I made some models of sanding tools from HDD parts.
I will try to explain with picture how i made.
Also i made my "new" power supply from computer power supply.
take the cover off
remove heads
take out magnets and other parts
glue paper sand on one of the platans.
Al so for the vertical sanding, use a "medical tube"
the parts are ready
install the disk withe the sanding paper, glued.
Make one small cover, if you like
install also the vertical sanding tube
put the helping and protect cover, in position
Current build : Sovereign of the Seas - Mantua 1:78 scale
Finished:        San John the Baptist - Cross section
                    Santisima Trinidad - Cross section                  Galery Santisima
                    San John the Baptist ( San Juan Bautista)    Galery  San John
                    HMS Victory 1805 - Cross section - Corel 1:98 scale
                    Panart (Mantua) 740 Battle Station          Battle Station Panart 740 Galerry
On Hold:        HMS Bounty 1:64   Mamoli MV39
I have made some with vertical tube, and other (with different ganulations) without vertical tube,
and also without protect cover
different type of protections and sanding paper
how to fix inside the vertical sanding tool.
For this to work, you need just ATA (PATA) hard disks, not the SATA ones
You can find wich are ok from the conectors
this are the PATA that are OK
On left is a SATA hard drive (not ok), and on right is a PATA that is OK
grup of PATA and SATA that i prepared
Pretty cool and ingenious.
How long do they last with the sawdust?
Jean-Philippe (JP)
Current build: Syren , HMS Victory Cross Section, Essex
:dancetl6:Please visit and subscribe to my YouTube Channel
On Hold: Rattlesnake (Scratch-built)
Completed:
I also made a "new" power supply.
From a PC you can take the power supply.
Keep the +5 and +12v connector as they are (you can use to the PATA hard disks),
and cut wires just from the 20 -24 connector
take one or two wires withe the same color to a new conector
use the green and a black to a switch (small one) to switch on the power
you cand see what means each color
Here is how i made the new conectors
the power source with the HDD sanding together
Hi Captgino, the quality depends just of the sanding paper, i used one for long (it was a 100, and an other 180) Now i made some separate (i have to invalidate some old HDD) so i made some new sandings, also wit different grains. I also have some spare disks (from this, because in some HDD were 2-3 turntables) an i will prepare with new grains
Cristi
Great idea Cristi, this is thinking well outside of the proverbial box.  Are the disks floating or do they have sufficient backing to keep them parallel across the whole platter when sanding?
cheers
Pat
Edited by BANYAN
Oh, and don't forget about saving the very powerful magnets that show their magnetic strength almost completely on one side due to the properties of the mounting shield.
BTW, a hard disk spins at around 5000 to 7000 RPM.  Isn't that a bit fast for sanding?  Since they're DC motors, can you adjust speed by varying the voltage?
Hi Bob i saved a lot of magnets, i use them, and are excellent (even from the SATA). Also i saved and try to use (i have ideas but not time) the bearings.
Cabbie, i did not thought about a tunbler, but i will take your idea and i will try.
Pat, the disk is not floating but there are well designed and seat ok, and parallel to the "desk".
The speed is fixed (5400, 7200 or 1000 RPM) depending of the hard disk (the motors are step motors and i will try to find some schematics to
see how to alter the speed). The motors are "strong enough".
For the power source i made (to the old power i used) a variable voltage output.
With this schematic, and i have to fix the radiator and the variable resitor, plus the 2 output connectors
I can try all the new ideas you will send to me
All the best to all. Cristi
