drtrap
Posts posted by drtrap
  1. Before I go, three basic questions to know in advance:
    a) Have you used 1 brass wire for the respective connections or something thicker? The No 145 on the right, could be No 146 1,5mm wire?
    B) Have you used the casting material of the kit for the boom rings of the yards (No 152, 153) or card-paper or stirrups?
    and
    c) I'm not seeing any of those "caps" (at each end of the yard) into the kit... Is it something important? Can I deal without its existence?
    Thank you in advance again
  2. Rigging of main and preventer stay collars finished
    Now its time for the next turn.
    I'm thinking to leave the bowsprit mounting and other relative fittings for a later stage because I want to avoid any unexpected "injury" of those parts.
    So my plan is to continue and accomplish any other "posterior" and "vertical" rigging is now available, and to leave the two final stages of yards and bowsprit for the end.
    I'm not so sure what;s your experienced opinions for my thoughts...
  3. Thank you all guys!
    @Jason thank you for your advice, everything is placed temporarily for the moment. Putting the bowsprit on and off the board enable me to proceed to the realative rigging anf fittings but in the other hand to store the ship into the custom-made anti-dust naylon bag, every time I'm away the shipyard .  ;)
    I consider as my 1st permanent step, doing the gammoning.
    Thank's again.
  4. Sjors, Alistair and the 'likers' appreciate your continued interest and support.
    Small progress update, finished rigging the bobstays and the bowsprit shrouds.  Boomkins made up but not glued yet as there was the potential to interfere with the bowsprit shroud.  These will be left off until later as they just seem too much of an accident waiting to happen.  Instructions indicate these should be made with 4mm dowel but even with tapering it looked far to thick so made up a set using 2mm dowel tapered slightly at the end which seems more consistent with pictures I've seen.
    attachicon.gifIMG_0550.JPGattachicon.gifIMG_05
    The 3D placement of the boomkin is a real head-ache Jason.
    Did you finally find its permanent orientation?
  5. Hello again to all the "snakers".
    Well guys as all we know plans are so confusing almost all the times so I'd like to ask for your advice:
    a) rope C is tied to the boomkin (a distal groove on the boomkin is advisable)?
    B) B2 rope is linked to the p1 deadeye and b1 to the p2, or the opposite?
    Thank you again in advance.
    I think I'm seeing a kind of block at the edge of the the boomkin on plan 3 and 6....
  6. After so many days I realize that 3,5 mm deadeyes were needed for the respective bowsprit fittings and not the 5 mm I attached yesterday..... :P post-944-0-18650900-1473601433.jpg
    Except that, a three deadeyes proximal block is important to be noticeable by the plans to the follower builders...
    I recosrtuction procedure is on the road... post-944-0-89406100-1473601445.jpg
    Of course a final touch-up and paint finish will follow...
  7. Janet B
    Hi Stergios
                     Thanks for the answer i tried Cornwall Model Boats but they had non left in stock so they put them on back order,i think that they are better than the ones in the kit.
                     Good luck with your build hope mine comes out as good as yours.
                               Regards Janet
    Thanks Janet
    Waiting to see your progress and pics from your build.
    Keep in touch.
    Stergios
  8. Hello again
    how you probably remember I've attached temporarily main topmast main & preventer stay (see #821 pics).
    To continue to the other main and preventer stays I need to have the bowsprit mast in place.....
    What's your suggestion, 1] to place and fix permanently the bowsprit mast first and 2] fix the other fittings of the area (boomkin, etc) and 3] drill the stem for the respective holes afterwards, or to proceed with adifferent way?
    Thank you.
    Stergios
