drtrap
Posts posted by drtrap
  1. Hi Stergios,
    The pillars came as seperate items to the board and therefore can be placed wherever you like. I pinned one to the board and sunk the other to get correct waterline. Same effect could be had with different height pillars but couldn't find suitable ones in stock.
    I had to file the jaws pretty extensively with my dremel to get a correct snug fit to the keel though.
    Jim
    Thank you again Jim.
  2. Can only speak for my experience, but I'd stick with woodfiller, I use the fast drying stuff which is very easy to use.  Glue isn't really made to fill gaps in the way you need it to, so you'd probably still have indentations when its dry that need to be taken care of.
    Thank you Jason.
    Any recommendation on the type of fast drying stuff?
    You know, local products are'nt the same and personal experience is highly required..!
  3. I used the .25mm line.  On your question on the front patform, who am I to judge  :huh:   There really seems to be no guidance, I made the assumption that the deck would fit around the bowsprit, but there are still gaps.  Maybe just see how it looks with the bowsprit in and you can decide if you like it or not?
    Thanks again Jason.
    I thought that you used the 0,1 line, I think I read yesterday your thosedays post....
  4. Nice little arsenal you have there Stergios!  I had much more fun with the cannons than the carronades.  Bottom line, there is very little room on the deck at the stern, the plans are hopelessly out of scale, and you're right it does take some playing to get it all making sense.  One thing that can buy you some room is to reduce the height of the ladders so they remain flush with the aft platform decking - there are some photos in my log which may help http://modelshipworld.com/index.php?/topic/509-hms-snake-by-beef-wellington-caldercraft-scale-1-64-first-wooden-ship-build/page-21#entry95246.  Apart from being a bit more intuitive, this also has the benefit of giving you a bit more space.  The tiller ropes do come very close to the ladders.
    Yes Jason
    I tend to reduce the height, I placed the ladders uncut and temporarily....
    I can imagine you've opened the holes for the breeching so close to the eyelet's hole for the wheel....
  5. So realy difficult to place all the deck fittings back here...
    Especially to find the right spot to drill the front holes for the eyelets of the wheel rigging, because of the holes of the last caronnade.
    I think I need to study your previous photos mates!
    The fittings are placed temporarily of course...
  6. Hopefully these help, view from the top and bottom.  Unfortunately these are assembled so its difficult to get a clear view.  You can see in bottom picture how the bed sits on the cross bar and the axle frame so that the small slot sits on the bar.  The quoin sits on top of the bed, see top picture.  I shaped this a bit so it is a true wedge as it would have been, its important to get the quoin placed and shaped correctly to allow the barrel to align correctly.
    One thing to note, the hole in the cannon barrel that wire is inserted in to make the pommelions is not centred, which is historically accurate.  Before gluing the cannon barrel into place, I'd play around with the quoin and the cannon barrel to make sure that you get the alignment you want on the ship.
    ...everything is so clear now.... :)
    Cheers
  7. Stergios, the bed is the larger of the two wedges you have cut out, the smaller is the quoin. There should be a small groove at one end, that sits on top of the metal rod you've already fitted, the other sits on top of the rear axle frame. Hope that helps.
    Thanks Jason, I'm still trying to fit those tiny parts. I;m not so sure about the orientation of the quoin.
    Should I place it onto the bed or "in line" with it? In a vertical or horizontal placement?
    The instructions are'nt so helpful, as you know....
