Everything posted by woodrat
Tom I am concerned you may have rounded of the aft edge of your frame which will mean you may have an unsigtly transition to the next frame, in this case the filler timbers below the transom timbers. I think the aft edge of the chamfer should be sharp and to the line indicated on the plan. Cheers. Dick
The fact that the beams cross the wales confirms to me that Zorzi Trombetta drew his sketch from life and probably while the nave was in drydock( hence the unplanked area between the main wales). This is one of the reasons that I chose this sketch as a basis for a model. Most other paintings are by professional artists interested in aesthetics whereas Zorzi was primarily interested in recording the craft of shipbuilding. Doreltomin. Thanks for the scholarly breakdown on the derivation of Carrack, with which I substantially agree. However, when you say: "The nao being primarily a merchant vessel while the carrack was primarily built for war", it does not take into account that in the late middle ages, mediterranean round ships ( naos or naves or nefs) were sometimes hired or recruited as warships even though they were built as merchant vessels. This is because it was soon realised that the high freebord of the round ship was a great protection against the low slung galleys of the corsairs. Only later were purpose built round hulled warships developed. It is a fascinating topic, isn't it? Dick
nil desperandum, Tom. No need to remake the knee. Much as Karl has shown, after you have completed and fitted the transom timbers, fashion piece and last 2 frames, simply fit some timbers below the lowest transom beam and shape them in situ with your friendly Dremel drum sander. Dick Another point. Please note there is a step at a slightly lower level for the step of the forward half of the full frame. It also has a hole for a dowel. You do not appear to have done this.
Tom, I highly recommend that you construct frames to rigidly hold the stem and stern posts. also take care that the keel is held by wood planks which go almost up to the rabbet line of the keel. here are some photos of the ones I made stempost clamp sternpost clamp. Note the allen key in the top of the clamp to tighten the bolt thereby holding the sternpost down. This will reduce the risk of twisting of the hull over time :) Dick
Many thanks, Christiano. At your suggestion I have renamed my log. S. Penzo's nave tonda is magnificent and puts mine in the shade. I have his book. I did try to contact Signor Penzo a couple of years ago but he did not answer the email. Maybe I should try again. One of my ambitions is to work up to a fully framed nave as S. Penzo has done. But it is a massive project. Perhaps I could do the Contarina I ship. At least the plans should be available. I will soldier on with the Trombetta nave tonda. Dick
Sorry, Steven. I cant access that link. But I think I know the image referred to. As you allude, many models of carracks underestimate the length of the mainyard which is made of two timbers fished together like lateen yards. Here are some pictures showing the bracing for the transversal bitt. The bitt is not bolted in but is wedged in placed. This allows some slight movement of the bitt which protects the side timbers. It also allows removal of the bitt if required. the stern timbers incomplete Dick
These pictures show the transversal bitt in place although not fixed in place. These bitts were a typical feature of the carrack and were probably not meant to be rigidly fixed to the toptimbers. They were however quite massive. Here is a picture of the Mataro nao showing the transversal bitt. This shows the step for the foremast Dick
Thanks, Vivian and Steven. Here is the progress of planking to the level of the turn of the stringer at the outer end of the floors Fitting the stealers stealer glued in position planking complete to first stringer Here is another similar carrack. Note the triangular topsail and the forward positioned foremast. I will base my rig upon this illustration Dick
Thank you for the link, Nenad. The model shown is certainly a venetian carrack and is quite old. It looks somewhat like the carracks in Jacopo de Barbari's panorama of Venice. Good idea to get information or pictures of models from Dubrovnik, Split and Rijeka. They, as you say, were on venetian trading routes for centuries. The Trombetta nave certainly would have visited them regularly. Cheers Dick
Thanks Tarbrush, Bob and Nenad M. I am learning more and more about carracks. For instance, this carrack forecastle from late 15th century shows how the carpenters built the framework for their awning assymetric to allow for the foremast. This may explain the somewhat bizarre appearance of this framework on the Trombetta drawings. The position of the foremast also forced the positioning of the bowsprit to one side or other of the mast. These were no nonsense working ships and often aesthetics took second place to practicalities. also, as this illustration from the battle of Zonchio shows, round ships were often co-opted as warships in mediaeval times as their high riding hulls gave them a height advantage over galleys. Cheers, Dick
Thanks, Michael. Most kind in you. I certainly would recommend doing the longboat for your Wasa. I found the ship's boats a very satisfying part of the build and building it over a mould is easier than you think. Great work on the Wasa too. Dick
I am unhappy with two things on my previous model: 1. the tumblehome aft of centre is insufficient 2. There is a more horizontal run of planking to the fashion piece and a more vertical run to the sternpost leading to a more complex shape to the stern. I will modify the full hull version accordingly Dick
