Hi CH,
Have been wanting to build the Portland for the past 10 years or so but didn't think I had the skills. I now
have been offered the kit, original version, for just $30 from a close friend. Will definitely take him up on this.
Want to see what it involves before I order the newer laser cut version. I see that you put her together in
just 6 months. Approximately how many hours?
I'm 75 and recovering from radical cancer surgery. Looking for a project to carry me through the winter. Hope
I have the energy. Your profile gives me much encouragement. Any thoughts would be welcome.
John Elwood
I am not that familiar with the old kit other than the railings are net on the older version and photo etched brass on the newer one. I would talk to Nic at Bluejacket to get better comments on that.
Someone once mentioned that you had to be a miniature carpenter to build a steamship model.
that may be close because of all the wood work.
As I noted up front in the log because of scale I used the smallest wood available, and eliminated some strips which I felt were to big, scalewise, for the location.
I did relearn that with these lazer cut models you have to be as precise as possible when fitting the pieces together. If not errors can be carried forward to cause problems where you don't want them
The kit is not hard to build. I made it a little harder by putting lights in it but I am glad that I did
If you build it stay in touch
Clarence
Flying Fish --  MSW
Essex ---  MSW
Constitution  --  MSW
Confederacy -- MSW
Philadelphia -- MSW
Chaperon -- MSW
San Felipe -- Panart
Portland -- Bluejacket
there is also a you tube pictures on this model
Flying Fish --  MSW
Essex ---  MSW
Constitution  --  MSW
Confederacy -- MSW
Philadelphia -- MSW
Chaperon -- MSW
Hi Clarence,
a wonderful model of the "Portland"  :) :)..
​Nils
Current builds
-Lightship Elbe 1
Completed
  • 2 months later...
Hi Clarence,
I just finished fairing the older hull for the PORTLAND after about 10 hours of sanding and filling. Will be picking up the newer kit
from Nic at the big conference in New London end of month.  In talking with him I find that the newer hull is 1/2 inch longer. Might
try adding a 1/2 inch section with some wood from the older kit. Question: Is the keel 1/8 square basswood or a smaller size? The
plan sheet shows it at 1/8. The sponsons look to be a big PITA. Guess I'll have many questions once I get started.
John
My keel is about an 1/8th x 1/4. I can only eyeball it since it is on a stand and can't measure' From  scale stand point that would be 1' x 2' sounds about right.
Good luck with your model. Let me know when you start a build forum.
clarence
Flying Fish --  MSW
Essex ---  MSW
Constitution  --  MSW
Confederacy -- MSW
Philadelphia -- MSW
Chaperon -- MSW
  • 1 year later...
Hi Clarence,
Hope you don't mind but I thought I'd send some pics of my Portland as of today. After 16 months from the start, I finally got the hurricane deck painted and
temporarily in place.  Age related medical issues have weakened my resolve but I'm still going forth. Thus far this seems to be the easier part of the build. The
instructions from here on are extremely lacking in detail. Also, the upper rub rail and remaining trim will be painted white as shown in photos of the prototype.
This has not been an easy challenge.
Be good my friend,
John Elwood
