Everything posted by kpnuts
Hi all I decided to give this one a go, it's actually a very nice kit and at 12.99 cheap. Here's the box instruction booklet and my start on it. I intend to put it on a base in a very rough sea.
all well I've fixed the foremast and strengthened it with a rod up the middle, making it a waterline model had an unexpected problem to it the main mast locates in an I shaped piece which is glued to the bottom of the hull to keep the mast central and true since I cut the bottom of the hull off obviously that locating area was no longer there also the mast was a lot higher than it should have been, luckily I still had the bottom of the hull that I cut off so I put the mast in it laid a rule across the hull and marked where it cam on the mast and cut that piece off but the mast is tapered at the bottom and the holes through the decks must be the same size as when I put the mast in it Leaned either way so I had a cunning idea and wrapped masking tape round the bottom of the mast till it was a snug fit in the bottom hole ( only problem now is the mast seems to lean sternwards) so now I just have that problem to sort and of course to make sure it is square with the center line as well.
Wow looking very good, I like the ultra marine too, I think that would be a good choice.
- 961 replies
Blimey this is some attention to detail you must have the patience of a saint.
- 2,686 replies
- heller
- soleil royal
(and 9 more)
Hi all well I've detailed up one of the ships boats (I suppose that means I will have to do the other one now)here's the before Put the bathroom sealant on and started painting the tops of the waves Loads more wave painting to do. I've removed a couple of the guns to load the supplies into I understand they used some sort of pulley system from the spars to load the supplies with and I want to depict that has anyone got any detailed drawings of how this was achieved. I've only used one of the port and starboard anchors, I'm hoping the other two are spares, I can't imagine they used all 4 anchors or am I wrong.
Well I'm livid I was hoping to finish this tonight (so close and now so far) I picked it up to turn it round to do the rigging on the left side of the second mizzen sail and it slipped from my fingers, if I'd let it fall it would probably landed on the floor on it's stand with no damage instead clumsy me tried to save it I broke the bowsprit (again) it took Supreme control not to hurl it at the wall I've managed to create a heath Robinson collection of weights and threads to pull it all together and get all the rigging true (the dolphin striker will be a bit twisted though) I'm hoping when all set it will still all be true and I won't have to strip all the rigging off and start again. I really am cross, I mean really cross, I came so close to finishing her grrr.
- 87 replies
- thermopylae
- revell
Hi all well this is shelved again for a while I've broken the (I don't know what it's called) the bit that tensions the bowsprit, I'm not actually sure how to fix it as it's very thin plastic and superglue doesn't seem to work I'm so annoyed at my clumsiness, this is the fourth time I've broken something on this kit. I will fix it, it's just annoying.
- 87 replies
- thermopylae
- revell
Hi all, well that's one mast finished, only 2 more to go.
- 87 replies
- thermopylae
- revell
Hi all here is the next update I'm actually quite shocked and proud, my missus just said you can't stick that in your junk yard(what she calls my spares room)she said I just can't think where to put it, maybe we could get a display cabinet.
- 87 replies
- thermopylae
- revell
Hi all here is the next update seems like a lot of rigging on this but it's nothing compared to the soliel royal, and I've barely started this.
- 87 replies
- thermopylae
- revell
Hi mate the instructions show same side they even give the belaying pin number.
- 87 replies
- thermopylae
- revell
Hi all here is the next update I noticed a split in the vac form mizzen sail and was going to patch it with a stitched square then thought I would experiment with some super glue. Unfortunately the superglue made the weathering go white but a coat of acrylic white and you would never know. I've finished all the ratlines on the forecast
- 87 replies
- thermopylae
- revell
No still got the shrouds on the mizzen to do also all the upper ones, so much to do, so little time.
- 87 replies
- thermopylae
- revell
Hi all well this is back on the bench, and here is the progress so far.
- 87 replies
- thermopylae
- revell
Hi all well this is back on the bench (hoping to finish it by October, a bit optimistic butbi will try)
- 87 replies
- thermopylae
- revell
Hi all well it's finally done being completely honest I think it's ended up looking very boring, I think I should have picked a different super hero, like the incredibles or maybe the fantastic 4 I would have weathered it with differing shades of black for the different panels as someone did suggest but I don't think I've ever seen a bat vehicle that wasn't perfectly matt black or perfectly gloss black. Anyway here it is, at sometime in the future maybe I will revamp in another colour scheme.
Hi all as I said before attempting to get some models finished so I can devote all my attention to the ducati. This is nearly finished now (just the rigging to go) I've decided not to put the other lifeboats on (may even remove the ones on there and add something else) I've also decided not to paint the railings to add a bit more interest, if I change my mind they will be red, anyway here are pics of where I am now. My next one to finish will be the Thermopylae. Thanks Steve glad you like it, I have very little time to look on the forums or build for that matter (life is so hectic at the moment)
