Posts posted by drtrap
- egkb, Beef Wellington and mort stoll
3
- jim_smits and mort stoll
2
Hi Snake-partners
May I ask you about those J-L-B-J fittings..... those are two seperate sets of fittings/ropes or a single one with all the blocks included?
Any idea or tutorial on how to deal with them?
Thank you in advance!!
Stergios
...any help for the J-L-B-J block-complex guys?
I can't find any tip...
Thanks again.
Seems a good approach Stergios, good luck.
Hey Jason
thank you for the support!
Hi everybody
the yards factory has started.
Thinking to go with the blocks first and to continue with the foot ropes.
I'll leave the section of the irons for the final stage.
I hope to have your agreement on those steps.
Thanks
PS: The main yard with its marked blocks-ropes and irons attachments.
I'm thinking to fix three foot ropes at each half yard at a distance of 2,5 cm.
- egkb, mort stoll, Beef Wellington and 1 other
4
Nice work and very fitting, I assume these are for port and starboard yards, as you know you only need one per side, with a boom ring at each end.
Looking good.
Frank
Hi Frank and thanks for the comment.
Those are just two dowels dummies just to stimulate in practice yard's and stunsail's assembly.
The real dowels are in a safe place!...
- Ryland Craze, foxy, Robin Lous and 3 others
6
Thank you Jason.
I know that you follow the whole literature regarding the rigging and the other procedures.
have you any idea about the distance "x" between the yards and stunsail boom?
I think to go with the second method (no space between them) to fit the irons.
Cheers.
My main concern is about the strength of those 0,3mm strips against possible tension and other forces from the rest of rigging etc...??
Of course I'll stabilize the yards to the masts using 1,5mm brass wire.
The second method is by calculating the distance of every circle for the iron using the yard diameter and the rule of "3,14"...
Here without space or distance between the yard and stunsail dummies...
The iron for the yard first using clockwise turn
I've used a tape to stabilize the two dowels how you see
Here is the counterclockwise turn for the iron of the stunsail, from a posterior view
And the anterior view
Thank you for your comments in advance, just to help me how to proceed.
I'm quite satisfied from my first attempts to stimulate the boom irons.
This is my 1st cut strip of 22mm to stimulate the irons.
I've tried two methods just to see wha's the best for me in practise...
I'm showing you the consecutive steps of the first one. I think that these steps is easy do be understood.
Making the iron of the yard dummy
and after that the respective one for the stunsail dummy
Taken from another angle...
Could you tell me what;s the indicative best distance "x" between the red lines, for my Snake??
Another pic
And here you are the preliminary result..
Of course in need for iron soldering
Thank you Jim
for the mo I spend my time trying to find the right way for the yards boom irons.....
Not sure if it's of any use for you, but I found a nice image of a truck in a book about masts and rigging..
With one or two holes.
Thank you Robin.
Welcome!
Stergios
@Jim: Thanks Jim, I'll be waiting...
@Jason: by looking your #656 post I see that you decided to replace parts No 152 & 153 with styrene or thin card...
Hi Stergios,
The item you have indicated with the yellow line should be on the photoetch supplied with the kit. If they are the same (which is likely) as in the C.C. Cruiser kit the rounded portion is too large and the flat portion too wide,easily fixed with a small file. I had to reduce mine by about 1mm to fit with the yardarm end dimension given on the Cruiser plans and approximately halved the width of the straps as they looked very out of scale.
The trucks are for the Topsail Yard ties which should be led through them. They are lashed to the aft Topmast Backstays,their position should be shown on the rigging plans.
Dave
Hi Dave
Finally I've found those parts, I'll try to test their dimensions tomorrow.
Thank you!
Btw do you think that the brass wire No 145 on the right side of the photo/plan (post #860) is in fact 1,5 mm brass wire (No 146)?
Thanks again.
Thank you Jason.
Any additional help about the post #860?
HMS Snake by drtrap - Caldercraft
Posted · Edited by Stergios
That's my 1st (main) yard with its boomsail irons in place.
I'm quite satisfied witht the initial results.
Thank you.
PS: The 3mm dowel is just a guide for the right placement of all the irons. A 45 degrees inclination is required.
