thanks for the link ,i didn't knew it and i will share in my french forum modelisme naval bois  :
http://modelisme-naval-bois.lebonforum.com/
Edited by ofencer29350
Of the bank I look at an ocean of pleasure, or the tumult attracts you, this global movement will be your tipcart!
current build:   royal caroline
buid finished:  la recouvrancehttp://modelshipworld.com/index.php/topic/3025-la-recouvrance-by-ofencer29350/page-2?hl=recouvrance
Don,
Left hand side of the page... there's a down-arrow with a line underneath it.   Check the boxes that appear (as appropriate) and hit the button.
Thanks, grsjax and ofencer29350, for the links. I've joined the forum modèlisme naval bois as a result. I also like the Marine et Modélisme d'Arsenal forum. There are plenty of great builds in both, as well as the different range of models from this forum. It's wonderful to peek into the fora in other countries such as Russia, Germany, Japan etc as they also look great -- representing different styles, models and culture which all adds to the interest and contextualises our different conceptual frameworks and conventions in this hobby.
Tony
Hi Mark, Still have not been able to download, I found the icon but it just keeps spining I waited at least 7min and could not get it downloaded, What am I doing wrong. Thanks Don
Don -
Make sure the pdf button is clicked, and the check box at the bottom of the window that pops up.
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Interesting French book that can be downloaded.  http://gallica.bnf.fr/ark:/12148/bpt6k5699565s.r=Collection%20de%20plans%20bateaux
Website is in French but I managed to get the book downloaded in pdf format ok not knowing any French.
Wonderful resource - THANK YOU!!!  This is one of the classics, frequently referenced.  There is a modern reproduction of many of the plans available as well, but the original is always a better resource.
Wayne
Epictetus
When you click the down arrow on the left another window should shiw up with pdf or jpg as options and a small square block to click at the bottom agreeing to the terms. If the window doesn't show you may have a setting in your briwser blocking it.
Wayne
Epictetus
Don,
If you click on the link, it opens... look to the left
The red arrow shows the download icon.
This will open another window.  Make sure the two buttons have been clicked... the ones with the red arrow. When done, click the button with the blue arrow.
I hope this helps.
Edited by mtaylor
Don,
I've tried on 4 browsers and they all worked for me. Is it possible you have javascript turned off on your browser? You can follow this link https://www.whatismybrowser.com/detect/is-javascript-enabled to check.
Good luck,
Richard.
Richard
Current Build: Early 19th Century US Revenue Cutter (Artesania Latina "Dallas" - messed about)
Completed Build: Yakatabune - Japanese - Woody Joe mini
Member: Nautical Research Guild & Midwest Model Shipwrights
Excellent resource, Admiral Paris is one of the classics... thank you very much grsjax and all!
Just in case, for all the non French-speakers which have difficulties to download the resource:  to download you must first check the box which says En cochant cette caisse, je recconais avoir pris... etc.
It is just a check  that you agree with the terms and conditions on which you have to click first, otherwise the download does not happen!
