robdurant
Everything posted by robdurant
  1. So, another week, and a little more done. I started the launch, which posed a few interesting questions. Mainly, the part no. 7 is shown on the plans as extending from frame 1 right back to either side of the keel, but in practice it stops some way short. Hopefully the pictures will make more sense of this than my description. (It's all dry fitted at this stage): I wasn't quite sure whether it was the keel (8) or the former (7) that was the wrong length, so I thought I'd take a look at AOTS (Anatomy of the Ship book), and see what it showed. It's worth pointing out at this stage that this kit is over 15 years old, so it is quite possible that Panart have fixed this is more recent versions. Some of the other Caroline builders may well be able to answer that question Well, looking at AOTS was a revelation. It turns out that the launch in AOTS is just over 18cm (even taking the 1:47 (kit) - 1:48 (AOTS) conversion), whereas, the model is only 14.4cm or 13.7cm if you cut out the spare keel... The picture below gives some idea of the difference... model placed on top of AOTS: That being the case, it seems that this is simply an area where the kit differs from AOTS, but it does help to answer the question should the keel be shortened... I certainly don't want to make the model differ any more from AOTS by shortening the boat even more, so I've decided to leave the keel as is, and accept that the former (which will be disposed of later in the process) is simply short. That decision having been made, I cut the notches into the frames to allow them to be snapped off once the planking is complete, put electrical insulation tape on the edges of the frames above the notch, and glued the frames on to the keel (putting the former in place, but not gluing it, as it will need to be removed later... Then I began the first planking... It did occur to me that with a picture like that, someone could get the wrong idea about my hobby :S Anyway - suffice it to say the pins are only for the purpose of keeping the planks in place and flat to the frames as they glue. You can see the red insulation tape sticking out - that's simply to stop any glue sticking the planks to the frames above the notches... Hopefully it will keep life simple when the time comes to remove those later. That's it for now. Happy building Rob
  2. Hi all, Just a little update. I've finished rigging the cannon (minus coiled rope that will be added right at the end of the build to keep the deck tidy while I do the rigging... I've also been working a little on the starboard staircase. It's a fiddly little blighter, and I haven't decided whether I can live with the colour discrepancy between this one and the one already in situ - I think I must have used a different wood as it's much darker once varnished :S (see last picture)... I'll sleep on it and see how I feel about it in the morning. I suspect it's going to mean another re-work... Happy building Rob
  3. Time for a little update... The starboard cannon are rigged now. Happy building Rob
  4. Hi Max, Sorry it's taken me so long to get back to you, I've been on holiday camping with the family. I've read through your build log and it will be a fantastic resource for me as I follow in your footsteps... I only hope I can achieve something of the results you've had. The large eyelets I made myself from 0.8mm brass rod. The smaller eyelets and hooks are leftovers from the HM Schooner Pickle kit by Jotika / Caldercraft. It's etched brass. They're brilliant for this sort of thing as they really are fine. Hoping to get a bit more done on the cannon this evening Happy building Rob
  5. Hi, A small update... I've got some more of the deck fittings in place, and spent some time working on the starboard staircase. I've also started rigging the cannon (using some left over bits from Pickle. Given the larger scale of Caroline (1:47 rather than 1:64 for Pickle), and the larger size of the cannon (over the tiny carronades on Pickle), it seems a shame not to rig them fully. Anyway, here's how it's going so far. I made a jig, and so far I've only got two rigged up - it's amazingly time-consuming. I haven't tied off any of the ropes yet, so there's a certain spaghetti quality to the whole thing, but hopefully the pictures make sense. Eyelets in deck ready for rigging cannon 48 x 2mm blocks, 56 x eyelets, 24 x hooks, 16 x rings later and it's just a case of finishing putting them together... More pictures soon Happy building Rob
  6. Hi all, Emelbe: I certainly didn't pick up anything insensitive in your post, so please don't worry - I agree it's a lovely kit, and I hope you will have the opportunity to build it at some point, too. Thanks to everyone for the kind comments and likes. I'm already absolutely smitten with this boat! Do feel free to pull up a chair, and if you have any helpful hints along the way, please do chip in. Rob
  7. Hi all, I've set up the build log for the next project - finishing Royal Yacht Caroline - and here it is. http://modelshipworld.com/index.php/topic/11123-royal-yacht-caroline-by-robdurant-panart-scale-147/ Happy building. Rob
  8. Hi, It's time to start my second build log on ModelShipWorld.com. As I won't be starting this build from scratch, I guess a little explanation is in order. My father started this model, and built it to the point shown below, where the hull decorations were mainly in place, and the deck furniture was mainly built, if not fitted. He passed away in January 2013, and I felt it would be a terrible shame for the model to be left unfinished. The challenge was to get some of the skills necessary to attempt to finish such a kit, so I started with something smaller. For those interested, you can see how I got on here with Caldercraft's HM Schooner Pickle (HM Schooner Pickle.) Anyway, I finished that kit a few days ago, and now I'm ready to begin work on Caroline. Here's a picture of Caroline before I started work (except to go over her with a soft brush to get the dust off) You can see a number of the fittings next to the bow. The first evening's work was to go through the plans carefully and try and get my head around what had been done and what hadn't. I was immediately struck by how sparse the instructions are. Compared to Pickle which guides you through the rigging step by step with great care, the instructions for Caroline stop once you've put the deck furniture on, and just point you to the plans. Thankfully I'll be able to draw on the many excellent resources on this website, and my experience with Pickle. Secondly was that the plans are printed on both sides, and so some time was spent sellotaping the plans back together where they had worn so thin they were in pieces. Once this was done, I was ready to start fitting deck furniture (which had been pre-assembled off the model by my father). An emotional process, but it's lovely to see it start coming together. Photos of progress so far are below: Cleats at the bow, fitted: Capstan, fitted, although I'm not very happy with the gap between the capstan base and the deck, so this will be gently refitted... The support for the flag pole... Steps... And then, just for the fun of it, I dry-fitted some of the other fittings just to give me an idea of how they would fit onto the deck side by side... (cannon, ships-boat supports, etc..) - all of these are dry-fitted (and now I look at it, the sled for the ship's boat is upside-down!) Sorry about the state of the photos, but it will give a rough idea. Anyway. Happy building, thanks for looking, and I hope to be back with an update very soon. Rob
  9. Thanks Eamonn, Mike - kind words indeed. I really like the idea of using black cotton - I shall be trying that on my next build. Eamonn - not quite sure how I managed to miss your post ... anyhow... I've seen it now. Royal Yacht Caroline's next up. I've been sorting out space so I can store it safely while I'm not working on it (a necessary step as I have a 5 and a 6 year old in the house ) Once Caroline's in dry-dock I'll start a new log, and put some pictures up (and add a note on this log ) - watch this space. Rob
  10. Well, there we go. I have still to get the proper camera out and take some proper pictures, but she's finished, and the crew have come onboard ready to set sail. Here are some mobile phone shots I'm going to miss building this kit. It's been a great experience (especially since it was my first wooden kit build!) Thanks to all who have liked and encouraged along the way! Now... I really ought to get some sleep Happy building all! Rob
  11. Quick update... Ships boats still under construction... Slowly but surely ... but it can't make sense to hurry at this stage Happy building Rob
  12. Hi Eamonn, Thanks for the encouragement. Yes, the boats did come with the kit. They're resin mouldings, and they're nice and thin. Rob
  13. And another update... so close to finishing now... just the fore-top yard lifts, sheets, ensign halyard and ships boats to complete. Progress to report: * The anchor's in place... * Backstays, yard slings and trusses are done. * Foreyard lifts are done. * Ships boats are under way Having got this far, I'm a little more aware of places I would have done things in a different order, were I starting again. One of the things I would certainly have done differently is to have put the pendant blocks for the lifts onto the mast top block earlier. It's a blighter to do it at this stage, as all the topmast stays get in the way. I'd also have made sure all the blocks were on the yards (falls included but coiled for ease) before I attached the yards to the mast... (I have a vague recollection that Blue Ensign may well have done it this way, and now I understand why...!) All in all, though, I've never built a kit with better instructions, and more accurate parts... Well done Jotika! A real pleasure from start to finish! (i.e. an appropriate amount of head-scratching and hair-tearing-out for this kind of model -- well, we wouldn't do it if we didn't love it! ) Happy building Rob
  14. A quick update... the bowsprit shrouds and bobstay are on... A bit hard to capture on camera, though. Rigging for the yards next. Happy building! Rob
  15. Hi all, Thanks for the likes... A little progress. I've been putting on the backstays. I spent more time searching the carpet for 3mm blocks than building last night, but finally, there's something (not a lot, but something) to show for it... Main-mast backstays next... Happy building Rob
  16. Thanks Eamonn. Well, the move went well, we're almost out of boxes, Pickle's arrived in her new home from her temporary port. I just spent a couple of hours yesterday evening adding the span for the topping lift, securing the topping lift for the driver boom to the deck (port side of the main mast) and beginning to add the backstays. I suddenly realised that I'm getting there. I spent a little bit of time working on the ship's boats as well. They're fiddly, but not impossible You can see them in situ in the second photo... So far, I've only put some of the ribs in, using the black card. I used carpenter's glue, which seems to work really well as it allows you to reposition things and make sure it's all lined up before it sets. Just for fun, I've added a picture of the wall in my office - a bit of inspiration when I'm working (the WWII fleet destroyer's a battered and bruised old Deans model of HMS Grenville I made when I was a teenager that needs a big refurb, so before anyone says, yes I know it's not even vaguely historically correct - but it is nice to have the hull out of the loft again) Rob
  17. Thanks for the kind words, Eamonn. It's not up to your Ballahoo, which looks fantastic!, but I'm pleased with how it's turning out so far. Not far to go now! Well, Pickle's moved... A few more bits of rigging and a little tidying up... and a picture of Pickle in her temporary home with Royal Yacht Caroline... Happy building Should be in the new house by the time I post again. Rob
  18. Yes, she does look a little lop-sided, doesn't she Time for an update... more standing rigging... * I've finished the ratlines * Made the mouse on each stay that requires one... I did this by wrapping the thread round a plastic tube with superglue on it... This could then be trimmed and glued on to the stay in the right position. I touched up each end with a little paint to cover up the white styrene ends... * Put on the stays on the foremast and the schooner stay for the main mast (these are in place, but only temporarily fixed (by belaying them in the wrong place), before I finally fix the bitts. Pleased with how it's coming on. The Jotika plans and instructions are excellent... even so I've had to stop and think about each stage before I've gone ahead... and even then I've had to undo and retie various bits as I haven't quite got it right... Finally, here's how it looks so far... (sorry about the picture quality on that one) Things may slow down for a while now, as I'm moving house across the country next month. Happy building and thanks for the likes. Rob
  19. Thanks for the encouragement, Jim. A quick update... I've been tying the ratlines... Wow, it's time-consuming I decided to take the ratlines across to the backstay (fourth shroud) too... just a personal choice... Anyway - port schooner mast ratlines are tied. Three more to go! Happy building Rob
  20. I use a mix of an EOS 40D when I want really nice shots, and my Samsung Galaxy S4 phone camera... I was struggling with the picture quality, espcially in the evenings, for build logs, but then I put a daylight spectrum bulb in my anglepoise lamp, and just moved that around the get plenty of light on the subject, and that's really helped Also, if you really want nice shots, then using a tripod, or beanbag with a slow exposure can help get the picture away from the limits of what the camera sensor is happy with, and if you use a time-delay shot, then you won't get camera shake as you hit the shutter button. I tend to avoid using a flash, because it is hard to get diffused light that won't burn out some bits and leave other bits dark, when the camera's so close to the subject... but that's just my tuppence. This is on the galaxy s4 with daylight bulb anglepoise And this is the Canon EOS 40D (with Speedlite 550EX flash bounced off a white wall and ceiling behind) Cheers Rob
  21. I should probably add that I was very grateful to my 4-year-old son for handing me one of the gaffs with the words 'Daddy, I think this is part of your boat', and a very serious face that said... Daddy, you ought to be more careful in the future lol! He may have a point.
  22. Time for another update... Hope you all had a very happy Christmas a new year * Final spars are lathed and ready to go... * Detailing put on the crossjack * Pendants are on (I'll seize them to the foremost shrouds when the ratlines are tied and I'm comfortable everything's nice and taught. and finally * I've started putting on the shrouds... You can see the little pile of jigs to keep the deadeyes in the right place while they're tied off. (32 in all, just for a little schooner... ) As always, all hints, tips and comments are appreciated and welcomed Happy building Rob
  23. Aah, yes. And I meant to say: Thanks Eamonn. Yes, it's moving along pretty well, now. I wasn't sure how the rigging would go, but so far, it's not too bad. A sharp pair of sewing scissors, tweezers and good lighting seem to make all the difference... (although I still seem to need to attempt everything at least five times before it works out the way I'm after. I also realised that one of the carronades was in the wrong place... it would have been in the way of the ship's boat... so I've moved that, too. Must remember, measure twice, cut once! Take care Rob
  24. Thanks Eamonn. Finished off the channels this evening, and put in the belaying pins... Also started putting blocks onto the masts. (Wow those close-ups really show up everything don't they :S ) Enough for now I've got the blocks still to put onto the schooner mast and yards. Happy building. Rob
