug so I left them with their glossy white finish. Stand Kurt, thank you for identifying the Alice E model. It looks beautiful. I found the image in a Google image search. Do you have pictures posted on MSW? I ended up making a stand a lot like yours, but I still have to mount it on a wood base. And the stand for the Coral Sea is awesome! There are more little details on the ground than I have on my whole boat.
  5. 4 Water Inlets Any tug boat experts out there? Why would you have 4 huge water inlets on the deck of a tug boat? I sure don't know, but these were fun to make anyway. The bodies are PVC tube and the tops are laser cut ply. The brass hand wheels were rough but I chucked them in my rotary tool and smoothed them with 400 grit wet sandpaper. They screw into little posts made out of a dowel - the same dowel as the mast. Those posts were hard to drill, center, and align, but I got them right after three tries. The kit includes hundreds of little brass hinge posts that are glued into holes that you drill. I was a little apprehensive of them at first, but they work very well. In fact the lids on these water inlets were fully operable until I glued them into place. I figured that I'd never open them and they'd be dangling loose in 10 years.
  6. Wow, I wish that was available a couple of years ago!
  7. Winch Plans for Lou A couple of weeks ago Lou asked for more details about the winch. Sorry Lou, I completely forgot. The plans for the winch are attached below. The frame is laser cut ply, and the mounting blocks are basswood. All of the other parts are turned brass. The motor is a dummy brass shell with endcaps, but the gears and brakes could all be made to operate if you wanted to go to the trouble. I hope this helps.
  8. Overall View Here's where it stands today. The hull and stack are both primed grey and ready to paint. The engine house and aft structure are primed white and will be painted the same color as the stack. There is a notch cut in the rudder support for installing the prop shaft. I will have to glue the cut out piece back in place and repaint after the prop is installed. Too bad the shaft can't be installed from inside the hull.
  9. Cabin While waiting for my paint to arrive I jumped ahead in the plans and completed the cabin. The instrument panels are made of lacquered cherry, and the planking is finished with 3 coats of orange shellac. Panart supplies a lot of beautiful brass pieces for portholes, hinges, and railings that really dress the model up. They also explain the high cost of the model. So far I've run short of some wood strips, but every brass piece has been neatly bagged and in the box. Here's a view of the bow with the cabin in place. Lots of Little Parts. 208 hours, 160 days. Lately I've been building lots of little, difficult parts. The mast was hand planed to shape from a 12 mm dowel. The brass lights were all supplied. These 13 braces support the deck where the cabin overhangs the lower quarters. The funnels are made of a brass casting on top with wooden supports below. Six life preservers are made from plastic rings and red striping tape. They will eventually hang on the cabin. Six turned wooden barrels were supplied. I painted them, then wrapped them with model airplane trim tape. The fill caps are painted nail heads.
  10. Color Scheme Blues, and Greens The model on the box is painted an interesting blue-green color that has been hard to match. I went so far as to analyze a digital photo of the model, extract the red/green/blue components of the hull color, and compare to color charts from Krylon, Testors, and Rustoleum. The closest match was Krylon's appropriately named "Surf" color, which I was unable to find locally. I ordered a can from a supplier on amazon.com 16 days ago and haven't received it yet. Handy Tip: Don't order from Bic Warehouse. In the meantime I bought a couple other Krylon paints and made some color samples. On the left is "Emerald Green," with "Periwinkle" for the stack. On the right is "John Deere Green," with "Pewter Gray" for the stack. I really like the combination on the left, but hate to start painting until I see what "Surf" looks like. What do you think?
  11. First Coat of Primer The next step in construction is to plank the deck and add a third layer of planking to the inside of the rails. But I plan to paint the outside of the hull first to keep paint off the deck. Here's the first coat of primer. Tomorrow I'll take a good look and fill all the cracks I missed before. Wanted: Ideas for a Stand I won't be able to use my keel stand anymore after I finish painting the hull. I would like to build a stand that looks like a tug up on wood blocks in dry dock. Here's a photo of a different tug model on a stand like I have in mind, but I do want to be realistic. I have searched online for a cool photo of a real tug in dry dock, but I haven't found anything to my liking. If you have have any ideas for an appropriate stand, please post photos or links, or message me directly. Many thanks.
  12. Full Profile View I haven't posted a full profile in a while, so here's what it looks like now. The cabin and engine house are just laying in place. I've built a few fixtures for the deck and cabin, but there is a lot more to be made.
  13. Temporary Decks Removed Two temporary decks made of heavy plywood were used to keep all the bulkheads in alignment during planking. They were held in place with small nails and were easily removed. This is the fist time I've seen the inside of the ship since January. Sub Deck Installed, Bulkheads Trimmed And now the inside is hidden again. A sub deck made of very thin laser-cut plywood was installed near the top of the bulkheads, and then the bulkheads were all trimmed to deck level. I thought that would be difficult, but not with this flexible Japanese cut-off saw. I sliced the bottoms of the bulkheads flush with the sub deck, then gently rocked each piece back and forth with pliers to break the glue joint. I know the insides of the side rails look terrible right now, but after I sand them and add a third layer of finish planking on the inside they'll be fine.
  14. Second Layer of Planking Completed - 120 hours, 122 days I FINALLY finished planking the hull and will soon be moving on to more interesting things. For the first layer I tapered most of the planks, and it took 58 hours. For the second layer I left most the planks straight. It only took 20 hours and it looks much better. In the photo you can see a crescent-shaped area left at the bottom where I had to trim the planks to fit. Helpful Hint - When basswood planks are wet you can cut them with scissors. I wish I had realized that that 4 months ago.
  15. Second Layer of Planking One reason that I chose this model that I wanted to build a double-planked hull. Now I wonder "What was I thinking?" On the first layer I tapered all the planks so that the same number of planks would cover all the bulkheads. That worked out well, but it was a lot of work. On the second layer I started at the top and worked down, with full width planks almost everywhere. I did use a couple of cheaters here and there to keep everything straight. I am now about half way down the hull, and this layer looks much nicer than the first. Eventually the planks will stop way short of the bow, but I think they will be OK. We'll see.
  16. A Major Digression Sorry for the long delay between posts, but I stopped working on the tugboat model long enough to build a sofa table for my son and his wife. The table was based loosely on a design that I found online, but I modified it so that it could be completely disassembled to fit in the back of a Toyota Prius. The table is now safely in North Carolina and I am back to work on the tug.
  17. Bridge House - 86 hours over 57 days The bridge house is framed up in laser cut plywood, and then planked with limewood (basswood) strips. The instructions said to build the whole structure before doing the planking. As soon as I started planking I realized that it would have been MUCH easier to plank the deck before adding the curved rail, and to plank the cabin before gluing it in place. From now on I'll try to read ahead a little. My wife and I are in Florida for a while. She is an author and only needs her computer to work. I tried to bring enough of the Anteo kit, tools, and supplies to keep me busy. But I forgot my drills, and I brought all the wrong paints. So I'm jumping around in the instructions and building what I can. I'll try to sort it all out when I get home.
  18. Windlass The parts for the windlass were mostly turned brass and were incredibly detailed. With a little work and a real motor you could probably make it operate. The brass was so pretty it was a shame to paint it.
  19. First Layer of Planking Completed. 58 hours, 39 days I completed the first layer of planking the other day. This boat is BIG! I don't know where I'm going to put it when it's done. After a lot of sanding, I filled the wood with a coat of Behlen water-based grain filler (available from Woodcraft.com). This stuff has the consistency of yoghurt, it dries quickly, and it sands off easily. I was amazed at how many cracks and depressions it found! You can see all the white areas in the photo. The stern is still pretty rough, especially around the prop shaft. Looking ahead in the plans I realized that all of the interior bulkheads will be removed down to the deck level, leaving a thin layer of planking to the side rails. A single layer of planking would definitely not be strong enough, so I'll have to bite the bullet and add a second layer. But I think I'll set that aside for a while and work on some of the superstructure.
  20. I've never done a double planked hull before, and I am pretty happy with the single planked hull so far. A little putty in the cracks might be enough. Everything gets painted eventually anyway. We'll see.
  21. More Planking We're having a major blizzard today so it's a great day to stay indoors and attach planks. I added a plank down the centerline of the bulkheads. Then I measured the remaining height above the centerline along each bulkhead. The longest segment is about 13 planks high. I divided each segment by 13 to get the height of the plank at that bulkhead. Then I tapered a bunch of planks and let them soak. I am now using white PVA glue along the plank edges and dots of CA at the bulkheads. If I do two bulkheads the CA makes instant pins to hold the plank while the white glue dries. There is much less CA oozing out and my fingers are clean. So far so good.
  22. First Rows of Planking The planking is 7 mm limewood. It's very flexible when it's wet. I glued the first few rows entirely with medium viscosity CA. Maybe that wasn't such a good idea. Now where's my acetone?
  23. Stand and Prop Shaft Housing Here I made a temporary stand that is a tight fit on the keel. The prop shaft housing was made of two rectangular blocks. I taped them to a 3/16" square stick with double sided tape, chucked them in the drill press, and sanded them at high RPM. THen I pulled the tape apart and glued the half-cylinders to the keel over a slot for the prop shaft.
  24. Bulkheads and Subdecks Installed Two subdecks have been temporarily nailed into place to keep the bulkheads aligned while the planking is applied. This will also eliminate any residual warping in the bulkheads. At this point the model totally reminds me of Steze Zissou's ship, the Belafonte, from Wes Anderson's "The Life Aquatic."
  25. The completed model will be 35 inches (890 mm) long. I will build it for display only, not RC.
