it just keeps getting better and better and better
great job
Joe
Hi Joe
Thank you :)
& thank all for your likes! I hope not to disappoint you with what comes next...............
The next parts to make are the davits for the longboats, not easy to do. The plan comes again from the Atlas du Genie Maritime, as most of the parts I built for this model.
The plans from the Atlas
The copied forms, glued to 1 mm brass sheet. Two more glued to the brass for spare parts
First raw cut with the jewellers saw
The davit, cut and filed to shape. It took me about 2 hours to come to this piont, there is much more to do until they are ready.
Will be continued.......
Regards
Gerhard
Problems just mean: solutions not yet found
Models in progress
SMS DANZIG
http://modelshipworld.com/index.php/topic/12842-sms-danzig-1851-by-gerhardvienna-radio-150-scale/
USS CAIRO
http://modelshipworld.com/index.php/topic/13282-uss-cairo-by-gerhardvienna-live-steam-radio/
Baby Bootlegger 1/10
http://modelshipworld.com/index.php/topic/13625-baby-bootlegger-110-radio-by-gerhardvienna/
Swiss paddlesteamer RIGI 1848 1:50, after plans from the Verkehrshaus Zürich, rescaled to original length
Anchor tugboat BISON, 1:50, plans from VTH, scratch
Finished models
See-Ewer ELBE, Constructo kit 1:48
German fastboat after plans from german Reichskriegsmarine measure unknown (too ugly to show up!)
German traffic boat for battleships WW2, 1:50, after plans from Jürgen Eichardt, scratch
German Schnellboot TIGER P6141 VTH plans, scratch
I finally got a chance to sit down with a glass of wine and go over some of your earlier posts. Loved every bit of it!
Glenn
Hi Glenn
Nice to have you here! So, sit down a little longer, and take another glass..............
Thank you all too for your nice likes!
The last days were filled up with even more work for my home improvement, but I found some hours too for the SMS DANZIG. The four davits are finally cut, and the soldering form is almost done.
Davits cut, two of them have still their paper sheets glued on. This will be removed after grinding and filing to final shape
The soldering form, stages to make it.
1), draw the inner contour of the part you will have to solder. This inner form must be as thick as the part that will be set into the form, 1mm in this case.
2), make the spacer for the parts to be soldered in
3), cut the inner part of the soldering form, and the place for the spacer
Outer parts of the soldering form follow the outer contour of the davit
The second outer part of the form will be made today, even the cuttings to the spacer. Some holes will be drilled, they are important to fix the form as well as to place the thin metal sheets that will hold the rollers later.
Will be continued.....................
Regards
Gerhard
Edited by Gerhardvienna
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Your log is realy great tutorial when, one day, I take my chance with silver soldering. You just showed that nothing is impossible
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Hi Nenad
This is all soldered with usual solder wire, silver soldering is something I`ve not tried til now. But I will have to learn that, when it comes to the boilers and steam engines. My equipment for the normal soldering is just a 30 watts electric soldering iron, and soldering wire for electronic devices from Stannol.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
I just can not believe! Must try !
In progress:
Content of log :
Past build:
The first attempts I made, were pure chaos, so don`t give up, when it looks really bad! Most important is not to be too fast, wait until the soldering iron is hot enough, and use soldering grease or liquid. I do it that way, and it works well for me. I`ll show what I do in one of the following posts, and maybe make a little tutorial about.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi again, and thank you all for watching, nice likes, and comments!
A small tutorial would be nice for everyone to see. Thanks
Hello Joe
Tutorial will follow, when this set of davits is finished, so I can copy everything into a new report. But it is still some way to go.............
Today I finished the soldering form, so the next things to do will be the fabrication of the roller sheets. Every davit will carry 3 rollers of 3mm diameter, with 1,1mm width. More about that will follow soon.
Grooves for the spacer cut into the outer form parts
Spacer for rollers in place, no slashes cut at this time.
That pin (with the white head) is important, it locates the place for the rollers axle!
Slashes cut to the spacer. This slashes are necessary to place the roller distance sheets, distance between the sheets will be 1,2mm, the whole head of the davit is only 4,8mmwide. The inner sheets are 0,1mm, the outer ones 0,5mm thick.
It took me 3 attempts to make the spacer, the smallest mistake will ruin the whole thing.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
You have nerves !
Do you notice that 0,5mm can be a bit thicker or a bit thiner than a exactly 0,5mm?
Edited by Nenad
In progress:
Content of log :
Past build:
You have nerves !
NERVES???????
This is called steel wire :D
It`s just my way to build models, try, if it does not fit to my requirement, try again! And this so many times till it fits. As I built my german Schnellboot TIGER, I made the hull twice, the first one was not good enough. The starboard side was about 1mm too narrow :huh: ..............
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
superb workmanship Gerhard.........the fittings and davits look great!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Popeye
Thank You! But this is not even the half way, there are so much more things to do, but at the time I`ve no room to get to my machinery. Lathe and milling machine are closed for my home renovation, I hope within the next two weeks i can reopen all, and turn all that little rollers I need for the davits. Days will be filled then with a lot of work on two boats, I can`t get bored from doing nothing :D!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
  • 11 months later...
Back again...................
In the meantime there were so many other projects to make, that I had almost no time for my ship models:default_wallbash:
But NOW it`s time to continue with something for the DANZIG! Next things to do will be the boats of the ship, the best I canb do with them, is to copy Archjofos method of building baots, as he showed in his simply perfect La Creole build report. Wood is ordered from http://www.massiv-holz-werkstatt.de/  should arrive next week. Then I can go on again with more stuff from that great prussian steamer!
All the best
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Glad to see you're back.  You have a fine boat build going.
Bob
Current build:  SS_ Mariefred
Hi Bob
Thank you, that`s what happens when admirals take over:default_wallbash:
Breaks for the modelbuilders wishes, but as I hope, now it will be all set and done for her "majesty" and the next steps for the Danzig can be done. But; I`ll never know what comes next............
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
look'in forward to see you resume as well :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 3 months later...
34 minutes ago, Torbogdan said:
A very good build so far! Just hitting the "like" button is not enough. Top notch!
Thank you!
There is a lot more to come, just working on the plans for the ship. There are no infos about her, so I will have to adapt other plans for the hull, maybe the plans to the russian Vladimir. But first comes the Cairo, lots of work on her too!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
