Everything posted by Kevin
each class of sub had its own set of curved blocks, however the old diesel boats had a flat bottom to enable sitting on the seabed, and i remember standard blocks with wooden props to keep her upright
from the photo she looks quite cleans so possibly flooding up, and caught by the gusting winds
good evening Uwe, no race, if i dont have any DIY jobs, dog walking or gardening, or playing Hogwarts Legacy on the PC then i do my boat, it will slow down. but at present im enjoying it,
- 443 replies
- Indefatigable
- Vanguard Models
good evening everyone, the boi is very tired today, but is happy eating and woofing day 23 thank you for the comments and likes busy day in the mancave quarter galleries made up, not being fixed to the hull at this stage, but as an alignment aid the stern builds up but only to fit one piece for now and here it is the two above pices are for now soley to align this up, once happy a pencil line is drawn under it and the wood from the tuck is removed once dry, outside in the sunshine for sanding gunports squared off and first of many red coats going on, god im loving this build, and only another years worth of her left
- 443 replies
- Indefatigable
- Vanguard Models
lovely work BE all that work will pay dividends, im only slightly ahead of you at present
- 648 replies
- Indefatigable
- Vanguard Models
Multiple injuries after ship tips over at Edinburgh dockyard - BBC News
both sides are not symmetrical, so yes i did. its no big deal though, i a weeks time its going to get covered over again lol
- 443 replies
- Indefatigable
- Vanguard Models
good evening everyone first of all thankyou for the comments wrt the the boi, he attended the vets today, and was put under, whilst they did xrays on his teeth and biopsies on his gums, on inspection they do not believe it to be anything nasty, but the results will be back in a week, no teeth were required to be removed, build day day 22 1st planking completed a bit messy in places but it went without any real issues, tomorrow is set aside and get some sanding done
- 443 replies
- Indefatigable
- Vanguard Models
looking good, you will over take me soon
- 587 replies
- Indefatigable
- Vanguard Models
just enjoy it BE, i dont work, i put in as much or as little time on the build as i want, plus playing Hogwarts Legacy on the PC
- 443 replies
- Indefatigable
- Vanguard Models
good evening everyone, thank you for comments and likes day 21 1st planking port side complete i needed to fair the parts 29 on the stern post, so i then continued with a rough grit sanding pad and gave the hull a once over, i was real happy with how it turned out, no where ready for the top coat though i am about an hours work from completing the stbd side, will try and finish that tomorrow, but the boi is in for an operation at the vets, so i might be to stressy for that
- 443 replies
- Indefatigable
- Vanguard Models
good evening everyone day 20 1st planking the bow is 1st planked, - absolutely nothing special, but will serve as a good foundation for the 2nd layer, i look forward to many hours of sanding before that happens the stern will be completed in the next day or so
- 443 replies
- Indefatigable
- Vanguard Models
good evening everyone Day 18 1st planking as soon as i left the make up of the hull, i have had to start thinking about things, and this has resulted in some redo's, lol no matter how much fairing you do, there is always more anyway the hull is is about 50% done and although bit messy in places, i have a sound basis to work on and yes i am still missing one part number 29 stern post filler, and the one fitted need working on
- 443 replies
- Indefatigable
- Vanguard Models
thank you. we look forward to seeing your build soon
- 443 replies
- Indefatigable
- Vanguard Models
everyone is welcome to follow my trials and tribulations of wooden ship building
- 443 replies
- Indefatigable
- Vanguard Models
well im glad you sorted the deck issue out
- 648 replies
- Indefatigable
- Vanguard Models
i use nails all the time and then remove them after the glue has set, the only char removed so far has been for fairing of the hull
- 443 replies
- Indefatigable
- Vanguard Models
they are in now, about an hour ago, thank you for keeping me in check
- 443 replies
- Indefatigable
- Vanguard Models
ty glenn, it did take me a good few hours to get them right, and only then after cutting back the first two under the template and re faing the stern
- 443 replies
- Indefatigable
- Vanguard Models
good evening everyonr thank you for comments and likes day 16 1st planking port and stbd side templates fitted stern tuck, caused me some aggro fot a couple of hours, so the fixed planks were cut back and the stern was re faired allowing the 3rd plank to twist and turn
- 443 replies
- Indefatigable
- Vanguard Models
lovely to catch up on your log, stunning work
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Good evening everyone thank you for comments and likes Day 14 port side Gun port templates fitted well i never expected to be at this stage after 2 weeks, but here i am, and loving it, and i have not had any issues to criticize the build, or instructions, after the hull fairing i test fitted the gun port templets, no other sanding was required the bottom of fwd template forms where the first run of planking under it goes, so a pencil line is drawn, the rest of the plank aligns along the top of the port sill , at this point the template can be removed first plank 2nd plank the after template fits on the top of the 1st plank and lined up with the top right corner of the last gunport, instructions need to be read to be aware of where the glue is applied, as a section of the framework has to be removed at a later date a templete fits between and the area over the ports is covered, using limewood rough opening of the gun ports when the glue has dried
- 443 replies
- Indefatigable
- Vanguard Models
