Four additional images, more detailed and focused on the bow and the stern. The first two images show the current status of the bow, with the stem still to be completed with new pieces and finishing: here I have to cover the plywood with the mahogany veneer in the same way I made for the keel and the stern.
y4mXLc9O-5xqaw79wK5eDL1EuTunlbf_4JJ9DOEH
y4mRf0SZwDYNKvHsaqu7jNhHT3a8Runa6LJ_Eee1
The next two images, on the other hand, show the stern completed.
Another task to do is that now I have also to modify the pedestal that is not performing as well as I expected: in practice the choice I made of adopting only two hull supports instead of four was unsuccessful.
See you next time, Jack.Aubrey.
y4mIYx6iZSX9xMttU2RnK9SEbGrrw3cucmrBw-c9
y4mOIOHuJBROwBAMTLAqUqkrVb0wPrXVQbmVpF-5
Edited by jack.aubrey
Thursday February 9th, 2012
During these days I didn't rest, on the contrary I began a lot of small tasks for my Soleil Royal. The problem is that these works are disorganized and there is no need to show them with images.
More in detail I worked a lot around the prow, the stem in particular, by continuing the application of the mahogany veneer. I have also prepared, in the same way, the rudder. Infact also this component was made with plywood and needed to be refined.
Then I'm preparing the small deck at the prow above the stem. I don't know the english term. It is an important element also to provide strength the the stem itself. Regarding the rudder I rejected another time the rudder gudgeons and pintles supplied with the kit and I built them using brass plates and tubes. I'm not too much confident with welding but my poor abilities in this matter were enough to achieve my target. I will also have to burnish them before installation.
Last, I definitely modified the pedestal to increase stability and handling. Cheers, Jack.Aubrey.
Also today, February 10th, 2012, I spent the afternoon working for my Soleil Royal.
I worked mainly around the prow platform/deck. I had to prepare the gratings in the proper shape and I had to refine the whole. I started in this way an activity that took me a lot of time because I was looking for a perfect result. Image 03 shows this platform with some refinements to be done. Later in the afternoon I completed it.
The first two images show the prow and the stem, now 99% covered with the veneer strips. At this point I am very interested to see the colour of this detail after a coat of oil . .
Last, image 04 shows the pedestal I modified sometime ago. Now it is more useful than the first version. The horizontal plank has the objective to simplify handling by supplying a secure grasp to the pedestal. I have also installed four rubber feet below the pedestal.
Kind regards, Jack.Aubrey
y4m8LImE0nGD3SMSpSruh2JkEkYM4S46B5JfWI9g
y4mb0_yk5goawAz30Jq1CR1gIVoq0FN9NR5SU0im
y4mAfVY_KVzWucDl2VmMDOiuvF4gTzq4omnvSNNb
y4m6VvwM1UpxpyRs1zSLGrpw0LNjz0Vv2gyK6h7s
Saturday February 12th, 2012 - The bow
I have finished the bow platform/deck. I started to build this detail some days ago and I show its evolving in the previous message. When finished I installed immediately in its final place because it represents a reinforcement of the entire prow/stem. Infact this detail keeps together a significant part of the stem and the hull. In this point of time the stem is particularly weak if left totally free.
y4mH8dHRG6sbIiZ2jjziGXqg47suWTa57pWA43wB
y4mz7jLXt_nErDhm-yuSkKF2zs_FEuvTkOeZivOS
y4m5Rvr9MLJC6cnE1FWthv7q-AkqaeqYYVevvkBf
y4mo7WGxDboeLOj_TQOD0_15cIB3hhgNYabAa1Ks
When the installation of this platform was completed I was so eager to see the wood colours of the whole prow complex that I applied immediately a coat of oil on some details, to see and appreciate its real appearance.
I think the difference is so evident that it doesn't need any comment . .
See you next time. Jack.Aubrey
Some nice work mate, she's looking sweet.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Saturday February 12th, 2012 - Rudder, pintles and gudgeons . .
The first image presented here shows the rudder, made up with a piece of pre-cut plywood supplied with the kit and completely covered with strips of veneer, like the keel, the stern and so on. The work resulted well done and I am fully satisfied. In the same image there is also an attempt of product placement (I hope this is the right term): the book I used as background for this photo. This book describes with great detail of information the Trafalgar Campaign and Battle and, after having read it, I recommend this book to all the italian readers interested in marine history.
y4mf6Iq-WsRTujy6LGoixIoaNtkhdccotF0VLJj5
Then I worked around the pintles and gudgeons.
The elements supplied in the kit are commercial pieces, ready to be used and already bored. They can be seen in the image here below. But I reached the conclusion they were not good enough for me because they were built for being wedged on a 4mm stern, while in my case the need was for 6mm. In addition the gap between the rudder and the stern seemed me too much . . so I decided to build them from scratch.
y4mtDFFe8PGSVYwrgroy4ZNTWftzPagQUs0CylUW
The next image shows the raw materials I used to build the pintles & gudgeons. A strip of brass cropped in the right measure from a sheet of the same material and a brass small tube. I found these raw materials in my "Used Shop Warehouse", so no additional expenses. As tools I used a electric soldering iron, some tin and a piece of wood of the same thickness of the stern and the rubber.
y4mN5qHpu9-RB6UdyYKu4a8QlFv6Z-Pwkqk3L-Zh
First of all I "cooked" the brass on the gas cooker. This made the brass pliable. I placed the strips on the wood to give them a "U" shape. All the pieces were then clamped together and I welded the tube above the short side. After welding, I cut with the minidrill the tube obtaining the finished pieces. A final refinement with a file, followed by blackening and the job was done . .
y4mP7BeDwLWmk9MA1IAuymQ5ECFQpVd0YPObZ3R7
Now I have to bore these pieces, but I will do this as last step, when these pieces will be fixed on the hull. Into the bore I will insert the head of a nail, of the proper size.
y4mNodBIjuXTuZ96wwJEU50YQgFhF_6vL97Gw88Z
February 15th, 2012
During these days I spent some time for planning the next macro activities, in the proper sequence. The planning can be summarized in the following list and sequence of actions:
  1.
  2. completion of the second planking in the upper side of the hull
  3. istall the gunwales and the remaining wales
  4. setup the elements of the waist
  5. install the visible guns of the upper gun deck, below what will become the waist
  6. install the waist
This is more or less the general plan for the next weeks. After, also if I don't know how much time I will need, I have to wait for new materials from De Agostini to continue . . and these shipments are a little late.
But let's come back to February 12th.
When I've simulated the positioning of the rudder with the "scratch built" pintles and gudgeons i discovered that the rudder I prepared was not good and was to be modified. The change was so conceived that I preferred to prepare another rudder, starting from a solid wood of mahogany. The problem arised was the difficulty to move the rudder with its current square shaped side adjacent to the stern.
Here below the image of the wrong shaped rudder to facilitate you in identifying the changes I made in the new one.
y4mkUqmvURwJ1yecWAU_jzgAIwszRgZHYWA5wjDa
The new one also has a shape that is compliant with the rudders used at the times of Soleil Royal.
Here below a couple of images where you can see how the side associated with the stern is not square but arrow shaped. The fact I used solid wood has greatly speed up the time needed to build it and keeping the same visual effect.
y4mSn4BirF51ZC8HzU0h89XotF2FbFpBHVNOen8T
y4mT7AnhEIDzgFhPRPwHff6inC8fw-jibufMt73E
Last, yesterday I began to prepare the pieces that will setup the waist. The pieces are made with birch plywood covered with beechwood planks. The overal thickness of this element is 2mm. The image here below shows the raw piece I prepared that will next be cut to form the two pieces required.
y4mxECs-sM0t6TbArK2DxSgHSyN32CE2Gzf37XcG
That's all for today, see you next time, Jack.Aubrey.
Thursday February 16th, 2012
Working around my Soleil Royal is still in progress . . yesterday I completed the two elements of the waist and I resumed the second planking to finally complete it. At this point of time I was able to finish only the right side and then I take a break . .
The image here below shows the finished side of the hull. Now there is to continue with the refinements of the circular gun ports, but they can wait . . may be tomorrow I will complete also the left side . .
y4m8qijNpaxsEfDLqHHFhVuIabbFFmZ-fiFX-Bz9
And now I will show the pieces for the waist. The first two images show these pieces above and below.
y4mOhILfTRlSLICEB_z4_WVcoCbRiIyG6rwIbtCM
y4mXIU-pCaCJS7ddyQQKXKSUlED2bvulPCM9bFS7
In the next two images I have positioned the waist on the hull, just to show how they will appear once installed in place. They are now larger that needed, but the proper adaptation to the hull can be done only during the real installation.
That's all for today, cheers, Jack.
y4mKhiq58173V3JtSes3qcNA3dv7CDER0AwfM-AC
y4mwOo1GtnJq4Pt8yXFWvPyPYQPEz1-I3O0H_ZJi
Thursday February 23rd, 2012 - Second thoughts about some planking . .
One of the future task to be undertaken on the hull sides above the upper gun deck is, in accordance with the kit manufacturer instructions, to paint this area with a light blue paint.
But I didn't like this approach. I like too much the colour and the grain of the wood to cover everything with paint . . and, after having spent weeks to  achieve the result of carefully mixing different kinds of wood and taking also care to obtain a "perfect" work, I reached the same decision I took sometime ago to do not paint with dirty white the quickwork of the ship.
So I will not paint in light blue the upper sides of the ship.
In a store selling wood and related products I found a stain whose colour is blue, similar to the same, but red, I found for the Santìsima Trinidad Cross-Section. It is a powder to be diluted in normal water and its darkness/lightness is depending on the amount of water you use.
y4mhi6sJ5NSQ3IfSQpy9HZ5JEcmDMaUGz2rRQJ64
Sometime ago I made a test to apply this stain over the chestnut veneer and the result was very good regarding the colour but the problem was another: being this stain dilutable in water, there were big problems when installing the plank using the vinyl glue. The colour had the tendency to melt and dirty adjacent wood, and this was not a good thing.
I had to find a way to remove this unwanted effect.
I have then prepared some sheets of veneer with this stain and after I applied a light coat of wood filler above them. When the filler was dry I was able to discover that the colour was stable and did not expand or melt. This was the result I was looking for, so I decided to go further.
Then I started to re-plank the upper sides of the hull with this coloured veneer. But before starting with these new planks I had to install a wale above the gunports of the upper deck. This wale is 3 x 2mm ad was obtained by cutting in the right measure some strips of rosewood. Having mounted and glued this upper wale I installed some planks of the coloured veneer, eager to see the live result and to continue . . but the day was finishing so I shot some photoes that I immediately show you here below.
y4mnlg5jO4StPyicanVYVZRZtuLAIsKD5H-4Dsyx
y4m3FdeQHF4jakNo0HUH7qA98edkVYcizdZE9Frq
y4m8cE7iLmepobx64ncDGvfqqi7H-CLj9GatnClx
Monday February 27th, 2012 - Last wales and blue planks
During this week-end I have finished to install the "blue" planks and the last wales located from midship towards the poop. A relaxing task, without any kind of problems raised.
One interesting and amusing point was the preparation of the wales using the table saw . . every time I use it, I become more experienced and I learn something useful new.
Then I took the occasion of the nice weather to make photos outside. There are some tubes in the background that need some painting but the daylight helps very much to highlight the blue colour of the last work I made on this ship model.
And now I cannot delay an activity I don't love too much: install 12 guns on the upper gun deck before continuing with the installation of the waist above them. To install these guns I think to transfer the shipyard (or better only the materials I need) at home, in order to manage this boring work in several short session during the day without the need to leave my home.
See you soon, Jack.Aubrey
y4mlOftL-MUKlpzePX6_5RQpfPEoepAxppfYApm_
y4mTHAFGxKb21KGDvPNAZ7ura8_b50hb6PqMed6R
y4mwAawZHLHgjtM63jSAK9E0xexZrMyTV7S4KNw-
y4mF6MLvFzGWjEBBN4k5dr7Gh6TjcrLyU4BSCZ0U
Other three images of the Soleil, same day . .
y4mGDI-QXwXlA2YC29BkC3WsTBPBnTM3GUTHC-Vn
y4mD_xt_pxWiQGSx3QuoqIMmaNrmkrtavlFgDO47
y4m43rj9vFen7rCbb4CRd38KipQpruRhbShTFiqp
that blue is perfect.  nice work
Thanks Sarah, I appreciate very much your script. The blue stained wood was an idea that I had without any suggestion from other modelers. So it is 100% mine, and I'm very proud of it. Thanks  again, Jack.
Thursday March 1st, 2012 - Guns
Today I spent some time to find the materials necessary for the installion of the 12 guns of the upper deck: gun barrels, trucks, ringbolts, blocks, rope, etc. These materials were shipped with sevaral issues of the magazine, so the search was not a matter of minutes but something more.
Having collected all the materials, I started the venture of installing these guns . . and honestly I think this job will take a certain amount of my time and efforts before writing the word "END".
In this first image you can see the main raw materials: 12 barrels and 12 trucks. Trucks are metal cast and I had to make some refinements with a set of small files and sandpaper to remove the many imperfections of the moulding. The image shows them already refined and you can also note that the metal used to cast them was in origin "aluminum" like and subsequently darkened outside.
y4mT5U680LSK7QQHXP4Jmy12a1iY9L3PCCwZC36b
Image 02 shows the blocks that I was able to find in a model shop. Again I discarted the blocks supplied with the kit because they were too big for this scale. The new blocks are 3mm wide and what you can see in the left envelops are one-way blocks while the others on the right are two-ways blocks. Another important point is that these new blocks are not made from wood but from plactic. Each gun needs six blocks, three of the two-ways type and three of the one-way. In addition I show the strings that will be used for the tackles.
y4moZA5zA0LSUVGL8UnyWsp1sPkRX7G0JBUoBrYm
Image 03 shows the string to be used for the recoil ropes and a reel of brass wire that I will use to prepare the ringbolts. Each gun needs six ringbolts for the tackles and two for the recoil rope. I will scratch build them because, again, the ones supplied with the kit are, for me, out of scale. I have a personal method to prepare them that I will show soon.
y4mJsvwHvrf2Og67oBPVJ8sM5m5hWDCNIvkxuh5U
This is all what I need to start . . now I have to start . . see you next time, Jack.
. . Continuation . . Friday March 2nd, 2012
As I wrote yesterday, having collected the materials needed by the next activities and having rationalised my mind, I started to work.
First of all the gun barrels: i mounted on my minidrill a wire brush and I cleaned all the barrels. This to remove any residual of filth from the object. The target was to make it ready to be immersed into the burnish solution. At the end of this task I immersed the barrels, all together, in the burnishing product and I left them there for about one hour. After this "bath", I washed the barrels under water to stop the process.
The result is visible here below. It is obvious I don't want to use any kind of paint but to leave the barrels as they appear in the image.
y4mORxji0n-z0XwuWj1bj9BGrDd6MKJY8NCzB9j6
After I started working on the gun trucks. I bored each truck three times in the proper position to insert in the holes the ringbolts: two on the sides where there are the wheels and the last in the rear. I think it is difficult to see this holes, may be in the high resolution images.
Later I studied a solution that allows to fix the truck above the deck with a metal pivot. The objective is to fix better the trucks to the deck without having to rely only with the four bit of glue under the wheels. But this truck has no bottom useful to be bored to make the hole for the pivot. So I applied a small piece of hard wood 5x1mm fixed over the bottom. The solution is better understandable in the image. I'm sure it will work properly.
y4mUO7uV-sb2_W4rXuxOoUyjFua12qlXobCYXsWA
Then I started to build the ringbolts, or better one of the two pieces that make up a ringbolt. I used the brass wire shown in the previous message and I build them by using the minidrill . . to keep the ring diameter equal on all pieces I used a drill bit of 0,80mm diameter.
Here below some of these pieces are shown. They have now to be burnished.
y4mUIjyzlS7GLW5C_6iG1-k6FAIS4-cJyreAKIE-
That's all for to day, see you next time, Jack.Aubrey
Sunday March 4th, 2012
After having built some pieces of the future ringbolts I found the power minidrill too fast and I preferred an alternative solution that can be managed in a more confortable way. I went back to my workshop and I found a manual drill I used when I didn't have the power tool. It was a lot of time I did not use it but it is very useful when you need to bore in area poorly accessible, given its limited size. The manual drill is shown here below
The process is the same than with the power tool, first of all you have to insert and fix inside the drill the to extremities of the wire.
y4mUpcgotUVPle48aJm3xAf6R6VMdLETjLFsBYjm
Once this task is done, a matter of few seconds, the ring is inserted around a pivot clamped in a vise. The pivot here shown is a drill bit of 1,5mm. Then you begin to twist the drill manually.
y4mIvPEjf6EHvHTOTBbNJNcYWjIy-pnGYbZQd__h
And here below you can see the result after the twisting. At this point I remove the piece and the process restarts from the beginning.
y4mewzjMSrRqEKc5cp1UGC6uqdnDyChEvIXewgAo
Today, in more/less 35 minutes, I made sixty of them.
After, I started to think how to build some elements of the superstructure of the decks. Some of these elements are what we call in italian language "cavigliere" (pin rails?) and "pazienze". I don't know the right english nautical terms, so I hope in some help from you to identify the proper terms. Anyway, in the future messages it will be possible to find these pieces completed. Here below I want to show two kinds of head finishing for these elements. The first image shows the classical solution, also proposed by the kit instructions . .
y4mZsGtVKbdHEwwEEItqwdsIOmRqw_0yALmnIZuP
And here below an alternate solution to the classical scheme. The colour is not important because the final elements will be painted in red. The first solution needs more time and work than the second. I have to decide but I'm more interested in the first example.
y4m4IZ4aYIEb4HvtB5QyFfCfZkYZtV-t4BzU6RH3
Cheers, Jack.Aubrey
Sunday March 4th, 2012 . . "Pazienze" and "Cavigliere" (until I'll find the proper english term)
The building of the "pazienze" and the "cavigliere" raise another interesting matter. Infact, the vertical elements of these details, in this case a 5x5mm wood strip, must be "carved" to receive another 5x5 or 2x5 strip. The achievement of these notches is not difficult to do manually, it needs only some patience, but this time I wanted to find a different path to obtain the final result.
I'm slowly but relentlessy discovering new ways to use my Proxxon table saw and, for this task, I found another way to use it just to realise these notches.
The next image shows a trial made to achieve this result: I positioned the height of the saw in order to protrude only for few millemeters and, by passing the table above I made what you see in the image. Obviously I made several tests until I learnt totally the lesson, with some waste of wood.
y4mBG-ugDvsNbEuqW1oPsW41RTLcHUEyx1DuuvJr
At this point of the test, I went forward to the next step: cutting the 5 x 5 square strip. But this is a normal use of the saw . .
y4m14fdgnoOm1smiFTr7OOJxjli1_ySdQHBgfwQG
After these preliminary and successful tests I started to do the real work with the proper wood and the result can be seen in the next two images, the first with the wide notch for the "pazienze" and the second with the narrow one for the "cavigliere".
y4mGEGh0w9gcfQAD27si_1i4Hj3oso3dqDClYwLE
y4muSQt84kdPfMmz1geK0e6Qvah7XUOELfAYcxvJ
Obviously they are not finished at all, I have to carve the head in accordance with my last message and cut then to the right length.
But, again, I'm very satisfied because I made a new experience with the table saw . . experience to achieve step by step, error after error, until the final, successful way was found . . next time this experience will be ready for reuse in my mind.
At this point someone will probably asks by himself: and the guns ? They are still in the process but, having in mind the same experience with another model, I know it is a boring task and so I mix the work on them with other more interesting activities like the one described in this message.
Monday, March 5th, 2012 . .
Today I built a "strange" structure (never seen on the naval achitecture books neither french nor english . . ) that has the role to support the ship boats. It will be located on the upper deck, just over the gratings of this deck. I had to built this element because, without positioning it over the deck, I can't identify the right place to install the ringbolts for some of the 12 guns. In fact this strucure interferes with them . .
Here below you can see the boats supporting structure: it is built with 5 x 5mm wood. Again my Proxxon table saw had a key role in cutting the single pieces, giving the warranty of perfect cuts at 90° that helps very much their assembly.
y4mH2hUMUQSn46p9DPD4Vf5tOij8XJzx99pMYLjV
y4meYqkYoYjgPE0DTZF1bxnWxiXNTGMB15-UIFgY
Later I passed to the gun's trucks by painting them with red polyurethane enamel. I used a double adhesive tape to hold the trucks in order to paint them in a more comfortable way.
y4mFVjVpVQSQDviIKBAWxTfWc7vQC7qlkdyEI2am
Here below the trucks after the first coat of paint. It is surely necessary a second coat, may be a third. I'm seriously considering the purchase of an air brush. I already have the air compressor. With an air brush these tasks will be surely faster. I will see on the market . .
y4mc5fAQri0CP8dVxr-PQg2g6EtVJHNHF0mMSbbA
Kind regards, Jack.Aubrey.
Tuesday March 6th 2012 . .
A preview of how the guns will appear on the trucks; the wheels are not yet painted.
y4mapUEpJCmJY4VBFwriU1DQPPgE4bpYlJBqCLPh
y4mqmUG6cTZais2TWeHHgaUVCgglAY6yiZ3ueZjQ
Friday March 8th, 2012 . .
A quick update of the work done in these last days. First three images show the boats support structure, the pin-rails and the "pazienze" (I hope now that you can see them you can also name them corretly) after they are painted with red colour. They needed a total of three coats of paint to achieve a good result, So, just to paint then I took three days . .
y4mkqgCejqnt5JNhYAMt7gxxy4kG9cwZSm51VpCx
y4mERUMzO32yXqt1g8fYAS1MZukjOa4uexZ3WZCG
y4moaosB-zQwih5YsscXRZ4Z9cDn7ZwnycugQKUj
The pivots that come out from the bottom of these elements are the protruding part of brass nails fixed into the wood. They will be inserted in holes on the decks to increase the strength of the glue.
What do you think about the two decker shown on the cover of the book used as background ? It is a very interesting book about the plans, contruction and history of a 3rd rate vessel of 1678 named Lenox. It contains plans that would allow to build a 1:72 model . . The problem for me is that I have a lot of shipyards open and I cannot open another one !!
y4mHoP0kcfoQFLzMi_MXTV-iVUOvxJnU7Qg1MgD0
I just found your build log and your work is beautiful.
Scott
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
Scott
Thanks a lot Scott for you kind comment . . hope you will follow my work again. Jack.
March 16th, 2012 . .
Last week I had too many things and they were not involving ship modeling, so the productivity was affected. Result: production below my usual average, average that is often lower than the rest of the world because of my slowness . .
Here I post some images of the work done, just to show something, anyway uncomplete. In the first two images the guns for the forecastle and the quarterdeck, different from the guns of the upper deck, with their red painted trucks. Again the wheel are not painted.
y4mjthnaGeyCQLFCOheHtJwV_o0dQOubN8eVgGL1
y4mOk0CyTWcB2PhtTXDzAbng1LDn0m5JZz1ZQe2D
Then I started to build the four anchors. I'm still far from the end and here I show one anchor with the raw wooden stock and the other with the same element shaped and stained. Today I made all of them, including the iron hoops. For these last details I used a personal method instead of the one suggested by the instructions. I will explain better in the next message which will include finished anchors images.
y4mFllgbTr5qmjqvfwEZ_oCXakFcfvXjhDcb6XMb
Wednesday March 21st, 2012 - last updates . .
Here follow some updates on the new superstructures of this week. Not too much but the wheels are still in movement . .
Two images of the anchors, 98% finished. To complete I have to cover the ring with a drawstring, in accordance with the books describing these details. To fix the stock to the shank I used a bi-component epoxy glue, which assures a much stronger adherence that the cyan-acrilate.
y4m_8jgXuFo-xciIXBVABpcPWcwkJ73TVHYZANFH
y4mH9qbQuskzMBmq9fAKK_f0JsWoNxKsYneMyTGE
Two images of some superstructures red coloured and the two catheads.
y4mGVAKgRs1p6BikqI0iX4XI9RyN9eyFg7PkbRbg
y4mHgtbgSQMj-dmMI95Yw8CpT-yAsa01Hbx0_C5i
First of all thanks to Gimo and Tom for their appreciations. I hope this log will continue to be of their interest and usefulness . .
Friday March 23th, 2013 . . continuation . .
I continue today the message I started two days ago . . I began the building of the ship's boats.
I built a cuople of years ago two boats for another ship and I had the plan to reuse them, but I had to accept the fact that they were not of the proper size, one boat being too big and the other to small for this model. So I had to plan the building of two new boats: a not short and simple task !
I took into consideration a couple of methods, in fact there are several ways to build these boats, but at the end I took the decision to work around the material supplied by De Agostini.
But this doesn't mean I will build these boats as described in the instructions, there are too many details made in a way that I cannot accept; some of them totally out of scale. But I can use the material provided for the initial structure of the boat, that is planned and made quite well.
Anyway, before starting to use this material I made with a scanner a copy of the pre-cut keel and bulkheads to have, in case of failure of my project, the possibility to rebuild these pieces and restart . . a kind of backup . .
I know this task can be quite long, and honestly I started it with the objective to mix this new activity with the others around the guns and the superstructures, this in order to differentiate the work and make it less boring. I'm also waiting for new materials from De Agostini, materials that arrived to me, by the mail service, in a very poor state that I requested a re-shipment to De Agostini.
y4mqZibkgh0nSL8YWQ05UxNkeNNY-a8L7ZvNj-9T
y4mvj1TDu1bKTxKmyFyXFeupfLnQXK_MrcWcB89k
On the fronline of the superstructures I started and finished the construction of the two privy (I hope the term is correct). They will be installed at the prow in the future.
y4mbS-_ay8r47JLVkEMCAQPyAyXPTCN2634ASYdw
y4ml9pt_IJWKQ8OJM-MrDsxysLGWkLOdd8h-Dl3H
Friday March 30th, 2012
The last week was a little unproductive . . The spring is coming and the fact I do not receive new materials from De Agostini has "iced" me, so, all what I made is to start planking the two boats, and nothing else of interest.
An interesting matter is that the two boats are exactly the same, one is only a little smaller. Infact the same defect I found on the larger is present also on the smaller and this probably means that the plans are the same, just a matter of a greater reduction of the scale.
Again, after having assembled the structure, I proceeded following my own way: instead of using the supplied planks (3x1mm), I used my veneer.
For the large boat I used planks of 2,5x0,5mm while for the smaller I used 2x0,5mm. My intention is to plank the hull three times and then remove the internal boat structure . .
As probably I wrote some message ago, the veneer I'm using has a very thin sheet of fabric on one side, so the first planking was applied capsized, with the fabric outside. I think the reason of this is obvious: the visible side will be the one oriented inside . .
Yesterday, in addition to the work done for the boats, I finished to prepare all the single elements for the installation of the guns . . at this point I can proceed with different options: continue with the ship boats or resume the ship guns . .
Cheers, Jack.
y4mEJinnHkMJuP_UuYzqyAcdR9fhajdctTDOwoU2
y4m4ow9dRxeMk7sqA6Flyxs9p8ZzddjFg-ld7h9W
Wednesday April 11th, 2012
Again , also in these last ten days I was not much productive, or better, I made some important activities, but not too much visible and I can't show only few things.
In detail I:
  • Smoothed definitely the hull, after the application of the second planking, with sandpaper of decreasing grain. With this task I obtained two goals: smoothing the hull and reveal everywhere the same color for a given wood. In fact the color of the wood, in particular for the chestnut, was greatly influenced by the daylight and in this way I made the wood color homogeneous on the whole hull.
  • Applied a coat of oil for wood on the whole hull, having in this way the possibility to admire the final colour of this ship after months of work . . and keep it stable.
  • Installed the pintles and gudgeons to the rudder; next step is to fix definitely the rudder to the stern.
  • Applied the second planking for the ship boats; I achieved a good result on the large boat, while I have to start the smaller.
Here a couple of photos of the long boat, still on the working basement. Cheers, Jack.Aubrey
y4mpYIgOthineaHbU28rPavRGdND6RE_AAs0Oxlj
y4mx62rQwN3eezKT1dVgj_UlUSq-vIXlEHnMS6H9
April 12th, 2012
The long boat is now ready for the third planking while the smaller is ready for the second planking
y4m1spVf1JvrfP6ZvuEO6LT9BcFo9UnAPm4ztknG
I made a little error with the second planking of the long boat that I will correct with the third planking. But this will not happen for the smaller . . power of experience . .
y4m8yFMcI5B6Vc2rfdokRC2-QUu8cI-p6u5mqC_N
In the next image I show the pintles and gudgeons applied to the rudder.
y4mY_Qatsq-oQDLq6_wjSu-YAxw7tWkKd5adZayA
I have also taken some photos to the overall hull, where I applied some coats of oil. May be in the images it is difficult to understand the difference, but in the real world the difference is great . . specially over the mahogany.
Image 04 shows the hull after the oil, while the 05 shows how it was just after sanding and before applying the oil.
y4m0SkOyb5sEXTTSgFSvvylcg88-KqkwN7bQ09si
Kind regards. Jack.
