Maury S
About Maury S
  • Gender
  • Location
    Fort Worth, TX, USA
  • Interests
    Member: Nautical Research Guild
    Current Build: Emma C Berry as a Schooner
    Recent Builds: C. Chase, Centerboard Schooner, Anchor Hoy, c. 1825
    Echo Cross Section from Admiralty Models
    http://modelshipworld.com/index.php?/topic/513-echo-cross-section-by-maury/
    Long Boat from MS http://modelshipworld.com/index.php?/topic/2284-longboat-18th-c-by-maury-modelshipways-by-Chuck/
    Fair American (POF) from Laukstreet.
    http://modelshipworld.com/index.php?/gallery/album/203-emma-c-berry-132-pof-by-maury/
Contact Methods
  • Yahoo
    mstuffmann@yahoo.com
4,871 profile views
  1. Druxey, I did a bunch of research into the type faces of the period. Pretty close to the evidence we have, Maury
  2. Back in the shipyard for a while. Working on lettering and scroll work for the trail boards. The name boards and trail boards are cut from .015" laser board. They are painted gold so the color shows through the decal. The surrounding areas will be painted flat black. The two names on the right are still on the decal backing and have not yet been attached. Maury
  3. It's time to take her off the building board. The support system is a pair of cradles similar to the cradles for my Centerboard Schooner Post 302 March 21, 2021. I start by tracing the #4 and #17 frames from the plan sheet and transferring that pattern to card stock for rough fitting. The lower part of the frame is close to the shape of the hull at the points where the embedded nuts are located. After that, I copy the shape to some 1/32" box for final shaping. Since the ECB is built on a sloped jig, I measured the distance from the top of the jig and the building board at the two mounting points and transferred that measurement from the keel slot to the bottom of the rough cradle. The scroll work will be done later. Maury
  4. Scotty, ...and of course you're going to serve the ring, right? Maury
  5. Yves, Thank you. That is my next choice. I have a jar in my collection. Maury
  6. Re. material... the bolts react to a magnet. They contain some iron, obviously. Could be some version of stainless. I had hoped BlueJacket's nickel blackener might work, but NO. Any other ideas are appreciated. Maury
  7. I too am waiting for my recollection to improve. Maury😊
  8. BTW, regarding the tiny nuts and bolts blackening...The nickel blackening solution does not blacken the bolts. I can use paint. Maury
  9. see post#244 for use of Serv-o-Matic: https://modelshipworld.com/topic/28039-emma-c-berry-by-maury-s-148-scale-pof-rigged-as-schooner/page/9/#comment-974182
  10. Serving the shrouds: I have been using Syren's Serv-o-Matic for years now. The only modification I've done is to put a key into every place where the brass tube goes into the gear to prevent slipping. Easy to use, and I can only do about an hour at a time due to eye focus strain. I run the serving thread through the rope (with a needle) near the left side, tie a couple of overhand knots, then serve to the right. The rope is held in the tube with alligator clips (with heat-shrink tubes over the teeth). I make sure the serving is going the opposite lay of the rope threads and maintain a mild tension on the serving thread. Maury
  11. Chuck, I get the sense that you REALLY enjoy doing this. It's a major accomplishment to design and prove out these projects. Kudos. Maury
  12. Allan, I don't know. I have a Nickel blackener that I'll try, then it's paint. Maury
  13. My partner gave me a kit of small nuts and bolts (washers, etc.) for watch and glasses repair. It comes with 6 drivers that is all he wanted. I haven't tried to blacken anything yet, but for about $20, there must be hundreds of these things that might be useful. Label reads "King'sdun" Maury
  14. Yes. Grommets are just paint dots, drilled through (hat tip Druxey). They will be mostly obscured once the sails are furled. I played with folding a sample (practice) sail and I think it will come out fine...we'll see. Connecting the sails to the mast hoops will be a challenge. Maury
