Can someone tell me the proper name for any extra partial top timber frame?
I was into a rhythm drawing my frames and suddenly noticed something was wrong.
After about 20 minutes I suddenly saw it tuck in between two frames above a gun port.
(see the attached image below)
Of course I had some choice names for it at the time, but now that I've had time to...  reflect...  I probably should be calling it something else.
Thanks in advance for your help with this.
Alan
Alan O'Neill
Seems I may be resorting to my original nautical vernacular (spoken like a true sailor) as this unnamed timber had caused me considerable emotional grief.
Or possible I'll just refer to it as Waldo (as in where's Waldo)  ;^)
Alan O'Neill
My guess is:  filler top .
In any case,  what you show is a nightmare.  Tapered timbers - shifted timbers.  re-enforces my preference for planking everything from the main wale on up. In which case, it is easier and makes for a more stable hull to fill the spaces above the main wale with timbers.
Edited by Jaager
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Thank you for the very good suggestion Jagger!
It was suggested this would take some research to find out.
I'm guessing it was not that common.
I have a small library that I will look through once more... and of course there is the inter-web which I will delve into further but I have a feeling you may be correct as it may have just been a "toptimber filler piece" as opposed to that sneaky little so and so.
For the present mine will be referred to affectionately :rolleyes:  as Waldo.
Regarding your comment on the choice of build... there are moments I feel I may have bitten off more than I can chew but I have nothing but time and I can be very patient but certainly never quit.  I am hoping it will be more fun than it seems. It will definitely be a worthy challenge.... and ah loves a challenge!
Alan
Edited by AON
Alan O'Neill
Peter Goodwin (Sailing Man of War, 1987, pg.15,16) and C.N. Longridge (Anatomy of Nelson's Ships, 1981, pg.19) both call them "lengthening pieces".  DH Roberts' translation of Blaise Ollivier's Remarks on the Navies of the English and the Dutch (1992, pg.65) calls them "fifth futtocks", but this is a translation of Ollivier's best guess on the subject.  Generally, I believe they're also occasionally called "filling pieces".  This seems to be the case whether they're above a port sill, as in your example, or attached to an unbroken bend.
"Waldo" works for me, Alan.   The name sort of grows on you.   ;)  :)
Edited by mtaylor
Usually 'Waldos' are attached to the top timber beside them with a long scarph. I've not seen an independent one such as your illustration shows. Very interesting!
I have a vague recollection of Rees mentioning and showing Waldo (though he called it something else) in his Cyclopaedia. Alas, I am packing ti move and my hard copy is somewhere in a box.
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
I have Rees and hadn't found it but will look again, I also have the PDF of the Cyclopaedia and will hunt through it tonight.
Thank you Wayne
(it may be hard to let go of Waldo)
Alan O'Neill
