Everything posted by Alex M
HMS Alert 1777 by Jaekon Lee - 1/64
Alex M replied to Jaekon Lee's topic in - Build logs for subjects built 1751 - 1800
Very good planking, Lee! How many clinked hulls you have build? Can you show us fotos? Alex -
Perfect mast partner, very fine work, Remco! Alex
- 1,215 replies
- sloop
- kingfisher
I'm sorry if this make you less happy, but the whole is more complicate, as far as I know... The garboard plank was beveled in mostly cases to match the rabbet. As clearly shown in those drawings: http://collections.rmg.co.uk/collections/objects/85449.html http://collections.rmg.co.uk/collections/objects/80965.html http://collections.rmg.co.uk/collections/objects/80745.html here the later practice: http://collections.rmg.co.uk/collections/objects/80704.html and here a couple of frame drawings that show tre rabbet and garboard planks: http://collections.rmg.co.uk/collections.html#!csearch;searchTerm=Telavera_1818;start=10
Hello, the work continues with the gratings and coamings of the quarter deck, and ladder way to gun deck. In this case the gratings should look like "real" and have proper thickness and shape. Follow images show the process. First the upper edge of the block was shaped on this jig: then cuts are done on tablesaw: then strips are glued and the whole was sanded again in the jig: Coamings are build around gratings, ladder way and coaming added: All is dry fitted now. Alex
Chopping block work table
Alex M replied to qwerty2008's topic in Modeling tools and Workshop Equipment
Hi Lextin, I would screw two or three 2x2 inch boards of hard wood (oak as example) to the underside of table. You can also glue them all together before them. Important: bound boards tight all together with ratchet straps before screwing. I have one very similar to yours in my basement as workbench, is very solid and stable. Alex -
Hi Lee, looks very good! It's a lovely little and fine model! According to beams: I would highly recommend to cut them instead of bending. It's not soo much more work. Otherwise this can end with bad surprises later... Now it's a state where you can avoid some problems. Alex -
HMS Sphynx by TBlack - 1:64
Alex M replied to TBlack's topic in - Build logs for subjects built 1751 - 1800
Hello Tom, thanks for warm words about my plans! I have folowed your build of Vinal Haven and should say, that you model looks very realistic. So please do'nt stop! I will follow your build! Alex -
Hello TBlack, nice start! looks like my Sphynx at beginning Alex -
Hi Chuck, excellent planking job! Very clear and smooth! Christian, I'm not Chuck, sorry, but if you look at the image with red painted counter in Chuck's previous post, you will notice a small step between them and tuck. The tuck will be planked later, and all will follow the plan. Very smart solution, Chuck! Alex
- 1,051 replies
- cheerful
- Syren Ship Model Company
