Alex M
Everything posted by Alex M
  1. The ruder fittings, eye and ring bolts. The ruder hinges are cut out from solid brass 2mm x 10mm, then filed by hand with a file. The little tool for eyebolts and the process of making (the wire is 0;4mm): The shot lookers: To be continued. Alexander
  2. Hi all and many thanks for your comments! some photos of manufacturing of deck planks with caulking. The first photo shows the complete process. The paper was glued to one surface of the prepared piece of wood, then the piece are cut in to planks. I used the Proxxon steel saw blade 50 x 0,5mm (photo 2). It gives very clean cut and does not need for sanding before gluing. (note an additional piece for fence is that the plank would not be clamped) The planking of deck: the work go on and the deck is nearly completted. The ridding bits and anchor bitts are only dry placed without a glue, and anchor cable is still for photo shooting. The deck of Captain's cabin is done, the planking of after part of hull is completed and lower counter rail also on place. Added some photos: To be continued. Alexander
  3. Hi Ilhan, it is an exceptionally workmanship you showed us here! Alex
  4. Hi Ed, I'm glad to see your log, and many thanks for reposting her as he was on old MSW! It's a great learning for all model builders! Alex
  5. Hi Giorgo, glad to see your builg again! Alex
  6. Hi Remco, I'm happy to see you here, and to follow you great build! Alex
  7. Thank Daniel! The hull was then oiled with linseed oil bellow the main wales: Here some images of gratings, hatches, ladders and gun deck framing, is now completed and is ready for planking. The lower deck is also completed and oiled, the after part is painted black. These are also some close views of main ladder and other things. To be continued... Best regards Alexander
  8. Some images from my home made draw plante with treenails 0,6mm for treenailing the hull, and the tools used for: And here the hull while treenailing: The main wales are painted with acrilic paint: To be continued... Best regards Alexander
  9. There are some pictures illustrating the macking of rails (boxwood). here is short description of scraping process: The width (and as also as possible the depth) of the profile cut in the razor-blade must correspond exactly the width of the strip, otherwise the blade follows the wood grain and does not run straight. With the first 2 to 3 courses the pressure of razor blade against the strip should be low, afterwards step by step with higher pressure. For a profile shown I need 20 to 30 courses, depends which kind of wood. I tried different woods and mostly the results were good, the boxwood I choose because of the color, and due to the fact the timber is very hard, which is an advantage with fine small profiles. The rails in place with gun port and part of main wale. The plankin get close to end: and finally done: Best regards Alexander
  10. Hello all here! I'm glad our World is back! So I start here my build log for HMS Sphynx. In the past life (I mean old MSW...) I have some images added to gallery, so I will post them all here in chronological order with some descriptions. The Sphynx was 20 gun ship designed by J. Williams, and was smallest 6th rate frigate. She was built in 1775 at Portsmouth, Hampshire and broken ap in 1811. The Sphynx-class is also the last class of small frigates with 9 pdr. There are 10 further ships builded: Camilia, Chathan Dyd, 20.4.1776-1809 Daphne, Woolwich Dyd., 21.3.1776-1802 Galatea, Deptford Dyd., 23.3.1776-1783 Ariadne, Chatham Dyd., 27.12.1776-1814 Vestal, Plymonth Dyd., 23.35.1777-1777 Perseus, Randall, Rothehille, 20.3.1776-1805, 1798 convertet to a bomb vessel Unicorn, Randall, Rothehille, 23.3.1776-1787 Ariel, Perry & Co., Blackwall, 7.7.1777-1779 Narcissus Plymonth Dyd., 9.5.1781-1796 For this project I have ordered the original plans from NMM, and I have decided to redraw the plans for model building. For decorative work and also some other details I have ordered the pictures from "Science and Society Picture Library" http://www.scienceandsociety.co.uk/results.asp?image=10325356 . For dimensions of all hull details I have used the Establishment lists, and Steels "The Elements of masting and Rigging" for mast, yards and standing rigging. The running rigging and sailing plan also arrive later. The result looks at time thus: http://zope.mein-media.de/meinmedia/plans/index.html In February 2006 the plans were ready, at least so far that I have begun with the building of the model. Parallel and in addition I have done further research, and the plans are further worked out. Now the images of beginning: The main wales are cut according to plan, and glued on. Then waterway, spirketing and part of planking abowe main wales are added. The model was then put keel over, and underwater planking begins. Best regards Alexander
