hello friends
i have the proxxon table saw (FET) and i need to buy good blade for cutting / making planks
my blade (the one that came with the table saw) can't cut planks even 1.5mm *5mm
so i want to buy a good blade for that job
which blade is the best for that job? (its not need to be only from proxxon but ni to be 80mm and 10mm hole to fit )
Edited by michael101
"smooth seas do not make good sailors..."
:pirate41:
MY FIRS BUILD : H.M.S BOUNTY (mamoli)
SECOND BUILD :The concord stagecoach 1:12 youtube link : https://www.youtube.com/watch?v=yJzCs9umWPI
CURRENTLY BUILD : H.M.S VICTORY (Caldercraft) : http://modelshipworld.com/index.php?/topic/15501-hms-victory-by-michael101-caldercraft-scale-172/
Michael
I use a metal cutting slitting saw blade which is 1/32 (.031) inch wide and has zero kerf. This gives me an almost polished finish to the planks and control on thickness of +/- .0015 inch. The blade has 108 teeth and was bought off the web for about £6 (probably originated from China). I don't have a Proxxon saw and I think the problem you are going to encounter is getting a slitting saw bade of 80mm X 10mm bore. I think this sizing is pretty much exclusive to Proxxon (unless someone else know different).
Example of my planks cut with the blade described above :-
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Michael - sorry should have said the planks are .031 inches thick and .200 inch wide.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Michael
Sorry my reply wasn't easy for you to understand.
This is the type of blade I use.  Sold by www.rdgtools.co.uk.
It is a bit too big for your table saw.
4" HSS SLITTING SAW 0.8mm WIDE / 1" BORE
MAXIMUM UP TO 130 TEETH FOR BETTER CUTTING
SEE OUR OTHER SLITTING SAWS
Be sure to add me to your favourites list!
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I checked Thurston and while they sell 2" and 3" (51mm and 76mm) diameter blades, the smallest hole size is 12.5mm.  I think that hole size might limit you.
I did get a number of hits using the following in Google:  https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=slitting%20saw%20blades%2010mm    Just click the link and it will open.
Bingo, Richard... that should work.
Another thing you can do if you have a lathe is to make and arbor ti fit the saw if theblades hole is to big.  I did this for my Preac.  Keeping this in mind take a look at Thurston for the proper blade. http://thurstonmfg.com/plain-metal-slitting-saws.html
David B
i see in the proton web
Technical data:
230V. 7,000rpm. Mitre infinitely adjustable up to 45°. Table size 300 x 300mm. Cutting depth 1 - 22mm. Saw blades between 50 - 85mm can be used (with 10mm centre hole). Weight approx. 6kg.
so i can buy 50mm also and i need it for making planks so i no need more than 50 mm :)
someone can recommend a specific blade with Experience of making planks?
or someone can recommend o blade that can serve what i looking for from that list https://knupfer.info...ageblatter.html (Moxis thank you for posting that link )?
thank you
Michael.
:pirate41:
Hello Michael,
Yes, I have both 50 mm and 63 mm diameter blades with 10 mm hole from Knupfer and have made planks of birch and abache with those blades. Both work very nicely with Proxxon saw, and the quality of planks is super.
thank you!
can you please give me the item number because all the web is in german and i can't understand the language
also i need to check if they sending to israel :)
:pirate41:
Hello Michael,
Following please find the part numbers for all Knupfer blades which can be used directly with Proxxon saw (have 10 mm hole):
50 mm diameter, 0,3 mm thickness: w-krs-50-03-10
50 mm diameter, 0,4 mm thickness: w-krs-50-04-10
50 mm diameter, 0,5 mm thickness: w-krs-50-05-10
50 mm diameter, 1,0 mm thickness: w-krs-50-10-10
63 mm diameter, 0,5 mm thickness: w-krs-63-05-10
If you think, which blades to order, I suggest you take both the 50 mm diameter and 0,5 mm thickness, and 63 mm diameter and 0,5 mm thickness blades. The thinner blades (0,3 mm and 0,4 mm) are prone to bend a little when in use.
And don`t worry Michael, you can contact Mr Knupfer in English language as well, he understands and speaks very good English.
Depending on the thickness of the wood, the most important thing will be the tooth count.
While this is for the Byrnes saw, the tooth counts still apply for the various wood thicknesses:  http://www.hobbymillusa.com/byrnes-saw-operation.php
hello Moxis
i have talk with Mr Knupfer bay emal and he give me everything i need
just want to make sure :
beside of making planks from wood i need also to cut planks i mean i have 0.5mm * 4mm planks and i want to cut 1mm to make the plank 0.5mm*3mm
can i do it with:
or i need  also:
thank you again
Michael.
:pirate41:
Hello Michael,
You can do this with any of those blades, you don`t necessarily need those thin (0,3 or 0,4) blades. You have to adjust the rip fence of your saw very carefully so that the distance between the saw blade and rip fence is exactly 3 mm.
Please see the enclosed picture where I cut 3 x 1 mm plank out of 5 x 1 mm strip with the 50 x 0,5 blade.
Thank you Moxis !!!
i hope it will be my last question lol have you try that one of proxxon?
http://www.amazon.com/Proxxon-28020-2-Inch-HSS-Blade/dp/B000S6DTT0
:pirate41:
