Posts posted by jablackwell
- augie, ccoyle and avsjerome2003
- 3
Now working on the foremast details. First all the rings and eyebolts then upper futtock shrouds and sheaves. I need to figure out a good way to attach the lower yard onto the front of the futtock band. It has made me think about bends in sheet brass to act as a catch for the little spindly metal piece (yard truss) that attaches to the yard. Going is slow, but the challenges excellent.
~john
- augie, avsjerome2003 and dgbot
- 3
Thank you for posting this. I am particularly interested in the section on sails.
~j
Those looking for SilkSpan can still find it at the Guillow model airplane homepage. It can be found under the spare parts section. Each model plane has a spare parts assortment, and the wing covering is an option for most.
~j
Been away for a while working on a re-build of the HO scenery in the basement. "Little Switzerland" is now a re-born project with about 24'x8' dimensions, thus saving me some 64 square feet of basement space... yeah, the old layout was large! This new one will run prototypically with electricity from overhead lines (catenary) and pantographs on the locos. While that was going on.....
I found some Silkspan (Guillow airplane shop)! So, it looks like either furled, unfurled, or a little of both for the Kate Cory. This has opened a whole slew of new research and reading... and omg rigging, lots more rigging. I am little excited and terrified at the same time. In the meantime, I have been getting the upper shrouds installed with their appropriate ratlines. The masts are looking good. I am using a hint from someone else here on MSW: go through the plans meticulously all the way to the end, and keep a running build notebook with step-by-steps that can be readily changed when something new pops up later on in the plan scouring. This has made planning out the masts a LOT easier. As recommended, I am doing all that I can to the masts before they are stepped.
In the meantime, here are some shots of the revisited Little Switzerland.... perhaps off topic, but it's better than no pics at all ;-)
~john
- JLuebbert, avsjerome2003, ccoyle and 1 other
- 4
I haven't posted anything in a while: been busy with making the masts..... lots of lathe work and sanding... slow sanding. They are assembled now, and painted. Little parts and pieces have been added to the main mast. I still have work to do on the fore mast. I'll then finish up the tops and royals with their respective rigging and shrouds.... then step them in for their all-ship standing rigging.
Now investigating sail material and seem to be running into serious issues finding a source of silkspan, what I used to use on model airplanes. Any ideas?
~john
- avsjerome2003, ccoyle, schooner and 4 others
- 7
My solution to the davit.... I shaved off excess materials from the davit (the base and the cleats), added a small wooden "shelf" just above the outboard plankshear with a notch to accept the base of the davit, a notch in the caprail.... then strapped it in place. It will look better when the copper oxidizes a little.
Ok - the irony: the plans from the Bedford Whaling Museum show the davit in both locations: outboard from the overhead deck view and then it is shown inboard on the bow facing vertical. Well..... I have decided it will be outboard.
~john
Agreed on the pinrail and associated interference with the shrouds/ratlines. It's right in there with the whole mess of rigging. Well, looks like some fun times on the outer bulwarks! Thanks for checking into that. That helps. :-)
~john
I think it was to allow the whaleboat to be lowered without rubbing into the hull. The bow curve begins right about that location forward, so the foremost davit would be inboard more and cause the lowering boat to scratch all the way down. If you have sketches, that would be really handy. Thanks. I really appreciate that.
~john
Hi GMO2 and thanks for the reference to Texxn5's website and work on the Morgan. He's doing a splendid job on that for sure. The interesting thing is the difference between the Morgan and the Kate Cory: the davits on the Morgan appear to be integrated into the woodwork of the vessel's hull. On the KC the davits are free standing iron(?) tubular structures. When they are on the inside of the bulwark, they are mounted onto the deck and then braced with a metal strip onto the inside of the bulwark. The one davit on the outside of the bulwark is the one I have no plans for. No one seems to know how this was attached, and some models that have that region of the hull visible in photographs show it mounted INSIDE the bulwark... directly in conflict with the ship's plans. I might have to "wing it" as they say and create some form of structure to hold onto the davit from the bottom and maybe at another point from near the caprail.
To compare: here's an image of the KC's davits held in some scrap for painting and rigging:
It looks like I will also have to file off the cleats on this one davit, which then begs the other question: where are the lines belayed? ;-) Ahhh the joys of these little mysteries. This is one reason why I love this hobby.
~john
- augie and avsjerome2003
- 2
All, I am posting this topic here as well as in my build log for the Kate Cory:
A question all:
The Kate Cory has a port-side fore whaleboat. As with all the whaleboats, there are two davits to hoist the boat up and out of the water or to lower it down. The stern davit for this whaleboat is inboard of the bulwark, like all the rest. The forward davit for this whaleboat is on the outside of the bulwark, actually in a location intermingled with the forward shrouds and between chainplates. I am ok with the location. What is not clear to me from the plans or instructions is the method by which this davit is attached to the outer hull of the ship. Ideas anyone? Images? I would imagine not only does it have to be attached firmly but also maybe to swivel? Maybe not? Maybe it's rigid? All help on this one greatly appreciated.
Thanks,
~john
A question all:
Thanks,
~john
heheh<chuckles>.... here's a roll for you..... ratatatatatatataatatatatatatatatat..... I see you have noted the kit in the back of the basement there. I'm in a couple of bands, mostly classical and 60s rock. I also do jazz and some punk when feeling energetic.
The color schemes: yes, that is interesting. All that I have read on the topic of whaleboats says that they each had their own unique color schemes for easy identification at long distances. Some were quite colorful apparently. The white/black/yellow schema is a modification of an existing boats colors at Mystic Seaport. Not many of the little craft exist (a dozen or so?) out of the tens of thousands that were made. Most were lost, scrapped, etc. This all said, there are very few examples of in-use whaleboat with full paint. I suppose this is where artistic license comes in?
~john
Two whaleboats completed and two to go. Finished them off with a colorful paint scheme for one (an active, in-use boat) and a dull grey and tallow for the stand-by, extra boat. Also got the tail feathers shaped and installed. I had some searching to do to figure out just how far forward the tail feathers' cantilever should go, but some plans from New Bedford got that solved.
- tarbrush, avsjerome2003, dgbot and 2 others
- 5
- avsjerome2003, tarbrush, tasmanian and 5 others
- 8
Hi David - thanks: I have thought about the Dremel, but am thinking it might be a little too much for this... well, at least when I get to the 1/16" thickness of the planks of the little things. Removing the interior wood near the center of the boats has been easy. Getting into the narrower portions by the bow and stern has been the real challenge. Sanding sticks, eh? I'll check that out for sure. Augie and I were thinking also the little cylidrical tool on the micro-vibrating sander. That's one thing this hobby is really good for: getting new and specialized tools I'll check in a few days to let y'all know the progress.
~john
Thanks, Augie. I happen to have one of those little sanders. I think I'll give that a whirl and see how it goes. Using a blade is too much for the task, I believe. The sander has a narrow cylinder attachment, that, with some rough grit, will get it. There is certainly more to do on the model - so when things get boring ;-)
~john
Hi Augie - thanks! I'm planning a long time on these little guys. I also thought, hmmmm.... maybe this is an opportunity to build a larger scale whaleboat as to learn all the details... then... that, would, be, what? six builds at once ;-) I need a bigger work area!
Any advice on roughing out the interior? Carving seems quite unwieldy in that cramped space. A #11 blade is out. Suggested blades or tools?
Thanks,
~john
Now started work on the whaleboats...four smaller and fine-detailed models in their own right. This method is to use small wooden flats, called lifts, that build the boats from keel level up. They then get carved and sanded out in the following order: Bow, Stern, and sheer (all outside) first. Then the interior is brought to shape followed by completing the exterior outboard sides. They get really thin.... 1/16" to 1/32" so no messing around with a Dremel for me (I have shaky hands with that thing). I'm going to carve closely, then hand sand or use a small electric mini sander to get into tight spaces.
Sultana by CharlieZardoz - Model Shipways - 1:64
Looking really good!
On sanding the back, that curve is a real challenge. I used a sanding block and a sort of jig arrangement. There is a description of it on this site in someone else's build log of the Sultana.... let me see if I can find it... http://modelshipworld.com/index.php/topic/1292-sultana-by-hopeful-msw-scale-164-bashed-kit/?hl=sultana
there is also a good description on process in Chuck Passaro's practicum (Model Shipways available online).
~john
