JOUFF
2 Followers
About JOUFF
  • Birthday 05/12/1953
  • Gender
  • Location
    France
1,737 profile views
  1. Bonjour, Très beau modèle, une réalisation parfaite ! Un très grand "BRAVO" ! Patrick
  2. Well done, congratulations ! Thank You for the photos. Patrick
  3. Hi Chris! Nice work, your construction site seems very well done. You are progressing well and you will achieve a very precise assembly of your frames. Keep it up, it's very promising... Patrick
  4. Hi Chris! This is great progress ! Your work seems very well done and you will take a lot of pleasure in seeing your hull build up... Continue on this path, take maximum pleasure and satisfaction. Patrick
  5. hi Ben I used the same technique but with a lighter wood paste. Patrick
  6. Hello Gentlemen ! Continuation of the work with the manufacture of a small tool that will make my job easier for what is to come ... The photos speak for themselves : I had to help this tool with pliers : the nails tended to escape ! But it works and will help me. See you another time ... Patrick
  7. Good morning all, Few advances on the model ... Here are just a few photos to show the current stage. See you later for the rest of the adventure. Patrick
  8. Hello Gentlemen, Thank you for your feedback. The Leds ramp is now definitely in place : The false deck is glued. Here is a lighting test. The brightness satisfies me : the goal is not to let it light up permanently but to be able to show the inside of the hold on occasion ... So let there be light : So much for this day. I enjoyed myself ... Patrick
  9. Hello Gentlemen ! It was a long time ago, wasn't it ! I had "lifted my feet" certainly but despite all the work continued ... A big piece for me: the false deck. I was not sure how to do it. Finally, I decided to do everything by hand : cutting the slats, adjusting them, sanding etc ... Some photos of the successive stages : A small patina, nails : I decided to make openings in different places where there is something to see. The upper decks will also be opened to show the structure ... To summarize : the wedge will be visible through the frames and on the opposite side we will see the structure in "plunging" mode. I make the openings : The false deck in place - not glued - to see what it gives : I also wanted a lighting system for the hold and the deck. I had not shown you these photos where I installed some micro-leds in the bilge to start : All this being practically invisible from above : I continue the lighting work with a whole ramp of leds, embedded in a slat, so that they are not visible when we look between the frames : That's it for the moment. The continuation next time ! I wish you a good day ! Patrick
  10. Hi Chad ! It was not easy to install these windows : it took me almost 3 years to get all the permissions and be able to bring a company for installation. Have a good day. Patrick
  11. Hello gentlemen, Small progression ... That's all for today ! See you later ... Patrick
  12. Good morning all ! The work continues slowly. I'm still in the hold, the walls are taking place little by little ... To follow in a few days ... Have a good day ! Patrick
  13. Hello gentlemen! The renovation work on the building is now complete. I retrieved my balcony and reinstalled the workshop. Everything is ready for the rest of the project "La Renommée". To follow.. Patrick
