Posts posted by drtrap
- KARAVOKIRIS, Ryland Craze, J Harreld and 1 other
4
- Beef Wellington, mort stoll, BenD and 1 other
4
On 18/6/2018 at 3:27 PM, Beef Wellington said:
Hi Stergios - my apologies, I used the wrong words in a hurry. The bowsprit does need to be fitted as you describe for the main, preventer stays to be completed. There is also a fair amount of standing rigging on the bowsprit that I would suggest doing before you do that. I think I actually did the bowsprit standing rigging before actually starting the mast standing rigging working from the stern.
What I meant to say above was that its not really necessary to attach the jib boom at this point - makes manipulating the model much easier as the jib boom seems to be an accident waiting to happen. Good Luck!
Hi Jason and thank you again.
I think I've finished with the standing rigging of the bowsprit. The rest of it's rigging, needs to have attached the bowsprit to the ship.
Pic to follow...
So (excluding the jib boom, I strongly agree with you), what's in your opinion the very first point to start with working the rigging form the stern?
Cheers.
Stergios
On 17/6/2018 at 5:59 AM, Beef Wellington said:
Bowsprit standing rigging does not interfere with the other masts - I also started from the back.
Hi Jason
To my knowledge, to be able to put and finish the stays (main and preventer) I have to fix the bowsprit dowel in advance.
Am I wrong somewhere?
On 15/6/2018 at 8:41 PM, Davemc said:
I worked from the back having first put in the stays
Hi Davemc and thank you.
To put all the stays correctly you have to attach the bowsprit mast in place, right?
Hi to everyone.
After the final trimming of the yards I'm showing you the latest picture of the ship and this way the stage of the current construction. Sorry for the anti-dust cover
Now, I really need your recommendations on "how to proceed, next":
working on the standing rigging ?, working upwards (and outwards)?, leaving the vulnerable bowsprit and its rigging for later? Doing something else?
Thank you in advance.
Stergios
- Beef Wellington, BenD, egkb and 2 others
5
These days the yards dpt is working hard to achieve the best possible balance and footropes-symmetry.
Stay in touch.
Nice work Davemc!!
Where did you buy the wood-base from?
Thanks
20 hours ago, drtrap said:
Davemc, jason, thank you so much.
I've prepared two rope-specimen (using watered pva and floor varnish respectively).
I'll inform you about the final results...
Well, i think that the floor varnish is the best option to stabilize ropes and footropes and give a natural sense of the whole creature.
Removing the pins-counterweights from the pva hardened rope leaves a rope sticky spot at the place of each pin which is totally undesirable....
Hi again Davemc.
I'm seeing that ypu have finished the standing rigging, am I right?
What's your plan for your next steps?
Placing and fixing all the yards permanently or fixing the yards of each mast working from bow to stern for example?
Thanks.
9 minutes ago, Davemc said:
i use counter weights
Did you use any watered carpenter glue or floor varnish as a hardener for the footropes?
Cheers
On 6/3/2018 at 10:28 PM, Beef Wellington said:
Very good Stergios, just catching up on your work. I really need to get back and finish my Snake...
That would be great Jason...
2 hours ago, drtrap said:
Hi friends.
A questionn in brief, for the spritsail...
Do you suggest to fix it to the bowsprit (using a 1mm pin etc as for the rest of the yards) or leave it hanging alone with the attached ropes and blocks?
I did it!
Hi friends.
1 hour ago, Davemc said:
Rotate the pictures on your computer before you download them to the site
Can't rotate and re-rotate everytime my computer's gallery.
The point is to fix this abnormality inside msw.
HMS Snake by BenD - Caldercraft - 1:64
Posted · Edited by drtrap
Nice try Duncbe.
