I am building a 1/350 scale plastic HMS Warspite Battleship  and i am looking for advice on hand painting with brushes my build please,  the first area i will tackle will be the hull - this are i think i can break up into smaller areas and mask off around different bulged  sections and armour plated sections, this would cut down on the area needed to be covered in one swoop etc.
I will be painting the bottom hull section first upto the masked off boot line, but wondered if anyone has any advice/tips regarding this please.
OC
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
If it help:
Wash brush well and often during work
better more thin layers than 1 thick
use small amount of color, it dry faster than you need,
and don't use it when start drying
prepare the thinnest brush you can find
use magnifier for precise painting
Play with mixing colors and transparent thin layers
Always do some tests before applyin acrylic
And use acrylic thinner (I do not) for washing brushes and corre ting mistakes
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
If it help:
Many thanks or your advice - the more the merry-er,  i have a good selection of brushes and i am use to painting by brush most smaller sized models, and with acrylics i only started using them with my admiralty range on my wood build.
As i am now building a 1/350 scale plastic a ship build in plastic will be the largest i have built/painted, so this is why i was wondering about the best way to paint the expense area of the hull?  i can break the painting up into sub-sections i think?  by masking off sections of armour, and try to get a smaller area to fill with paint easier from the brush,  i just dont like the idea of having to fill an area from bow to stern about 20" in one sweep, i think that will be asking for an un smooth finish by anyones standards?
OC
Current builds
Completed works.
OC,
Large areas can be done by applying several thin coats, rather than attempting to cover with one thick one. Slightly thinned acrylics will dry without brush strokes. Wait 24 hours and re-coat for complete coverage.
Some acrylics hand brush much better than others. What brand are you using, and what thinner?
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
OC,
Hi Joe,
I have just ordered a white Vallejo primer in Acrylic and also the authentic WW11 western approaches range  from a company called LifeColor, again in Acrylic, i have also ordered from Vallejo their sand colored Acrylic that i will add some light grey to - to simulate bleached salt worn wooden planking.
I already have a bottle of Acrylic red ocre  that i am hoping to use for the bottom RN anti fouling red hull paint,  my plan is to assemble both sides of the hull minus the deck and prime this after a thorough wash with detergent and water, then i was going to mark of the Boot topping line and paint the Red hull first, then after a few days allowing to dry, i was going to mask the top of the Boot line then paint it black.
Then afterwards move on to masking the patterning and painting sowly each section.
OC
Current builds
Completed works.
Sounds like a good plan OC. The Vallejo brush paints nicely. I don't have any experience with Lifecolor, but they have a good reputation as a quality product. See what they recommend as a thinner for their paints.
Joe Volz
Current build:
Thanks Joe,   have you any tips or advice on masking tape for the Boot line(as HMS Warspite has a lot of details to mask around)  and for the camo Stripes/bands as i assume these would not have been hard sharp edged and more of a feather edge?
OC
Edited by Old Collingwood
Current builds
Completed works.
OC, I've used 3M blue masking tape laid down on a piece of plate glass. That will take some of the stickiness off and you can cut it to width with a knife and metal straight edge.
If you have a well stocked local hobby shop (LHS), you might to see if they carry Tamiya brand masking tape. It's low tack and pretty flexible. Comes in various widths. A bit pricier than the blue masking tape, but it is a very good product.
Ken
Started: MS Bounty Longboat,
I agree on the Tamiya tape, as that's what I use exclusively on plastic models. It holds an edge very well a does not lift hobby paints. As far as the camo, in reality it would likely be a soft edge but in such a reduced scale masking it would be appropriate and much neater. You'd never be able to see a feathered edge in such a small scale.
Joe Volz
Current build:
I have just picked up some blue low tack tape so with any luck this will do?  i will try the trick with taking some of the stickiness off them laying them on some glass/tile etc first.
OC
Current builds
Completed works.
Thoughts in general:
I have had a lot of success hand painting with Badger acrylics. Even better when thinned down, a Nenad suggests.
I have had good success using artist acrylic (from a tube) watered down as well. I got this from Chuck's discussion in his Winchelsea (?) log. (Confederacy maybe). Thinned down to almost water, multiple layers until you get the finish you like. It works great on wood. I assume it will work on plastic as well. So far I have only used black. Red is n my future
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
I am really appreciating the replies folks, thanks to all,  another question from my never ending list - what sort of ratio would you water down an Acrylic paint from a new bottle/tin etc, say 50/50 or is that to much making it to runny?
And also any thoughts on a good WW11 battleship Bottom Hull color,  i am kind of  leaning towards Vallejo  Hull Red color, but as Royal Navy ships used a color called RN19 Anti Fouling Red, i dont know how different the two might be?
Sorry for all the questions folks but any ideas please?
OC
Current builds
Completed works.
I might be tempted to use a red auto primer.  I know its not acrylic, but....if I recall from my Navy days, it is close to anti fouling red.
With reference to water down ratio, I would say to experiment.  When I water down artist acrylic, it is heavily pigmented water.  The first coat is translucent...you can see the base below.  The second, third and fourth coats do the job.  I let dry and sand with 1200 sandpaper (first 2 coats) or buff with cloth.  It works great on wood, but I'm not sure how it will work on plastic.  You may need a slightly different technique.
Chuck Seiler
I was wondering about the bottom hull red color on my HMS Warspite build,  i know British Second World War ships used a paint called RN19 Anti Fouling Red, i still have some Red Ochre that i was using on my Napoleonic period RN build inner bulkheads/gun ports.
Could i use this paint to simulate the Anti Fouling paint?  as i belive it is a very early version of Red Oxide,   so possibly later paints used on the bottom of RN hulls may have been based around this type of color?
Any ideas folks please.
OC
Current builds
Completed works.
Just picked up on this topic.
A number of years ago by boy wanted to build and paint some of the Games Workshop figurines and equipment (http://www.games-workshop.com/). The GW stores offer free lessons in this art. I had to stay with him in the shop as he was underage at the time. It was hard not to get involved- and I picked up some good tips and techniques for painting with acrylics - the staff know what they are doing. The techniques transfer across to ship modeling, or any other kind of modeling I suppose. The downside is you would have to buy a box of their models (and some of them are a little different to say the least) to paint in the shop for the lessons, still it was probably worth it for the experience I picked up. Thet also sell books on painting.
I think the best tips I could give are:
use small amounts of paint, well thinned with acrylic thinners ( a bottle goes a long way)
many of these thin coats instead of one thick one
use water to clean the brush (keeps the cost down)
use a good quality brush
Their paints and materials are worth looking at as well - ignore the names, go by the colour.
Al
I tried the Vallejo Primer   dilluted it 50/50 with distilled water from a kettle after it had cooled, i applied it in many fine layers with a flat 8cm brush, i  let it dry for about 15 hrs and tried to do a bit of light sanding with a fine sanding stick that had been dulled to make it smoother,  but it was pulling at the paint peeling away instead of sabding it finely - what could be the problem?
OC
Current builds
Completed works.
OC, was the hull surface clean? If casting oils, release agents or dust are on the plastic, the paint won't stick. Get some dishwashing liquid and warm water and wash your hull. Let it dry and then paint.
A good brand I like here in the US is "Dawn". No scents, cuts grease.
Ken
Hi Ken,
Yep i washed both hull sections with washing up liquid then rinsed off with warm running water and left to dry before working on them,  i then glued my paper hull plates on firstly with wttle  glue PVA but then had to settle them down with Revell contacta poly cement, i then sanded these down.
I am not sure if it may have been areas of white glue that may have stopped the primer sticking well, or just me not giving the primer enough time to fully harden before sanding?
OC
Current builds
Completed works.
Use isopropyl to clean the hull. Various liquid soaps can leave surfactant residue behind the actually prevents adhesion.
Thanks Joe,   i wondered if it was down to the layer of PVA i had painted over the hull?
OC
Current builds
Completed works.
That could very well be the case OC, and that would also end up giving you some trouble.
Thanks Joe,  lucklely  none went on the sides just under the hull.
OC
Current builds
Completed works.
