Posts posted by drtrap
- GuntherMT, Dimitris71 and egkb
3
Well Jason, it seems that you'll start your third one before I finish my Snake....
- Beef Wellington and mtaylor
2
- mort stoll, Beef Wellington and egkb
3
If you keep it as it is you shouldn't encounter any problems in future stages of rigging...
...but, personally, I would move the the futtock stave to keep everything looking consistent. I feel that I've spent so much time and effort on my model already that I know that I would be very unsatisfied at the end if I let something go that I know I could have fixed. But that's me...
The revision has begun....
Jason I think that you can answer that betterI think only you can answer that Stergios
Don't think you will encounter a specific issue other than visual appearance. Maybe try to put the yard in place to see what it looks like and whether you are comfortable. Last night I fixed a couple of ratlines which was very challenging given other rigging now in place, but it could be done, its just down to your own appetite.
cause you're so many steps ahead and - this way - you know better.
As you know I can't follow only the plans and I'm not so sure about the way and the height the yard will be fixed, so your experience on her is my only compass to proceed....
I'm trying to see in the meantime Jim's "yard section"...
I'm waiting to see your suggestions my friends.
It's very hard (how you know) to dettach all those components for create the futtock stave at the very next [lower] rope-step....
Hard to tell from the photo, but the foremast futtock stave looks to be the one that is a little high based on where the cheeks are, although it should only be a visual thing. From pictures I've studies, the futtock stave is at a very similar level to the yard when in position, as the catharpins helped keep the shrouds from interfering with a yard braced round. If the yard does not interfere with the shroud then I think you should be OK...
You're right Jason, here are the relative futtock stave to cheeks heights...
Do you consired that as a huge penalty or I can live with it?
Should I stop and re-align the futtocks stave?
I'll try to apply a custom made solution.... I hope...
3
Hi Stergios, I'm sure you have a lot of distractions, hope you're doing OK and able to find time to continue building your Snake. Best wishes.
Hi Jason and thank you.
Everything seems better now but with a huge ammount of tax compansative measures. We'll see...
Cheers Mort!
- Beef Wellington and egkb
2
... and now, let me present you my personal modification for the fore lower mast catharpins...
in photo steps....
How you see, I've used the serving machine to prepare catharpins of equal length, I'm not so happy with the non-served eyes, but their fitting is'nt so visually detected especially after the placement of the futtock shrouds...
- mort stoll and egkb
2
2
Well, I think that looks great Stergios. Glad you got it sorted.
Thank you Jason.
Futtock stave was a great challenge to me some time ago...
I decided to follow Andy's excellent work on it and now everything it's fine...
- egkb, Beef Wellington, Dimitris71 and 2 others
5
- Dimitris71, Beef Wellington and egkb
3
Stergios,
The futtock stave should be the same distance below the top as the mast cap is above the top. I normally tack the stave to the shrouds with dots of super glue, then properly hitch them. They don't move around that way.
Looking good.
Hi Joe
the way of "hitching" is the hot stuff, I think.
Any drawing or pic to help?
Thanks
........................... I just used a simple clove hitch on an angle across the stave and shroud, I would also alternate the angle: / or \, to keep the thing from twisting too much. Tie off three or four to start (spaced a couple shrouds apart). That will be enough to hold the thing in position. Let the glue securing the knots dry, cut the leftover ends and tie a few more......
Hi Andy
I'm trying to understand the whole procedure but without success...
Could you please help anyway?
Thanks in advance.
Stergios
I struggle with the deadeyes of all things. What diameter are the deadeyes on Snake please?
The deadeyes are 3,5 and 5 mm.
Thanks
Jason, Joe, thank you for your time and assistance.
I'll try to "translate" your suggestions in practise, very soon.
Stergios
My latest concern (still for the futtock stave placement):
1) the way to attach the futtock stave on the shrouds. I'd like to perform a kind of rigging (using clove hitch knots ??) for a better stabilization of the staves...
2) the right "height" of futtock staves placement. Following strictly the height/distance from the plans, in my case the runway of the futtock shrouds seems to be in a more perpendicular way, so I can't simulate the sharp angle "a" of the plans. Do you suggest to place the staves two ratline steps higher?
Cheers.
Stergios
- jwvolz, Dimitris71 and Timmo
3
- egkb and Dimitris71
2
HMS Snake by drtrap - Caldercraft
Posted · Edited by Stergios
Now I'm one turn before the trimming of the ratlines and I'm thinking already what to do next...
...continue with the other/upper thirds of the fore, main and mizzen masts or fix the bowstrip and its relative fittings?
If you have any experienced idea on this, please show me "the way"...
Thanks
Stergios
