Greetings,
This is a rebuild of my first build lost after the server crash, as luck would have it I only lost a few photos.  Over the next day or two I'll be adding the photos along with a short write up for each.  I welcome any comments, because this is my first major build and the first as an on-line build.
Thanks,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
BlueJacket's 80' ELCO PT boat out if the box, showing the hull, chart house, cockpit and day cabin along with castings and torpedo tubes.
Tim
Future Build:
Completed Builds:
Member:
Thanks Joe,
I'm excited to get the hull a point where it looks more like a PT Boat.
We have many very fine model builders in our club (Hampton Roads Ship Model Society), with that said it brings a high level of expectation from fellow members, needless to say it will be slow meticulous for me especially because it's my first large build.
Ive completed small kits like the Rainbow and the 10" Sea Coast Mortar and have built many plastic kits over the years.
Thanks for your interest, please continue to follow the build, any help or suggestions are greatly appreciated.   :D
Respectfully,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
My first step was to remove the extra wood, at point on the bow where the wood blank attached to
the equipment used by BlueJacket Ship Crafters.  This was completed with the use of various small chisels’,
files and sanding sticks.
My next step was to transfer the hull lines from the plans to the deck of the actual hull.
By marking these points I would be able to use the templates I made from the plans, these were copied and mounted on
card stock with spray adhesive to make them rigid enough to work with on a
continuing basis.
Regards,
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim
Future Build:
Completed Builds:
Member:
Tim
Future Build:
Completed Builds:
Member:
Tim,
Glad to see your PT Boat build log up and running.  You are doing a good job on this kit and I look forward to following the build.  Also, thanks for bringing this model to the meetings to share your progress with the members.
Ryland
               - Nautical Research Guild
Harvy,
Thanks for the encouragement and don't hesitate to put your two cents in any time you feel.   :D
Tim
Tim
Future Build:
Completed Builds:
Member:
Once the hull is moth and to proper shape the next step is adding the Deck Edge Guards.  Using a sanding block and 150 or finer grit sandpaper I'll sand flat a 1/16" wide strip along both sides of the deck-to-side junction from the bow to stern.
Tim
Future Build:
Completed Builds:
Member:
My next step is to soak the 1/16 x 1/16" Deck Edge Gards is water until they are pliable enough to work with, this only takes a short while because of their small size.  I then taped them around the deck edge and let them dry completely.
post-260-0-78611200-1361219023_thumb.jpgpost-260-0-07279000-1361219057_thumb.jpgpost-260-0-20324900-1361219080_thumb.jpgpost-260-0-26015900-1361219099_thumb.jpg
Tim
Future Build:
Completed Builds:
Member:
Your getting there, a little at a time. Keep the post and pictures. About time someone made one of these. Seen to many PT 109 to last a life time.
Wacko
Joe :D
Go MSW :) :)
Your right, "moving along like a "Heard of Turtles"....  Im looking forward to it looking a little more like a PT Boat but that takes time!  And Joe, I guarantee it won't be PT 109...   ;)
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim,
This is an interesting project, I did not come across a PT build log before. Since I am building the Blue Jacket Schooner myself, I am keen to learn about your experiences with their kits.
I shall follow your progress with great interest, keep up the good work.
/Alfons
Current Build: Gloucester Fishing Schooner - Blue Jacket - Scale 1:48
Next Project: Riva Aquamarine - Amati
Alfons,
This is my first BlueJacket kit.  At this early point Im highly impressed with their quality and workmanship.  The Basswood hull is flawless and extremely easy to work with.
I took a look at your build and I must say you are doing a wonderful job.  I'll be following your build with great interest also.    :)
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings PT Boat fans,
At this point I had hoped to have the Deck Edge Guard and the Chine Guard attached, but I managed to come down with a chest cold and it's prevented me from making any real progress on the kit.
For some strange reason VICKS VaporRub and Sawdust are not compatible!
I hope to have a new post up by the end of the weekend.
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim,
good luck with the chest cold!
question: how heavy is the hull block?  any concerns with checking or other instabilities in such a large hunk of wood?
r/
Jerry
Currently building: Model Expo AMERICA, A/L KING OF THE MISSISSIPPI
Completed: Mamoli Victory cross-section, Revell LSM (Plastic, in memory of Dad), A/L SANSON tug, MS Longboat (awesome model Chuck!), Dumas 1949 Chris-Craft 19' Racing runabout, A/L SWIFT, MS ELSIE, Constructo ELIDIR (now LOUISE), Midwest Muscongus Bay Lobster Smack, Amati 1:80 Yacht ENDEAVOUR, Mamoli CONSTITUTION cross section, Revell VIIc U-boat (1:72 plastic), lotsa other plastic ships
Next up: who knows - there are too many to choose from!
John and Jerry,
Thank you!  The chest cold is getting better!  I should feel like a new person by the weekend.
I'm not soure about the weight of the wood, it's laminsted, the wood is so clear and clean it's hard to see the glue joints.  I really don't believe there will be any chance of checking.  (BlueJacket has done an excelent job with this kit).
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
I'm not quit as far along as I would have wished, but any progress is better than nothing in my book.
I have finished shaping the hull and have most of the heavy sanding complete, I'm sure there will be some minor touchup in a couple areas around the bow.
The next step will be to add the deck guard, sheer clamp and chine guards.  After those are attached I'll drill the three rudder holes and mark the strut slots and install the shaft boss's to the hull.
Photos of the shaped and sanded hull.
Timpost-260-0-79024900-1361750255_thumb.jpgpost-260-0-49934900-1361750256_thumb.jpgpost-260-0-72451300-1361750257_thumb.jpgpost-260-0-48534400-1361750258_thumb.jpg
Edited by Timothy Wood
Tim
Future Build:
Completed Builds:
Member:
Tim,
You are making good progress on your Elco.  The hull lines look great and I also like the cradle you made to hold the hull.  Keep up the good work.
Ryland
Thanks Ryland.  I'm looking forward to seeing progress with your Armed Virginia Sloop!
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim,
Neat!  I'll be following along, watching your build here.  After Pat Matthews did his SIS articles on an RC PT boat a number of years ago the thought has crossed my mind every year or so of building one.  I've always wondered what the Blue Jacket Shipcrafters kit was like - and here it is!  You've got a very good start going there....I'm looking forward to seeing more.
Cheers,
Elia
Elia
Rose Valley, PA
Arethusa: 1907 Gloucester Knockabout
Thanks Elia,
I'll do my best to keep your informed and on the edge of your seat!
Tim
Tim
Future Build:
Completed Builds:
Member:
Tonight I was able to attach the port and starboard deck edges.  It was a little tricky applying CA glue to 1/16 x 1/16" deck edges, as you know this isn't a very wide area.   I applied glue to about an inch of deck edge at a time, then I positioned it and held it until it set, about 15 to 20 seconds.
Photos to follow in a day or two!
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim - the hull looks great!  I'm looking forward to seeing it in person at the club meeting.
Dave
Current builds: Model Shipways 1/48 LongboatEduard 1/48 F4F-3 and F4F-4
Completed ships and boats: Kitbashed Model Shipways 1/24 Grand Banks Dory, 1/16 East Coast Oyster Sharpie,1/48 Echo Cross Section, 1/48 Scratchbuilt Hannah from Hahn plans, 1/64 Kitbashed Rattlesnake from Bob Hunt practicum, 1/64 Brig Supply
Hey Dave,
You will have to wait until the April meeting, as you recall the next meeting is the auction.  I did plan on going to Cabin Fever in April but I think that's off for this year.  I'll be sure to bring the  PT to the April meeting!
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim looks like you are doing a fine build.
michael
Thanks Michael,
With a little luck I'll have an update on her this weekend!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
